Old 03-03-2005, 04:29 PM   #1
Trader Rating: 114 (100%+)
Send a message via AIM to Valentin.H
Default how to make a 7 cell flat pack?
how do you make a 7 cell flat pack? how do you connect the 7th cell too the 6 cells with the batt. bars?
-valentin
www.csjunkies.com
Valentin.H is offline   Reply With Quote
Old 03-03-2005, 04:31 PM   #2
ThePrfctGetaway's Avatar
Location: If I told you, I'd have to shoot you in the face.
Send a message via AIM to ThePrfctGetaway
I'm assuming connect it like the other cells??
ThePrfctGetaway is offline   Reply With Quote
Old 03-03-2005, 04:44 PM   #3
Its simple you just use an extra battery bar to connect the cell to the pack. You will probably have to by a new package of battery bars to do this. Then solder the connection you need for your ESC..Just make sure that the the battery bars are still alternating sides like you would on a 6 cell pack.
If you use wires to connect the last cell, you willl raise the internal resistance of the battery pack. Something you don't want.
wcoyote is offline   Reply With Quote
Old 03-03-2005, 05:26 PM   #4
i c....btu how would i connect it? i cant imagine how, because there is a extra battery but how are you going to solder the extra bar to the dang pack?
-valentin
www.csjunkies.com
Old 03-03-2005, 05:30 PM   #5
Steve Bahnatka's Avatar
Send a message via AIM to Steve Bahnatka
use wire?
SMC-/-JACO-/-PARMA-/-TEKIN-/-CRI
Steve Bahnatka is offline   Reply With Quote
Old 03-03-2005, 05:35 PM   #6
sosidge's Avatar
This is either the dumbest question I've seen on the board, or we just haven't understood your problem clearly. I would have thought it was fairly obvious how you solder another cell on.
Old 03-03-2005, 05:36 PM   #7
PitCrew's Avatar
I think this guys wants to make a 7 cell out of a stick pack (7 cell hump pack)
If thats the case, you have to completly dissasemble the pack, as in remove all shrink wrap and rip off the 'welded' tabs connecting the cells together in stick formation. Then get some battery bars. solder the bars to the ends of the cells, from one cells (+) to the next cells (-). If you need to ask any other questions about how to do this, you probably shouldn't even mess around with it!!!!
PitCrew is offline   Reply With Quote
Old 03-03-2005, 05:48 PM   #8
no im buying loose cells and im just wonderinbg HOW THE HELL DO I CONNECT THE FRICKEN 7TH CELL TO THE FRICKEN PACK!!! lol im asking because battery bars have 2 cells, which hold 2 packs together, so im wondering how do i attach it! (A PIC WOULD BE NICE! xD)
PLUS IM NEW TO THIS "soldering your own batts." thing so hehe SORRY!
-valentin
www.csjunkies.com
Old 03-03-2005, 05:58 PM   #9
Trader Rating: 28 (100%+)
no im buying loose cells and im just wonderinbg HOW THE HELL DO I CONNECT THE FRICKEN 7TH CELL TO THE FRICKEN PACK!!! lol im asking because battery bars have 2 ends, which hold 2 packs together, so im wondering how do i attach it! (A PIC WOULD BE NICE! xD)
Start by lining up two cells, with the negative and positve sides of the batts opposite themselves. Solder a batt bar to the positive of one and the negative of the other. Leave either the positive or negative open of the first batt. Keep doing the batts like that..positive to negative until you get to the last one. Then the opposite of what you left open on the starting end will be open. If you left the neg open, then the last one should have a positive open.
If you plan to solder direct every time, solder a batt bar on pointing up, then bend it around the top of the pack, so it is flat. That's where you solder your speedo wires.
If you are going to use plugs, then solder a wire to each end that's open, then solder the ends of the wire to the plug. Make sure the polarity of the plug matches the polarity of the speed control plug.
jbrow1 is offline   Reply With Quote
Old 03-03-2005, 06:00 PM   #10
You connect it just like all the other cells! Instead of putting an endbar on the 6th cell when assembling the pack put another horizontal (regular position) bar on the end connecting it to the 7th cell. Once the 7th cell is connected to the 6th cell solder an endbar on to the remaining end. You are either looking for something different then we think, or you are making this way too complicated.
AE Racer is offline   Reply With Quote
Old 03-03-2005, 06:00 PM   #11
ChrisP's Avatar
I was goingto defend the question..saying that most jigs only allow for up to 6 cells....but that last comment blew my defence outof the water...
Ok...to connect the seventh cell...you do it exactly like the previous 6cells
[]_[]T[]_[]T[]_[]T[]
sorry it's so primitive....but [] is a cell and looking at it you would have a battery bar at the bottom _ and then on the to...T.....to connect them all together....macking sure to go from the + on one cell to the - on the next....
ChrisP is offline   Reply With Quote
Old 03-03-2005, 07:04 PM   #12
i get what your saying windsor, thanks alot, but wat does Ts suppose to be? lolz
-valentin
www.csjunkies.com
Old 03-03-2005, 07:15 PM   #13
ChadCapece's Avatar
The battery bar symbol for the top side of the diagram.
ChadCapece is offline   Reply With Quote
Old 03-03-2005, 07:20 PM   #14
isnt the battery bar the _ thing??
-valentin
www.csjunkies.com
Old 03-03-2005, 07:21 PM   #15
ChrisP's Avatar
There is no symbol for an elevated underscore...or overscore if you will....the closest I could find was the T....
Ignore the vertical line on the T.....
Possibly you should consider a name change?(J/K)
Convert Hump Pack to Flat Pack robcox1980 Radio and Electronics 1 04-30-2008 09:17 AM
WTB Receiver 5 Cell Flat Pack zJatoRad R/C Items: Wanted to Buy 5 01-24-2007 11:28 AM
Flat 5 Cell Receiver Pack DOMOisCOOL R/C Items: Wanted to Buy 5 12-06-2006 11:46 AM
Wall hits make cells go flat? celt MARCCA Discussion 10 01-07-2005 06:08 AM
flat pack nitrosaurus Nitro On-Road 7 09-24-2003 11:35 PM
