Old 03-07-2005, 12:19 AM   #46
jzone's Avatar
i have to agree, the torque factor got shot out of the water. krazy speed was all good. temp stayed about the same as i geared up, every run
Just to compare some #'s............when I was breaking in the brushes ............at 2 volt's amp draw was avraging 17amps.
Jesse Galang
Northwest R/C Club - VP
OverGeared Racing OG
Team Associated | Reedy | Orca
jzone is offline   Reply With Quote
Old 03-07-2005, 12:47 AM   #47
FW-05RR's Avatar
how good is this motor over the other 19t
FW-05RR is offline   Reply With Quote
Old 03-07-2005, 01:06 AM   #48
jzone's Avatar
i would still take a C2 over any right now, but the dynasty will be a spec motor for the western canadian TCS
Jesse Galang
Old 03-07-2005, 01:13 AM   #49
MYXTYPLYX's Avatar
I second that motion and add specifically the Putnam C2 has been a real terror on the track.
MYXTYPLYX is offline   Reply With Quote
Old 03-07-2005, 02:38 PM   #50
mtveten's Avatar
Trader Rating: 27 (100%+)
Ramil,
I have done extensive testings with every type of brush / brush mod possible and the setups I sent Jesse are by far the best. Just put the Tveten Tweaks on it and you'll be set.
Oh BTW the F setup will be your best bet for GT1 the others are all to shift the powerband for the F1's limited gearing.
Mark
mtveten is offline   Reply With Quote
Old 03-07-2005, 08:19 PM   #51
MYXTYPLYX's Avatar
Originally posted by mtveten
Ramil,
Mark
I haven't gotten any from Jesse. Maybe you can send them over to me so I can do some of my own testing. I've got 2 weeks.
You comming up to run?
Old 03-08-2005, 12:01 AM   #52
jzone's Avatar
All you had to do was ask. I haven't been able to test all set ups. But it should get me in the ball ark
Jesse Galang
Old 03-08-2005, 11:55 AM   #53
mtveten's Avatar
Sounds like Jesse is on top of the motor situation.
Regarding the cloverdale race I am not sure if I will be able to make it or not, I should know more by monday.
Please PM the event schedule.
Thanks,
Mark
Old 03-08-2005, 12:29 PM   #54
rc-zombies's Avatar
I have the pubman C2...anybody try it with the V2 conversion kit?
Old 03-08-2005, 06:32 PM   #55
MYXTYPLYX's Avatar
You do mean Putnam right?
The V2 conversion will only allow you to use the brushes mostly desined for mod and therefore has less silver content.
I recommend sticking with the Green brushes for full power or use Green(+), Blue(-) for slightly longer brush life.
Old 03-09-2005, 08:29 PM   #56
jzone's Avatar
From what I've seen with any V2 conversion on a 19t. Is that the efficiency looks better. Sprint brushes, and even the cut sprints. You gotta use the ultra hard springs though. But I don't know if they are available out there. They are harder than the Peak hard springs
Mark, thanks for all your suggestions on the motor tuning. We should start doing bench races on motors in the pits.
hope to see you and pops out for our first TCS next weekend
Jesse Galang
Old 03-09-2005, 08:52 PM   #57
MYXTYPLYX's Avatar
Jess, can you send me that info please?
I wanna have a look at what he's done.
Mark and Pops have to come out. They naver miss any of our races...
Old 03-09-2005, 09:15 PM   #58
jzone's Avatar
u got pm
Jesse Galang
Old 03-10-2005, 03:13 AM   #59
Anytried tried taking down the comm to say 0.28" (7mm)
Due to the small brushes (compared to laydown) it may help a lot. The 19T V2 is really short on RPMs as it is.
vassago is offline   Reply With Quote
Old 03-10-2005, 05:12 PM   #60
jzone's Avatar
The cut brushes work well on them.
As for cutting the com down to a smaller diameter, a gain in rpm would be something you will see most of the time.
Jesse Galang
Peak Dynasty motor differences? MrLosi Electric On-Road 3 09-05-2006 03:31 PM
Peak Dynasty V2 Motor jim beam Australia For Sale/Trade 2 06-02-2006 04:37 PM
F/S: BRAND NEW PEAK Dynasty 19T Spec Motor f2000racer R/C Items: For Sale/Trade 6 12-10-2005 12:58 PM
Peak Dynasty 19T motor D_Ames Electric On-Road 2 12-31-2004 12:07 AM
19T Spec Peak Dynasty motor, no power? Cain Electric Off-Road 4 12-23-2003 08:40 PM
