YOKOMO Touring Car BD-7 >
Like Tree8Likes
Old 07-26-2018, 08:22 AM
  #7531
b20btec's Avatar
Originally Posted by NumptyRacing View Post
Ok cheers, Ive seen it advertised as a BD7 option on some sites. I think I will leave mine as it is if thats the case
Enjoy your 2016, it's still a very competitive car as it sits. I do recommend setting your eccentrics high all around, if you don't like it you can always set it back to lower position.
NumptyRacing likes this.
b20btec is offline
Old 10-14-2018, 06:51 PM
  #7532
Trader Rating: 22 (100%+)
I need some help please, what front drive shafts will work on the 2016 BD7 Black edition? Mine say 40.6.
is there any other MFG that will work? I can’t find any Yokomo s in the USA
please pm me.
Thanks for the help
Grumpybrat is offline
Old 10-14-2018, 07:01 PM
  #7533
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Check with bigwavedave33 he may have some
RKeasler is offline
Old 10-15-2018, 12:11 AM
  #7534
Tiny.24's Avatar
is there any other MFG that will work? I canít find any Yokomo s in the USA
please pm me.
Thanks for the help
i have sets in stock. PM for details and pricing. Located Vancouver Canada.
Tiny.24 is offline
Old 10-15-2018, 07:49 AM
  #7535
please pm me.
Thanks for the help
3racing xi sport dcj may also fit, just 1 mm shorter if you don"t mind.
tc3driverhk is offline
Old 10-15-2018, 10:17 AM
  #7536
Thanks you for the info on Front Drive shafts, went with spec r p8 version
Old 06-09-2019, 06:18 PM
  #7537
Jhollywood3000's Avatar
Hello everyone, how can you tell the difference between the years? I am not sure if i have a 2014 or 2015.
Jhollywood3000 is offline
Old 06-10-2019, 01:23 AM
  #7538
DirkW's Avatar
The '15 introduced the X-braces on the diff bulkheads - the '14 did not have those.
DirkW is offline
Old 06-11-2019, 01:00 PM
  #7539
Ahh ok, thanx. What about the difference between 15 and 16? Later on I’ll post photos of the car. When I got the car I was told it’s a bd7, but I am not sure what manual to download.
Old 06-11-2019, 01:16 PM
  #7540
DirkW's Avatar
Ahh ok, thanx. What about the difference between 15 and 16? Later on Iíll post photos of the car. When I got the car I was told itís a bd7, but I am not sure what manual to download.
The '16 had shorter dampers, smaller diffs, etc. than the previous models
DirkW is offline
Old 12-03-2019, 06:30 AM
  #7541
tak4's Avatar
Hello all. I'm resurrecting an old thread because i need some help.
I'm getting back into onroad ep and will be using my 2012 bd7 for the 13.5 nonboosted class. I've tested the car, got the fdr down pat and it handles quite well right now. I'm as fast if not faster than some of the other modern cars running the same class right now.
Problem is... I forgot i stripped the screws holding the centre bulkhead so many years ago. I've reordered the parts but would really like to change the entire system if possible. I hated this system as the screws were smaller than the norm and it was quite easy to strip them.
I prefer the system on the current bd9 which uses the upper deck to hold the bearings in place. I also dont mind the bd5 system which is held by two larger screws that have nothing to do with the rotating spur mechanism.
Is there an alternative to the 2012 bd7 system? Did the newer bd7s change this up and if so would they fit my car? What about after market solutions? Or can i get the bd7 rs versions... Would they help?
Thanks for any help provided. Much appreciated. I will post a pic to show what is on my current car.
tak4 is offline
Old 02-17-2020, 09:58 AM
  #7542
Does anyone happen to have a set of BD7 SLF long shocks laying around they'd be willing to sell?
Blarson1 is offline
Old 02-19-2020, 10:10 AM
  #7543
Default Set up sheets
Does anyone have set sheet for bd8
Junior8869 is offline
Old 02-23-2020, 06:26 AM
  #7544
duckman996's Avatar
I should have some. Where are you located?
duckman996 is offline
Old 06-22-2020, 06:34 PM
  #7545
tak4's Avatar
Hello beautiful people. How are you all doing? My lhs has run out of bd7 parts and I'm wondering if anyone here knows where to get parts for the car online.
Mine is the blue 2012 edition of the car. It is still running great and all but am down to my last pair of arms and knuckles. Any help or suggestion is greatly appreciated... I would ask if anyone is willing to part with their bd7s here but Im probably located on the other side of the world from most of Rctech users.
Advanced thanks for all info provided. Here is my car hehehe.
tak4 is offline
