GM3 Comm problems >
GM3 Comm problems
GM3 Comm problems
Old 08-20-2001, 05:42 PM
  #16
RCTech Member #2
TSR6's Avatar
Jeff - heh... True!
TSR6 is offline
Old 08-20-2001, 06:29 PM
  #17
Moderator
Speedo's Avatar
Cool
I like my GM3 for off-road, cause it seems smoother. For on-road, I like my P2K. AE Racer, yeah, the Fantom P2K's are not bad, I had one that flew!
Speedo is offline
Old 08-20-2001, 06:43 PM
  #18
Anybody run a Rage much? I'd like to get a high RPM motor for my 1/12, but if GM3's are allmost a hazard, I'd like to find another choice. What about the TOP motors? Any of them high RPM? I'm doing allright with a P2K in it, but I really think a higher RPM motor would help.
JeffC is offline
Old 08-20-2001, 06:50 PM
  #19
AE_Racer's Avatar
the Rage is ok, but I still say try another GM3 or get a P2K
AE_Racer is offline
Old 08-20-2001, 06:53 PM
  #20
Right now I've got 4 P2K's, 2 MVP's, and 1 junk GM3. I suppose I could try slotted or cavity brushes in a P2K or MVP to get more RPM... Should probably try that instead.
JeffC is offline
Old 08-20-2001, 07:39 PM
  #21
Trips's Avatar
Trader Rating: 16 (100%+)
I ran a Rage for a good part of last summer. I'd have to agree with others who have said it's a very high revving motor, but it is not very torquey. For a touring car gearing would be critical, but in a 1/12 car I think it would be pretty nice.
My Rage was happiest with BRP Silver Hollow Laydown brushes, and either the springs that came with it or a Trinity Red on pos and Green on neg. For 1/12 I'd probably go with the Red/Green combo.
One thing about the BRP Silver Hollow brushes... You need to really make sure they're fully seated to the comm before they start making power. The usual three to five minute break in won't get the job done. I use a brush contouring tool to face the brush, then a few minutes of break in. Without the contouring tool, you couls spend 10 to 15 minutes breaking those brushes in. On the plus side, one set usually lasts me the life of the motor, unless I go really crazy with the gearing.
Trips
Trips is offline
Old 08-20-2001, 08:49 PM
  #22
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
i love my gm3s....you must be carful when gearing, troys was just bad, cause he was geared like i was, as for fantom, they put out a great product, in our area a trinity pro, and a fantom are the same price, and i would take th fantom every time...
Matt M. is offline
Old 08-20-2001, 08:55 PM
  #23
Moderator
Speedo's Avatar
Cool
I like the fantom P2K's, they rock, but the GM3's, in my experience aren't very good. At least they aren't true to the dyno numbers...
Speedo is offline
Old 08-20-2001, 09:04 PM
  #24
Administrator
Matt M.'s Avatar
why would they be honest with the p2k and not with the gm3....
Matt M. is offline
Old 08-20-2001, 09:07 PM
  #25
RCTech Member #2
TSR6's Avatar
I have no clue why mine went poof... It makes a cool video though! Oh well, another $13 down the drain for a new arm.
TSR6 is offline
Old 08-20-2001, 09:11 PM
  #26
Moderator
Speedo's Avatar
Talking
Hey troy, How can I get the video?
Speedo is offline
Old 08-20-2001, 09:12 PM
  #27
Moderator
Speedo's Avatar
Cool
I think the brushes they put on the P2K are better, cause when I fired up my fantom GM3 with the stock brushes, it was crap. I put some niftech X-cuts on and performance went up alot. Plus, due to the reduced surface area of the X-cuts, the motor doesn't get as hot, and the brushes are softer, for longer comm life.
Speedo
Speedo is offline
Old 08-20-2001, 09:16 PM
  #28
Administrator
Matt M.'s Avatar
they put f315s in the p2k and gm3, which is basically a 767...i found that most of the time my motors run best with those or the team one 4140...so i think you are just mistaken...ha ha
Matt M. is offline
Old 08-20-2001, 09:22 PM
  #29
minicooper's Avatar
Location: Beautiful Downtown L.A. Where the sky is always on fire and the grass is always brown
If the only thing that goes POOOF is the motor then that's cool but your ESC can also go...
A few weekends ago I geared my Banzai GM3 at 85/29 (5.86) on my schumacher axis, the whole time I was waiting for that magic white puuuuffff of smoke. It never happened and I ran it twice back to back. I think that some of the comms just came defective from the factory and you either got a good one or you got the ones that go poof.
BTW, that race was at night on a wide open track
minicooper is offline
Old 08-20-2001, 09:25 PM
  #30
minicooper's Avatar
Speedo
Speedo - how are those x-cuts working out for you?? I tried some but they were breaking and jamming my motors. Are the niftech brushes any good? What kind of power are you getting compared to the other brushes? Thanks
