Old 07-19-2012, 12:58 PM   #1
Default Good motor to Boost class 17.5T
Looking for a good engine 17.5t.
I'm thinking of Dualsky Z5 17.5t
Is this a good choice?
Currently, I ride on Robitronic Platinum 17.5t and is not very fast.
Thank you in advance for your help and sorry for my english
J. Kłapacz is offline   Reply With Quote
Old 07-19-2012, 02:02 PM   #2
locked's Avatar
The ESC and it's settings make far more of a difference than the motor choice in boosted classes.
I've used Speed Passion v3, Tekin redline, Trinity Duo2, Duo3 and ReVtech motors in boosted classes and they all worked quite well. None of them really stand out as being a lot faster than the rest.
Motor choice makes a big difference in blinky, but not nearly as much in boosted.
Post which ESC you have and it's current boost settings, as well as your FDR, endbell timing and the track size you race on.
How hot is your motor after a race?
Maybe someone can help you find the extra speed you are looking for without having to change motors.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 07-19-2012, 02:12 PM   #3
samnelso's Avatar
Originally Posted by J. Kłapacz View Post
Dualsky Z5 17.5t
This is a new brand to me here in the States. Can't recall hearing of it before.
Team Associated | Reedy | Airtronics
RC Excitement: Fitchburg, MA | RC Madness: Enfield, CT | Horsham RC
samnelso is offline   Reply With Quote
Old 07-19-2012, 08:31 PM   #4
TeamWTF's Avatar
Speedpassion V3 series motors (1 cell, MMM, regular all work well)
Trinity Duo3
As said, ESC and settings make a bigger difference, along with have a decent cooling fan blowing some SERIOUS air directly onto the motor.
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 07-20-2012, 02:13 AM   #5
My equipment is:
ESC: Tekin RS
Motor: Robitronic Platinum 17.5t
Battery: Life 30c (Do not use lipo)
I have these settings:
Ratio 4.6
Boost 27
Turbo 20 (max)
Start RPM 1750
These are my last set of fast track asphalt
The best driver on the track the engine uses GM 17.5T
I have a 30mm cooling fan, and after the run in a very hot day I had a temperature of about 76 degrees Celsius
Old 07-20-2012, 02:24 AM   #6
Ciao Klapacz,
i'm not a tekin esc user, but according my experience with other esc (hobby wing, viper, team wave) the starting point of the turbo at 1750 rpm seem to low, usually i set it from 3000 to 4000 rpm, according track condition and layout.
Ciao
Max
Touring: WRC STX
F1: WRC F-ONE 200 and 180 mm
ESC:Viper VTX10R; Motor: too many; Radio: Sanwa MT4
Don't follow me.... at the end of the straight there is the hairpin and my wall.....
mtaddei is offline   Reply With Quote
Old 07-21-2012, 07:57 AM   #7
jsr555's Avatar
Trader Rating: 17 (100%+)
My equipment is:
ESC: Tekin RS
Ratio 4.6
Boost 27
Turbo 20 (max)
Start RPM 1750
You should check out the tekin RS thread if you haven't already.
By final ratio if you mean FDR, that seems high unless your track is very big and fast. I was running 6.5 on a free flowing track with about a 70-80 ft straight. I would also lower the turbo, but increase the boost. Did you have any timming on the motor?
Xray T4 & HPI/HB Pro 5 - Powered by Hobbywing
SQ: HPI RS Pro -HPI RS Pro 2 - HPI Pro 3 - HPI Pro ?? - HPI Pro 5
jsr555 is offline   Reply With Quote
Old 07-21-2012, 12:28 PM   #8
I was on the motor set timing 4.5 max is 6.5
Old 07-22-2012, 12:35 AM   #9
vivo quevas's Avatar
Trader Rating: 18 (100%+)
I ran a LRP 17.5 they take heat and you can gear them low and go real fast. Our club band boosted after I started running one last week!
