Old 02-28-2005, 04:25 PM   #1
Default discharge avg voltage??
I have an integy 16x5 with the 20amp discharger. Whats a decent avg. voltage to look for from a pack?? And will discharge amperage change the average voltage??
stumper is offline   Reply With Quote
Old 02-28-2005, 05:19 PM   #2
Yes the discharge amperage will majorly effect the overall adverage voltage you come up with........A 20 amp discharge on my best packs are around 7.40 adv V...........same pack's at 30 amp dis........7.08 adv V....hope this helps.............Joe
1/8 Scale: Tekno EB-48.2... Tekin RX-8 GEN-2 W/2050kv... Airtronix M11-X Radio... HiTec HS-7954SH Servo...
1/10 Scale: Associated B-5(rear motor)...Tekin RSX Gen-2 W/8.5t... Savox SC-1258-TG Servo
Joe B is offline   Reply With Quote
Old 02-28-2005, 05:27 PM   #3
well crap.................All of my packs are at 6.4 and thats even my fairly new packs of Kinetix 1.17's.............. Im thinkin maybe about only 10runs on those packs...... I guess I'll put one of them on the cycle mode tonight and see what happens.
Old 02-28-2005, 06:19 PM   #4
My numbers are from my GFX and also my Quasar pro....they seem to come up with almost identical readings.......even my old practice packs that are 116's are 6.95 after a 20 amp discharge........something's wrong....mabe your integy is off a little.....
Old 02-28-2005, 06:20 PM   #5
also make sure you trey them before the cycle ..to get accurate results
Old 02-28-2005, 07:37 PM   #6
ok thanks for the help.
Old 03-01-2005, 04:35 AM   #7
Cole Trickle's Avatar
Default You cant compare numbers from two different chargers !
Especially not from two different brands. even details such as length of wires, makes a difference. Not to mention the calibration and the internal hardware / software.
Even within the same brand and model, huge differences is quite common. Calibration is the keyword, calibration cost money...
I do have a CDC v6.0B, and with a Fukuyama 1,160-1,165, I get these data:
Charge cap: 3927
Discharge cap: 2969
Average voltage: 6,978
Peak: 9268
IR (discharge): 32
This pack have about 30 runs in it.
So what can you do: Use the numbers only for internal/personal reference. And get an equalizer, that will probably improve the voltage and IR.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 03-01-2005, 07:48 AM   #8
Thanks for your help also !
Old 03-03-2005, 02:33 AM   #9
You could also try to configure your 16x5 for single cell discharge. Then discharge each cell at 20 amps. Then discharge each cell at 1 amp. Maybe do the same at 0,1 amp, to take them down as much as possible. Then completely charge and discharge and note the numbers. If there's an improvement, you need an equalizer.
Ni-mh discharge voltage joe of loath Radio and Electronics 4 01-25-2008 02:31 PM
Orion 3200 Lipo Discharge voltage? ioxqq Electric On-Road 9 12-20-2007 11:36 PM
What does both? Pulse discharge @ 30A and maintain voltage rmdhawaii Electric On-Road 22 08-03-2007 12:14 PM
Voltage goes up during discharge? Iceracer Electric On-Road 8 12-17-2006 09:24 PM
Integy 16x5v6 discharge voltage threshold? Bob Nilsen Electric On-Road 2 04-03-2004 04:12 AM
