HobbyWing ESC XERUN-120A V3 >
Old 08-05-2012, 10:34 PM
ZZracing's Avatar
Default HobbyWing ESC XERUN-120A V3
This adds three colors! Red-Black-Blue
Strongest: Most advanced software functions
Simplest: Built-in electronic switch saves chassis space
Easiest: Ten pre-set profiles for Plug and Play
Most Reliable: Innovative heat dissipation structure
XERUN-120A-V3 has 3 kind of color options:
Blue edition: PN=81020310
Black edition: PN=81020320
Red edition: PN=81020330
1 Specification
Specification XERUN-120A-V3
Current Continuous: 120A, Burst: 760A
Input * Note #1 4-9 cells NiMH/NiCd or 2-3S LiPo
Built-in BEC [email protected] (linear mode)
Resistance 0.0003 Ohm
Motor Supported Sensored and sensorless brushless motor
Suitable Motor With 2 Lipo or 4-6 NiMH
1/10 on-road: >=3.5T, 1/10 off-road: >=5.5T
With 3 Lipo or 7-9 NiMH
1/10 on-road: >=5.5T, 1/10 off-road: >=8.5T
Suitable Car 1/10,1/12 all competitions
1/10,1/8 rock crawler
Cooling Fan 5V
Size 37.5mm(L) * 31mm(W) * 29.5mm(H), excludes wire connectors
37.5mm(L) * 37mm(W) * 29.5mm(H), includes wire connectors
Weight 93g
* Note #1
For 4-6 cells NiMH/NiCd or 2S LiPo, the standard cooling fan needn't be changed.
For 7-9 cells NiMH/NiCd or 3S LiPo, the standard cooling fan need be changed to 12V high voltage fan.
2 Features
2.1 All in One. Up to ten profiles can be stored in the memory and imported or exported easily. Factory pre-set profiles include:
Blinky mode, Modify Mode, Stock mode, Practice mode, Offroad mode, Drift mode, Crawler mode.
2.2 Built-in Electronic Switch, long life and high reliability, also saves space on the chassis.
2.3 Aluminum Upper Case with optional colors, giving better heat dissipation, and allowing higher current.
2.4 External Programming Port (EPP), easy to connect and also a power port for additional fan.
2.5 Advanced Dynamic Timing technology, providing more customization possibilities for highest level competitions.
2.6 Precise throttle and brake control, setting of drag brake and brake strength with more options, new punch and brake rate control functions, and throttle and brake curves through the PC client.
2.7 Integrated Data logger, recording the maximum temperature of ESC and motor as well as the maximum RPM, using LCD Programming box to check easily in the pits.
2.8 Multi Protection Functions, making your running safe with ESC and Motor overheat protection, low voltage cutoff and throttle signal loss protection.
2.9 Easily programmed with the Professional LCD Program Box and USB Link Software
(Note: XERUN V3 ESC ONLY works with the new version of the USB Link Software, that is, the version not ealier than V3.0_Beta_120401)
2.10 New USB LINK Software graphic interface, providing extra parameters for advanced settings.
2.11 ESC firmware can be updated through the USB adapter in the LCD Program Box.
ZZracing is offline
Old 08-05-2012, 10:39 PM
ZZracing's Avatar
USB LINK also has the very big change!
ZZracing is offline
Old 08-05-2012, 10:40 PM
ZZracing's Avatar
The 2012 IFMAR World Championships was held in Holland since 22nd to 28th July. In this biggest race, Hobbywing successfully finished its wonderful first show.
Hobbywing team driver Andy Moore chose the XERUN-120A-V3 speedo in all races and took the 2nd place of 1/12th scale and the A8 of 1/10th scale electric IFMAR world titles
Japanese top driver Atsushi Hara also installed Hobbywing XERUN-120A-V3 speedo in his Hot Bodies cars and took the TQ and A2 of 1/10th scale electric IFMAR world titles.
Another Hobbywing driver, German young star Yannic Prumper was potential to get good result in this race, unfortunately he had much bad lucks so finally he lost the chance to enter the top 10, but his driving skill was highly praised by other drivers, everybody believes that he will grow up to a top driver soon.
Hobbywing chief engineer and co-founder Mr. Michael Liu, and Hobbywing team manager Mr. Salton Dong also went to Holland to provide technical supports and services at track-side for the drivers using Hobbywing products. They had closer communications with other RC manufacturers and drivers with the expectation to speed up the process of internationalization of Hobbywing.
ZZracing is offline
Old 08-06-2012, 01:23 AM
narcotiks's Avatar
There's already a thread for the V3.
narcotiks is offline
Old 08-07-2012, 03:15 AM
ZZracing's Avatar
v3 is a sharp weapon!
ZZracing is offline
Old 08-13-2012, 10:11 AM
ZZracing's Avatar
Atsushi hara V3 set up
V3 FIRMWARE 0511_BETA
2A 50%
2B 15
2C 15
3A 14
3B 87.5%
3C =DRAG BRAKE
3D 50%
3E 20
3F 20
4A(BOOST) 27
4B(START RPM) 11000
4C(END RPM) 28000
5A(TURBO) 26
5B FULL TH
5C 0.15s
5E 15
5F 18
ZZracing is offline
Old 08-13-2012, 10:31 AM
lewis110's Avatar
What motor are those setting for?
lewis110 is offline
Old 08-13-2012, 05:52 PM
ZZracing's Avatar
REEDY 4.5T
ZZracing is offline
Old 08-14-2012, 12:53 PM
Barry_Hughes's Avatar
Thumbs down
Why start a new thread when there is already one specific for the V3 and the it is also covered in the Hobbywing software thread as well
Barry_Hughes is offline
Old 08-25-2012, 06:28 AM
ZZracing's Avatar
Andy moore 1/12 v3 set up
ZZracing is offline
Old 08-26-2012, 05:42 PM
GSM Storm's Avatar
Trader Rating: 114 (100%+)
2A 50%
2B 15
2C 15
3A 14
3B 87.5%
3C =DRAG BRAKE
3D 50%
3E 20
3F 20
4A(BOOST) 27
4B(START RPM) 11000
4C(END RPM) 28000
5A(TURBO) 26
5B FULL TH
5C 0.15s
5E 15
5F 18
Do you know the gear ratio that was run with this setup.
Regards
Gary
GSM Storm is offline
Old 08-26-2012, 08:16 PM
caaraa is offline
Old 08-29-2012, 08:05 AM
ZZracing's Avatar
Regards
Gary
Sorry, I don't know!
ZZracing is offline
Old 08-05-2013, 12:55 PM
Default Issue throttle V3.1
Gents,
I have 2 cars, both of them has an new hobby wing ESC v3.1
Yesterday we went to test the car on the track.
When you apply the throttle something the car does not react after a couple of time trying it will start running.
It keeps running for some minutes but when you try to apply it the throttle it not reacting.
The steering is still working when this happen, the ESC is not hot.
Is this a know issue for you guys.
I like the way that the esc works the only problem is why the throttle stop working suddenly.
Please let me know what can be done.
Thanks in advance
snipertech is offline
Old 08-19-2013, 02:36 AM
Anyone have a 13.5 setup ??
onroad racer is offline
