Old 05-16-2005, 10:23 PM   #46
Alex C's Avatar
Trader Rating: 50 (100%+)
Default Re: Re: Much More Motor Master Version 3.0 question
Originally posted by litespeed-dom
I own both. There is no comparison. The GFX simply just break the motor in, tell you the amp draw, you set the voltage and time, that's it. The only other thing you can do is to run a lathe.
The MM just pretty much does every of the above plus add a lot more features to it.
One more thing is that you can't adjust voltage while the GFX is breaking a motor in, but you can do that with the MM. For $160, it's a little bit spendy, but I got a used one for a little over $100, and it works perfectly so it's worth it in my mind.
The MM is just trick.
Dom
Thanks Dom for the Info, i am just looking for something more compact rather than my Turbo 35.
on another note Competion Electronics coming out with new firmware to fix motor Voltage adjust. E-mail them to get more information.
Alex Cortez
Thank You to all My Sponsors
Ko Propo USA / RC America - Xray - Hudy / Max Power Engines / VP PowerMaster Fuel / Team Espo - "Lay it down Prop"!!!!
Alex C is offline   Reply With Quote
Old 05-16-2005, 10:29 PM   #47
litespeed-dom's Avatar
Default Re: Re: Re: Much More Motor Master Version 3.0 question
Thanks! I'll do that.
I'm currently using a Futaba CDR-5000 and GFX as chargers, then the MM as motor break-in machine.... I'm hauling just about the 2 biggest chargers out there, thinking about getting a MR cell master to replace the Futaba.
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 05-17-2005, 03:01 AM   #48
sosidge's Avatar
You are aware that the Motor Master doesn't charge batteries? Cell Master is Much-More's charger.
Old 05-17-2005, 03:43 AM   #49
Default TIMING
Hi Guys,
I am testing the same modified motor at different timing settings and I am wondering how to interpret the readings to find the best timing setting?
Is the best setting at the point where you get most RPM per Amp drawn, or should you look to get a set Amp draw from the motor?
Obviously the more timing - the more RPM I get but also more Amp draw.
Help!
crangon is offline   Reply With Quote
Old 05-17-2005, 06:04 AM   #50
Default Re: TIMING
Originally posted by crangon
Hi Guys,
Help!
I'd be carful with a mod motor the MM is only good for 20 amps!
Hyper1 is offline   Reply With Quote
Old 05-17-2005, 06:13 AM   #51
Default Re: Re: Re: Re: Much More Motor Master Version 3.0 question
Dom
I'd probably replace the GFX before the Futaba,I have two gfx's,the only downside to the Futaba is it doesn't have a motor run feaure,but if you have a mm you won't need it,the MM and the Futaba is a killer combo.
Old 05-17-2005, 08:06 AM   #52
any help you can give me though?
Old 05-17-2005, 09:20 AM   #53
Actually my 8T mods draw less amp then stock motors (if the stock motors haven't been "tuned"), I went 6v on the motor run with a 8X1, didn't trip the MM to go offline.
Dom
Old 05-17-2005, 03:41 PM   #54
Arun's Avatar
Yes, low turn mods are no problem for the motor master.
Running a mod in 6 cell CTX mode will get you a lot of attention in the pits !
http://nexusracing.com
Arun is offline   Reply With Quote
Old 05-17-2005, 04:19 PM   #55
Yeah, do that just to psych people out!
Dom
Old 05-17-2005, 05:31 PM   #56
Regional Moderator
kumpol's Avatar
Thumbs up
Especially, more attention when running DC motor with CTX mode!!!
kumpol is offline   Reply With Quote
Old 05-31-2005, 01:39 AM   #57
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
Got a few questions....
Looking at getting a Team Orion Motor Performance Monitor and I believe it doesn't have the "quick test" function. What is the value of that function??
Also... is it okay to run 7-8-9 turn Mod Motors (including DC Motors, haha) on this? I ask just cause i don't want it to cut off my power supply or blow a fuse or something.
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 05-31-2005, 02:26 AM   #58
centax error!'s Avatar
I have tested a 6x1 V2 using CTX test with a 24 amp power supply with no problems at all, but only once though as I was worried I'm gonna fry something inside. And Oh, you will love the sound when the motor screams!!! weeeeeeeeeeeeee!!!!!!
centax error! is offline   Reply With Quote
Old 05-31-2005, 02:29 AM   #59
F. Alonso's Avatar
I just want to make sure that the Orion version will do the same thats all. I think it will, but with all the varying versions of motor masters, its all become a little confusing.
Simon Feigl
Old 05-31-2005, 05:33 AM   #60
MrRolla's Avatar
Trader Rating: 29 (100%+)
I wouldnt be running any low turn motor on the checker constantly, i have hheard a few stories of motors throwing a wind..
Plus free reving them with no load doesnt do them any favours either!!
Simon,
To be honest i have never used the quick test function on the motor master
MrRolla is offline   Reply With Quote
FS/FT: TEAM MUCH MORE Motor Master & Cell Master litespeed-dom R/C Items: For Sale/Trade 15 06-15-2006 08:44 PM
Much More Racing Motor Master hierog Electric On-Road 4 04-15-2006 01:44 PM
Much More Racing Motor Master Surikarn V3.0C DougC R/C Items: For Sale/Trade 8 03-20-2006 10:38 AM
Team Much More Racing CTX Cell Master and CTX Motor Master letitroll R/C Items: For Sale/Trade 7 11-18-2005 11:25 AM
Much-More Racing Surikarn Motor Master motoazure R/C Items: For Sale/Trade 3 05-28-2005 09:55 AM
