Old 02-28-2005, 08:22 AM   #1
No oneway in front at the TRF 415MS?
I bought a brand new TRF 415MS.
In front has one way diff. Simple:
When I want to stop and use brakes only the rear part stops.
Is there a way that i can make it as a usual 4WD car?
Capone_GR is offline   Reply With Quote
Old 02-28-2005, 08:28 AM   #2
RCGaryK's Avatar
search the 415 thread, there's an assembly procces along with a parts list in one of the regular's signature. A lot of people have used it successfully. Good luck.
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 02-28-2005, 08:34 AM   #3
RCGaryK's Avatar
Found it for you, here you go, thanks to forty6 for posting this in his sig:
TRF415 Front Diff Parts (TRF415 Thread's Most FAQ)
YOKOMO ZS-501 Diff Joints
YOKOMO ZS-506 Diff Rings
YOKOMO ZS-507 Diff Thrust Bearing Set
YOKOMO ZS-508 Diff Adjusting Kit
YOKOMO ZC-S100 Shim Kit (10.0mm diam) 20 pieces
(2) 5x8mm bearings
TAMIYA 51055 415 Diff Pulley
TAMIYA 53379 3mm Lighweight Diff ball set or any 3mm diff ball
TAMIYA 53708 Tamiya TRF415 Center Direct Pulley
TAMIYA 51092 Tamiya EVO IV 46mm Swing Shaft (old suspension)
HorizonHobby.Com
Old 02-28-2005, 08:36 AM   #4
pookat's Avatar
Look in the 415 thread, forty six has the part list required to make a front diff as his signature.
Also you can buy a spool from speedtech.
Whatever you do, if you want 4 wheel braking you'll need a solid layshaft.
pookat is offline   Reply With Quote
Old 02-28-2005, 08:43 AM   #5
pookat's Avatar
Beat me to it, thats what happens when you work and surf at the same time!
Old 02-28-2005, 08:47 AM   #6
RCGaryK's Avatar
HorizonHobby.Com
Old 02-28-2005, 09:27 AM   #7
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
According to Tamiya USA - they (USA) is working on releasing a front diff for the 415...
The also list the parts and "directions" for assembling a front diff on the 415 - it under the new TRF Racing page
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 02-28-2005, 11:53 AM   #8
Well i have job to do.
Start searching for parts...
Thank you all!!!
Old 03-22-2005, 04:31 PM   #9
Does anyone has bought the Yokomo stuff on-line?
Mi2 front Oneway Roberto Falcon R/C Items: For Sale/Trade 7 05-17-2006 06:56 PM
wanted front oneway TNT racing R/C Items: Wanted to Buy 1 05-10-2006 07:41 PM
wtb: tc3/tc4 hd front oneway trilerian R/C Items: Wanted to Buy 0 01-18-2006 06:20 PM
XXX-S front oneway T Stephens R/C Items: For Sale/Trade 4 04-07-2005 10:55 AM
Diff Vs Oneway in front Jimmeke Nitro On-Road 0 06-27-2004 06:08 PM
