Old 03-02-2005, 08:16 PM   #1
scoobydo's Avatar
Default Eliminating Static Electricity
What do you guys do (if anything) to prevent your EP car from creating a static field?
When I run on asphalt, the car builds such a charge that it becomes a dirt magnet.
I know you can just use compressed air to blow it clean,
but I was wondering if you could do something at the source to reduce the static electricity somewhat?
scoobydo is offline   Reply With Quote
Old 03-02-2005, 08:49 PM   #2
Send a message via AIM to greencactus3
they do have those anti static sprays that work real well for clothes. dunno bout rc tho. is it really static that gets the dirt?
greencactus3 is offline   Reply With Quote
Old 03-02-2005, 09:18 PM   #3
scoobydo's Avatar
What else could it be? The dirt cakes on and stays there. And only on the conductive surfaces.
Sprays would ruin your electronics unles you sprayed the rolling chassis only.
Problem is, the spray would only last a couple of runs and then you would have to do it again.
I also want to figure it out because it would eliminate shorting out of equipment.
Anybody ever try grounding the car somehow?
Old 03-02-2005, 09:23 PM   #4
Soviet's Avatar
I'd say it has more to do with the flux in the solder heating up and becoming sticky when load is applied to our solder joints.
Use denatured alcohol on all your solder joints and you'll notice alot less dirt buildup.
"You don't get hurt racing little cars..."
-Me
Soviet is offline   Reply With Quote
Old 03-02-2005, 09:30 PM   #5
scoobydo's Avatar
Its not just the batteries. The problem is with the chassis and most of the graphite parts. Since graphite is conductive and the charge has nowhere to go, it stays charged and attracts dirt.
Maybe I'm wrong, but what else could it be?
Old 03-02-2005, 09:44 PM   #6
Lebatek's Avatar
Send a message via AIM to Lebatek
Default Static guard
We have used Static Guard for years when static electricity was as issue...
Just spray a light coating on the entire car (enough to coat but not enough to damage electronics...) and you'll notice less build up of dirt or carpet fuzz. An air compressor is handy though to blow off the remainder.
John Lebak
Sponsored by: Team Associated, Reedy, Airtronics, LRP, and Mugen
Lebatek is offline   Reply With Quote
Old 03-02-2005, 09:48 PM   #7
scoobydo's Avatar
Default Re: Static guard
The same kind used for clothes?
Old 03-11-2005, 04:44 PM   #8
jw92656's Avatar
Post Eliminating Static Electricity
There are a couple of posts covering this, but they pertain to the glitching in the radio when dealing with static, or the RF intererence it causes too. CA Glue the edges of the Carbon chassis. This seals the conductive carbon behind the glue thus eliminating the static build up your getting.
jw92656 is offline   Reply With Quote
Eliminating/minimizing Glitch imel24 Electric On-Road 5 03-16-2007 11:40 AM
Questions on Electricity for Parking Lot Racing SlamMan Electric On-Road 13 07-18-2006 05:52 PM
eliminating e-clips BOWTIE1 Electric Off-Road 10 04-23-2005 03:46 PM
Xray Chassis conducting electricity? Rieley Electric On-Road 9 03-17-2005 05:43 PM
Static sag great seller. berwicknitro Buyer/Seller dispute and Feedback discussion forum 0 12-20-2004 07:46 PM
