Old 07-20-2012, 08:36 AM   #1
Default Gearing FWD TC
Hello, in my FF-03 pro I've installed a tamiya super stock RZ motor 23t and in the instructions the recommended gearing is 6.5-7.5:1. My FDR at the moment is 6.8. I'm having heat issues, so I obviously should drop a pinion size, but because the car is two-wheel direct drive, I should be able to run a lower FDR, right?
I'm running a 26t pinion and 68t spur. What should I aim for?
Thanks!
fwd25 is offline   Reply With Quote
Old 07-20-2012, 08:43 AM   #2
SteveM's Avatar
Trader Rating: 142 (100%+)
When I last ran my FF-03 Pro in my club's GT2 class I ran a 92T spur and 51T pinion. My FDR is 4.69 on the nose and I finished 3rd in the A-main. I used the Speed Passion Citrix "Stock Club Race" 17.5BL motor and ESC combination.I wasn't using a fan as the motor was coming off the track still cool to the touch.
SteveM is offline   Reply With Quote
Old 07-20-2012, 02:22 PM   #3
Thanks!
Those super stock motors can handle a lower FDR then mentioned on the box. I've run the TZ 23T super stock motor (witch i prefer more then the RZ) in my FF-03 PRO and went below 6.0 FDR but that was on a medium outdoor track. The FDR depends on how big the track is, but start a FDR arround 6.0 and go from there.
Cause the more wheelspin you have the less acceleration and more power is lost.
The trick is to find a perfect balance between acceleration and traction.
I've run this year my FF-03 PRO with a tamiya brushed GT Tuned motor against some 14T brushless motors (i was the only one who was using a brushed motor) and managed to finish 2nd overal.
A good car setup with the right FDR is the key to succes.
addicted2blue is offline   Reply With Quote
Old 07-20-2012, 04:05 PM   #4
I've run the Super Stock RZ before and the kit stock gearing for our permanent track make it a bit under-geared.
When you say "hot," are you actually measuring with a temp gun? I've run these things at 180 deg. F with no problems. Unless we're talking temps over 200 deg, I think you are doing fine.
I first gear the car so that it keeps accelerating up to the 2/3 point of the longest straight. Then I make a compromise on whether I'm giving up too much acceleration on the other turns on the in-field of the track.
My opinion on using a taller gear ratio to tame wheelspin is you are giving up too much on acceleration and your motor just can't spin up as well.
Adjust the expo on your radio so that initial throttle tip-in is gentler. At a certain expo setting, the throttle curve feels too unnatural and that is when I go to the initial current settings on the ESC.
TwoWheel is offline   Reply With Quote
TC race at Hot Shot MCSEDanny Georgia Racing 283 05-10-2012 08:14 AM
MNC EP 2012 (TC) - Sekadar meminta pandangan shahrin Malaysian R/C Racers 109 02-07-2012 09:11 AM
FWD TC Class - which direction and rules? cannon Australian Racing 141 09-21-2011 07:52 AM
FWD TC CARS - what are the possibilities cannon Australian Racing 25 06-28-2010 08:11 AM
