Old 08-02-2012, 07:44 PM   #1
Trader Rating: 77 (100%+)
Default motor cogs in only three positions
what does it mean when a brushless motor only cogs in three positions? What I mean is, you take the motor and turn the shaft. almost all brushless motors seem to cog in one of six positions; but I ran across a motor that only cogs in three, each being one third of a rotation apart.
motor seems to run fine otherwise and the rotor checks out ok on a gauss meter, almost balanced + to - too.
I race at:
SpeedWorld Raceway
Roseville / Sacramento, California
VTA, 1/10 nitro, touring, USGT, F1, and more!
www.speedworldraceway.com
slashdriver is offline   Reply With Quote
Old 08-03-2012, 06:09 PM   #2
Hyde's Avatar
What esc? What motor? Are you running a sensored brushless motor with a sensor-less esc? What batteries are you using? Gearing? What Model RC?
MyForum> www.uncovertruth.forumotion.com
Hyde is offline   Reply With Quote
Old 08-03-2012, 06:23 PM   #3
samnelso's Avatar
3 pole stator versus 6 pole?
Team Associated | Reedy | Airtronics
RC Excitement: Fitchburg, MA | RC Madness: Enfield, CT | Horsham RC
samnelso is offline   Reply With Quote
Old 08-03-2012, 06:26 PM   #4
I'm not talking about when it's wired to an ESC/battery etc., i'm talking about when you are holding the bare motor in your hands not hooked to anything, and just turning the shaft by hand.
Interesting thought on the stator. it's an older novak motor, I wonder if they made them that way in the past.
I race at:
SpeedWorld Raceway
Old 08-03-2012, 10:28 PM   #5
syndr0me's Avatar
Trader Rating: 32 (100%+)
You can make any motor feel this way by shorting out two of the poles. Jumper some solder between two of your tabs and see what I mean.
I've come across some DUO motors in the past that felt this way without being shorted. They always ran fine.
syndr0me is offline   Reply With Quote
Old 08-04-2012, 12:47 AM   #6
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Interesting. When I bridge the tabs on motors, I usually get high resistance, but not the loss of cogging.
Old 08-04-2012, 03:57 AM   #7
I believe its less rpm on higher pole count usually.
I have not heard about 540 size motors with 6 poles. More info is needed.
MatsNorway is offline   Reply With Quote
Old 08-04-2012, 08:30 AM   #8
syndr0me's Avatar
I guess I should have said jumper them and spin it by hand. Applying power would be bad. It makes one of the poles feel soft.
Old 08-04-2012, 10:42 AM   #9
Trader Rating: 217 (100%+)
I tested 5 of my motors and all have 3 cogs.
Andy Koback is online now   Reply With Quote
