Old 03-01-2005, 12:54 PM   #16
Charlie O's Avatar
Default Re: theoretically
Originally posted by imjonah
"Unless your racing a class where stick packs are required, I would recommend you hard wire your esc to your battery and motor. It will give you more runtime, power, and efficiency. You will have 1 solder joint between the esc and battery. With plugs you have 3 joints. Each joint is robbing you of power and speed."
Also make sure you only use one coat of paint and no decals on your body, the lower weight will really help your lap times.
Also dont charge your packs all the way, just enough to finish the race, all that extra juice is extra weight!
Charlie O is offline   Reply With Quote
Old 03-01-2005, 01:20 PM   #17
Send a message via AIM to greencactus3
Originally posted by Soviet
There is NO ELECTRICAL LOSS that can effect an RC car with Deans plugs.
but other than the normal more solder joints issue, it will most likely make your wires longer. this may or may not matter to sum people i know. but longer wire is added resistance and also more weight. 12gauge wire is no lightweight
greencactus3 is offline   Reply With Quote
Old 03-01-2005, 01:54 PM   #18
ChadCapece's Avatar
If you don't think deans plugs make a difference, then you shouldn't use them b/c you probably can't go for 5 minutes without a wreck. Yes, the advantage is minimal, but everything helps when you and 9 other guys are running lap times within tenths of each other.
ChadCapece is offline   Reply With Quote
Old 03-01-2005, 04:08 PM   #19
Trader Rating: 114 (100%+)
Send a message via AIM to Valentin.H
so i need male plugs on the esc and charger and females on the batt. would ULTRA females fit males? is there a difference?
-valentin
www.csjunkies.com
Valentin.H is offline   Reply With Quote
Old 03-01-2005, 04:10 PM   #20
ms2005fl's Avatar
I found it easier to do direct soder. no dean cilip
ms2005fl is offline   Reply With Quote
Old 03-01-2005, 04:52 PM   #21
naw i wont direct solder,the reason i want to change plugs is because of the TAMIYA plugs....heard they bad bad..so yep. im going deans plugs!
-valentin
www.csjunkies.com
Old 03-01-2005, 05:50 PM   #22
Trader Rating: 28 (100%+)
For indoor carpet racing I direct solder. Why? Because power is abailable at my pit. As for offroad I will run deans plugs. I mostly run gas so don't need to worry about it anyhow. But I'm surely not going to bring a generator just so I can solder my batts. I guess a power converter or 12v solder iron would work. But man I get tired of soldering...
jbrow1 is offline   Reply With Quote
Deans plugs surrealmaterial Australia Wanted to Buy 3 05-21-2007 05:42 AM
WTB- Deans plugs acracer Australia Wanted to Buy 2 10-10-2006 05:08 AM
Deans plugs ProudSavageOwnr Electric On-Road 1 06-21-2006 05:40 AM
deans plugs yokomo7 R/C Items: Wanted to Buy 5 12-06-2004 01:09 PM
deans plugs was ist los? Electric On-Road 23 04-14-2002 11:05 PM
