Old 08-03-2012, 03:57 AM   #46
SlideMasteR's Avatar
I have run a single Speed passion Gt2.0 Pro in mod for 3 years not one sec problems ... and recently tried a Hobbywing V3 both are awesome esc's for mod, so any re-branded variation of these will be good
I personally like the V3 as it has more fine tuning options and has the data logger which helps for squeezing those last few tenths out of a lap
just my opinion, others may disagree
Xray T4 15' - Hobbywing V3.1 ESC - Reedy Modified Motors - Thunder Power Batteries - Protoform - Much More
SlideMasteR is offline   Reply With Quote
Old 08-03-2012, 04:57 AM   #47
Skiddins's Avatar
Originally Posted by 303slowdown View Post
Look at http://rcprogear.com/ it list what wins.
Or at least, it lists what the sponsored drivers have to run
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 08-03-2012, 09:31 AM   #48
Suspended
Smile
Sponsorship is the real reason why , and is also why Novak is used in offroad racing.... That does not make Novak any worst than anybody else, just different for the non followers !!! The Kinetic 2S is good to try without software upgrades for dirt cheap...
bertrandsv87 is online now   Reply With Quote
Old 08-03-2012, 09:52 AM   #49
cwoods34's Avatar
If you ask me, it says none of the fast guys choose to run Novak.... Otherwise they would've sought sponsorship with em, right?
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 08-03-2012, 11:46 AM   #50
Trader Rating: 20 (100%+)
Originally Posted by bertrandsv87 View Post
Also, I've never heard of anybody running a 3.5t with full boost in a six minute race... I have seen 4.5t motors with 20 extra boost , but the speedpassion esc was at 200 after four minutes though....Forget about tekins here...
I don't think anyone needs a 3.5t with full boost. My comments were that I needed to run my 4.5t at full boost on my LRP. I did look at some of the more recent speed passion setup sheets and it looks like most guys are running 4.5t with 26 of boost and some turbo at the bigger tracks so my setup isn't out of line with that.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 08-03-2012, 11:46 AM   #51
Suspended
Smile
Novak esc's are too inexpensive for racers to need sponsorship to run them . Others are way too expensive, and blow up constantly...... You do the Math... I'm not sponsored, and I'll stick with my inexpensive Novaks versus the always changing field of new esc's... They blow so much that you'll need to keep getting newer and newer versions of the same thing just to participate... Meantime some companies are getting rich at your expense ! The only esc I ever blew was a Lrp AI super reverse running a 10t motor in a two wheel drive pan car ... Lrp did send me a new one, but I never used it again !
Old 08-03-2012, 11:54 AM   #52
Suspended
Troy, you mean 26 boost on top of motor timing(30), plus turbo(15) ? 71 of total timing ??? Wow, no wonder their esc's are melting.... I run only 30 motor timing in my 3.5t, at 8.409FDR I think that's enough to keep up with the others ....
Old 08-03-2012, 12:31 PM   #53
DesertRat's Avatar
71 isnt that bad. Remember, at 50k rpm the dynamic 'feel' of the motor isnt like a shorted circuit at all, its more like a capacitor you are charging a discharging over and over, the boost overrides that and forces current through the motor before the rotor can get turned to that point and counteract the induced magnetic field. At 0rpm, 71 degrees would just cause the motor to turn backwards, at 50000, its just part of the game if they have the advance curve right.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. Losi 22 4.0, CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 08-03-2012, 12:31 PM   #54
303slowdown's Avatar
Trader Rating: 24 (100%+)
Ive seen more novaks burn up than any other brand
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 08-03-2012, 12:41 PM   #55
I'm not sure what motor timing they are running on their motors.
Old 08-03-2012, 01:37 PM   #56
2wdrive's Avatar
it's 26 steps of timing not actual degrees.
26 steps is around 13 actual degrees
www.rc-lemans.de
2wdrive is offline   Reply With Quote
Old 08-03-2012, 02:35 PM   #57
Here is a link to one of Rheinards set up sheets. 4.5t, 15 endbell timing, 25 boost, 28 turbo.
Maybe the sheets are wrong but it calls everything out in degrees not steps.
Old 08-03-2012, 03:22 PM   #58
Team Tekin
Tekin Prez's Avatar
Originally Posted by gom View Post
I am new to mod racing. been racing stock 17.5 for awhile.
Just want to know what ESC to get. I would really like one that doesn't require hooking up to a laptop computer to adjust timing/turbo etc.
Which ESCs out there are capable of that and are generally reliable?
Just because this seems to be so misunderstood...
You can adjust boost on the Tekin RS and RSpro right on the unit without a laptop or program box. The onboard programming has 5 preset boost settings from 0deg to 45deg that are very good for almost all setups. The led tree is very easy to understand and adjust.
However if you are going to run a 3.5 fully boosted you will likely need an esc with a heatsink and a fan. RSPro would not be your best choice, but we have something coming that would be
[email protected]
Smarter, Smaller, Faster....
www.teamtekin.com
Tekin Prez is offline   Reply With Quote
Old 08-03-2012, 03:36 PM   #59
2wdrive's Avatar
They call it degrees to not confuse the masses but they are steps. You can add 64 steps in total. They programmed it this way to make the timing more efficient and gradually or something. Tekin uses the same trick.
Go to the hobbywing thread and ask there if you don't believe it. They are the original manufacturer of the speed passion esc and the software is identical to the hobbywing software.
www.rc-lemans.de
Old 08-03-2012, 03:47 PM   #60
Team Tekin
Tekin Prez's Avatar
Our boost and turbo are actual degrees of timing.
Our sensorless timing advance is a percentage 0 to 100% of the 30deg we can advance the timing in sensorless. That is a little confusing... Both go faster when the number is bigger, but they do not compare very well.
[email protected]
www.teamtekin.com
what happened to 1oth scale truck racing? c4coop Electric Off-Road 95 01-22-2012 01:46 PM
Upgraded SC kits - Good or bad for racing? JMYBFFT Electric Off-Road 19 09-10-2010 12:31 PM
just bought a ft b4, new to electric! what motor/esc to get?? iraqsucks Electric Off-Road 17 10-02-2009 12:48 AM
Good LiPo for racing? Chris__RC Electric Off-Road 44 08-03-2008 06:49 PM
