Old 07-17-2012, 09:01 AM   #16
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
I generally take temps from inside the can, thru ventholes
Outside can temps vary too much, from my experience
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 07-17-2012, 09:29 AM   #17
bvoltz's Avatar
Trader Rating: 44 (100%+)
Originally Posted by wingracer View Post
Remember an ice cube straight out of the freezer WILL be below freezing. Once it's melting, then it should read 0C.
But who cares about the temp of an ice cube or coffee. What matters is accurate temp of the motor so again, boil an old can and check it.
Will do... I just found this information interesting to the settings...
bvoltz is offline   Reply With Quote
Old 07-17-2012, 09:32 AM   #18
bvoltz's Avatar
Yes I do that, but when the temp gauge is not reading correctly it really does not matter to what location you take the temp from... My gauge read via the vent hole 289, and used another temp gauge (Exergen) it was 194... Same spot with in 1 second... So I trying to figure out how to make this freaking temp gauge read a correct temp.
Old 07-17-2012, 09:45 AM   #19
chucko's Avatar
do any of you have a professional solder station.? you can adjust the temp setting wait for your soldering station to heat up and go temp the tip. easy takes two min.
Losi 22, XXX, SCTE 2.0, 8ight E.2.0, B44 and last but not the last a 44 .3, M11 X
rc scoring pro
Track owner & race director.
Crook County Race Course Prineville Oregon.
chucko is offline   Reply With Quote
Old 07-17-2012, 11:57 AM   #20
Does the gauge read a normal ear temp of 98f ?
I've heard this is an excellent way of determining accuracy, as it is a consistent temp
Old 07-17-2012, 02:21 PM   #21
bvoltz's Avatar
Yep. It only has a problem at high temps like 150 and above.
Old 03-05-2013, 04:12 PM   #22
Are you just temping electric motors? If so set it at 77 and just figure in a +/- of maybe 5 deg. Very accurate for our sport.
cottonme173 is offline   Reply With Quote
