Old 07-22-2012, 05:03 PM   #1
ground-round's Avatar
Trader Rating: 18 (100%+)
Default TC6.1 Pulls Right -Help
Guys, need some help. Under power, my TC6.1 pulls right pretty severely. After the inital yank to the right, it evens itself out and is driveable.
Spool up front, gear diff in rear with 35wt oil. If it helps, running the "Sean Cochran" Snowbirds setup on carpet, 17.5 blinky.
I'm not a noob, been racing for over 20 years. The car is otherwise mechanically sound, free drivetrain, not tweaked, installed new bearings, CVDs are free and not bent, rebuilt the gear diff between rounds and that didn't even help. Aside from throwing this thing in the trash and starting over, I don't know what to do. I must be overlooking something, but I don't know what it could be. Any ideas?
ground-round is offline   Reply With Quote
Old 07-22-2012, 05:31 PM   #2
Jerz616's Avatar
Trader Rating: 49 (100%+)
I had a similar issue with my X-ray except it was pulling left. it was caused by a bad shock in the right rear which had almost no fluid in it from a blown shock bladder. When I would accelerate it would transfer all the weight to the right rear and kind of lift the left fromt. Maybe worth a shot at looking at your rear shocks.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 07-22-2012, 06:37 PM   #3
You know, that makes perfect sense. And, I was so preoccupied with the drivetrain today, I didn't even think of the shocks! Thanks.
Old 07-22-2012, 06:49 PM   #4
wingracer's Avatar
Trader Rating: 24 (100%+)
Other possibilities, uneven rear toe, uneven droop, servo or receiver glitch.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 07-22-2012, 08:16 PM   #5
Suspended
rcpaintinpete's Avatar
Trader Rating: 16 (100%+)
Could just be that your a jack wagon ahhhhhhhhhhahahahahahahahahahahaha: lol::lo l:
Ok seriously did you get it
TEAM ARC USA --- TEAM POWERS USA ---- TEAM VALKARIA RC ----
rcpaintinpete is offline   Reply With Quote
Old 07-22-2012, 08:33 PM   #6
What kind of servo are u using?
Servo glitch under load maybe?
Mike Dobbs
barnacle is offline   Reply With Quote
Old 07-22-2012, 09:47 PM   #7
Marv's Avatar
Your car is telling you to vote Republican.
Marv is offline   Reply With Quote
Old 07-22-2012, 10:54 PM   #8
Adjust your subtrim
Associated B4 FT +8mm
Associated SC10 4x4
Associated B64D
Losi XXX-SCT
jimmer411 is offline   Reply With Quote
Old 07-22-2012, 11:28 PM   #9
Jochim_18's Avatar
Its just the car I think... It gave me so much problem last reedy race I can't figure out the car pulls on one direction I practically took the whole car apart and it's still the same... Switch to Tamiya 417X problem solve lol... I think the chassis tweaks relatively easy ...
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 07-22-2012, 11:46 PM   #10
sell it to me for $100 then
Associated SC10 4x4
Associated B64D
Losi XXX-SCT
Old 07-23-2012, 05:43 AM   #11
Thanks, Pete! Miss you too, buddy.
Old 07-23-2012, 05:44 AM   #12
Where were you yesterday, Dobbs? Anyway, I thought the same and changed servos too. Does the same with both.
Old 07-23-2012, 06:10 AM   #13
poochy's Avatar
One outdrive is worn out or upperdeck tweak
poochy is offline   Reply With Quote
Old 07-24-2012, 01:00 PM   #14
turbodog's Avatar
G-man, check that outdrive that you're having an issue with the blades!!
Troy Schafer
turbodog is offline   Reply With Quote
Old 07-24-2012, 01:07 PM   #15
samnelso's Avatar
Uneven front droop?
Team Associated | Reedy | Airtronics
RC Excitement: Fitchburg, MA | RC Madness: Enfield, CT | Horsham RC
samnelso is offline   Reply With Quote
New car project TC6-C daleburr Electric On-Road 97 12-04-2012 01:07 PM