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 07-22-2012, 03:19 AM   #10
Danielson2's Avatar
My Sons Xray was set with a 4.9 fdr, prior to using the boosted software. After I put the boosted software into the esc the car was slower with around 48 degrees of total boost and turbo timing.
I changed the pinion from a 29 down to a 24 giving a 5.95 fdr and it was heaps faster. The other thing maybe your battery but I would try ratios first.
Dan
Xray XB4, Mugen MBX6 Eco.
Danielson2 is offline   Reply With Quote
Old 07-22-2012, 03:26 AM   #11
jsr555's Avatar
I have sent you a PM.
Old 07-22-2012, 09:24 AM   #12
Dan
Our track has 80' straight and is twisty I had my geared 27/115 fdr of 715 the car was very fast. My temps were good for 95* degree track I had temps of 140*on my LRP motor with no fan. I too race a Xray.
I took the boost/timing out an re-geared 43/104 the car was very slow feeling in testing the next day and the temps went wild 200* but the track was 115*. I decided to stop testing and just try it friday night at the races and see what happens! No more 17.5 boosted unledd you want to run in open.
Old 05-03-2013, 03:30 AM   #13
Hi! Can somebody helm with my brushless system? I use Reventon Pro with Team Epic D3.5 17.5T on my TC6 in a boosted class and I can`t choose optimal settings. I`m using final gear ratio 6.4. Help me please to set up my system for medium long tracks (40-60m). What I must to do? Mayebe I must change my gear ratio, or something else?
Motor heat is in range 80-95 degrees Celsius. Track temp around 30-40 degrees Celsius.
With regards!
Catharsis_UA is offline   Reply With Quote
Old 05-03-2013, 01:44 PM   #14
rangerjkb's Avatar
Trader Rating: 40 (100%+)
Send a message via MSN to rangerjkb
+1 on checking out the www.teamtekin.com homepage for recommended esc setups. I've used the following on a large open asphalt track with a 120' straight. Recommend making adjustments to Boost, Turbo, and End RPM (possibly lowering Turbo and End RPM a few thousand) to meet your track conditions if using on a smaller track. Software: v223, FDR: 6.6, Endbell timing: 0*, Current limiter: 95, Throttle Prof: 3, Boost: 45, Turbo: 10, Turbo Delay: 0.16, Start RPM: 3095, End RPM: 17,993, Ramp rate: 2.0 Not familiar with your motor, but it should be able to run quickly. I preffer Murfdogg Synergy Motors, especially in boosted applications. Hope this helps get you close and periodically check temps (1-2 min) during your first test run trying new setups so you don't overheat your electronics.
Jason Burks
Psycho Cells Racing~Hal's Hobby Warehouse~Murfdogg Products~Avid RC
rangerjkb is offline   Reply With Quote
Old 08-22-2013, 10:01 PM   #15
Hi guys.
Sorry I am new to the racing world, I also want to get myself the right 17.5T motor from the start in this new class. I also race in 21.5T open stock.
Sorry if I am hi jacking this post. By rearing all this posts I still don't know what motor is good or even the best...LOL...
I do have a new Hobby Wing V3.1 that I will be using in this class.
Now I just need to know what motor to get.
I did have a look at the following motors.
Gen2 17.5 Tekin
X20 17.5 LRP
D3.5
MMM 17.5 Speed Pasion.
And reconmondations from all the guys that knows this class. I am running a Mi4LP with a internal ratio of 1.8.
Thanks guys.
SPEEDWHEELS is offline   Reply With Quote
Good 17.5T Brushless motors? nitrous36 Radio and Electronics 58 11-28-2016 10:00 AM
17.5t motor questions elecRC23 Radio and Electronics 33 05-08-2012 04:00 PM
brushed to brushless equivalents Sabin Electric On-Road 24 07-03-2011 11:43 AM
ARCMCC proposal for Offroad Stock Class cannon Australian Racing 384 09-19-2010 05:31 PM
