Old 03-03-2005, 07:10 AM   #1
M.J
M.J's Avatar
Exclamation Acceleration problem!!
Hey guys
i am having a real problem with my car i am running a 9 single motor with a cyclone speedie. 16 tooth pinion as said in my manual and a 98 spur. with a JR xs3
When i accelerate it takes a long time to reach top speed unlike my other motors.
Any know how i can fix my problem????????????????????????????????????
M.J
M.J is offline   Reply With Quote
Old 03-03-2005, 07:47 AM   #2
Joel Lagace's Avatar
The manual is only a starting point, u may need to drop a tooth or 2 still to get what u need. I find that manuals suggested ratios are way off for the racing i do. What size track do u run on?
-Is the motor brand new? Is the timing set right?
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 03-03-2005, 09:58 AM   #3
thecrow2k's Avatar
19/98 is low imo, however ive never ran a low turn motor, maybe try going up a tooth or 2
thecrow2k is offline   Reply With Quote
Old 03-03-2005, 10:03 AM   #4
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
First, what car are you running and what kind of motor is it? Is it new? How many runs are on it? Have you cut the comm? How old are the brushes? Can't figure out what gearing you're running without knowing the internal ratio of the car first.
Jon Kerr is offline   Reply With Quote
Old 03-03-2005, 03:21 PM   #5
MadMikeB's Avatar
The manual is just a very broad approximation for gearing. I know on my T4 if I run my V2 12x1 with the gearing suggested in the manual it will come in totally cooking - the motor spray would just boil off the motor plate, and I generally need at least 2 teeth on the pin LESS than the manual.
If acceleration seems sluggish and you've ruled the motor, I guess some other electronic things should be checked: maybe you changed the punch setting on the speedie, or have you been playing with throttle expo on the Tx? Tx throttle EPA OK?
Let us know if you find out what'a happening.
MadMikeB is offline   Reply With Quote
Old 03-03-2005, 04:01 PM   #6
M.J
M.J's Avatar
Ok guys
The motor ios brand new never cut. speed controller works fine all in great condition.
Would i be better off going up or down a couple teeth?????
Please help me
Matt
Old 03-03-2005, 04:05 PM   #7
Jon Kerr's Avatar
Has the motor always been slow? How many runs on it? Low turn mods need to be cut and have new brushes every 1-2 runs normally. You may also want to check the timing on the motor. It would help to know that type of motor it is.
Old 03-03-2005, 04:10 PM   #8
MadMikeB's Avatar
As a general observation if acceleration is sluggish, then drop teeth on the pinion or add teeth on the spur.
Another question, is the motor really hot when you bring it in? If so that is another indication you need to drop some pinion teeth.
MIKE
Old 03-03-2005, 07:23 PM   #9
Jack2's Avatar
may sound dumb but make sure your diffs are nice and fresh and check belts etc. to make sure you haven't got sliping probs. the extra poke of a 9 turn may cause some probs. I run 8x1-7x1 V2's and they dont need to be cut that often. so it *shouldn't* be that
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Old 03-03-2005, 07:32 PM   #10
Post
just go up 2 teeth and youll be fine ... still dont know the ratio of your car .but this ahould do well for you .. keep chking the motor for het too ...
Mark Barden .
mb racer is offline   Reply With Quote
Old 03-03-2005, 07:36 PM   #11
Jon Kerr's Avatar
But most other low turn motors will need to be cut that often. Try and run a KR 9x1 more than two runs on a cut and brushes. It'll feel like a 19 turn at best.
Old 03-03-2005, 09:12 PM   #12
Jack2's Avatar
so true. you have to love V2's.
I think 2 teeth on the pinion or adding 5 teeth on the spur should make a huge difference tho
Schumacher Mi4CX
Mugen MTX & MRX
Old 03-03-2005, 10:49 PM   #13
StasI's Avatar
Default batts
what batteries you running??
StasI is offline   Reply With Quote
Old 03-03-2005, 11:55 PM   #14
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Going up 2 teeth will make the problem worse, going down a tooth or 2 would get the car up to top speed faster which seems to be his problem.
Old 03-04-2005, 12:23 AM   #15
maxepower's Avatar
Default Timing a ratio!
Your final gear ratio at the very least should be in the mid 8's and your timing better be advanced by at least 20 degrees or you'll kill the motor!
Just my 2!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
more acceleration, same top speed? streetracer745 Monster Trucks 8 04-14-2007 09:52 PM
car not responding on acceleration uniquexme Electric On-Road 23 05-21-2006 12:06 AM
Acceleration Problem! Adein Nitro On-Road 13 02-25-2005 01:17 PM
problem!! car rumbeling of acceleration murfy Australian Racing 9 10-19-2004 10:26 PM
RS4 Slow Acceleration Everton Nitro On-Road 13 06-21-2004 05:21 PM
