Old 05-09-2005, 02:44 PM   #31
AlanLim's Avatar
My best Monster pulls 10.5, 10.3, 10.2, 9.5, 8.9, 8.1 with 37,328 rpm on CTX mode.
AlanLim is offline   Reply With Quote
Old 05-09-2005, 06:14 PM   #32
What setup are you running on that motor mate? springs brush cuts etc?
Thanks Ricky
I would post readings but everyone is in bed here its 1.14am!!
prodriver is offline   Reply With Quote
Old 05-10-2005, 11:00 AM   #33
AlanLim's Avatar
Thanks Ricky
I have 240g spring for positive and 210g for neg.
F brushes with vert. slot on both.
Old 05-10-2005, 11:57 AM   #34
MrRolla's Avatar
Trader Rating: 29 (100%+)
I spun up my 2 new Roar stocks on the MM the other week, best results out of both was 41,170 @ 16 amps. dam that thing was quick..
The other day my mate pointed put that if you use the motor run feature, and put the liitle cap on the motor and stick it in you can see what revs and amp draw your motor is pulling at what ever voltage your using..
I have had the damn thing for 6 months and my mate who doesnt have one pointed that out
MrRolla is offline   Reply With Quote
Old 05-12-2005, 05:18 PM   #35
AlanLim's Avatar
Man! how did you make that roar stock to rev at 41,170?
GIVE ME THE SECRET!
Old 05-13-2005, 05:40 AM   #36
C'mon now 41000 for a stock motor?
Hyper1 is offline   Reply With Quote
Old 05-13-2005, 06:34 AM   #37
HI Guys, on a monster stock 40,015rpm drawing 14 amps!!
Purple red springs, 4503 brushes.
Binary 2mag record I have so far is 44,570rpm drawing 16amps!!
red red spring with Putnum brushes and trailing edges off.
This is on the Much more motor checker. These figures have been also checked on my friends one and both motor checkers have the same readings give or take 300rpm
RC
Old 05-13-2005, 08:11 AM   #38
AlanLim's Avatar
RC
Yep, Putnum brushes are great. I have better numbers on my motor master now.
I will check if numbers on motor master and results on the track are relevant.
Old 05-13-2005, 10:01 AM   #39
MrRolla's Avatar
GIVE ME THE SECRET!
You will have to ask Kinetix for the secret, it was straight outta the box from them, the other one i got pulled around 39,000 from memory, very happy with there product!!
Since there are a few guys with these could you post your results for other motors, mine as follows
Best P2K2 34,500 @ 12-14 amps (4499, red/green )
Best monster 35-36,000 @ 10-14 amps ( 4499 purple purple)
There the best i have ever had my motors, i dont seem to have much luck with the Monsters i have had..
Old 05-13-2005, 10:08 AM   #40
Just checked two monsters in CTX 4 cell mode
1- 22000 rpm's with about 12 amps purple and red springs and 767 brushes
2- 20000 rpm's with about 9 amps red and green springs with "F" brushes
Both motors were freshly cut and broken in for 300 secs at 3 volts before testing.
I've got some greeen and blue putnams I will install these later this evening and retest.I seriously doubt I'm going to see 40,000 rpm's though.I will double check my #'s on a TD45,it will tell the real story.
Old 05-16-2005, 07:08 PM   #41
litespeed-dom's Avatar
Just got my motor master in the mail today. Since everyone is happy testing, figure I'll give it a try. Here is The Team Br00d Monster Stock that I wont Regional 11 1/12th stock with. I probably had 3 runs on this same set of brushes.
6-cell mode
14.67 peak amp
36330 peak rpm
4-cell mode
7.84 peak amp
21960 peak rpm
Putnam Greens, tweaked green + and regular green negative.
It's fun to talk about numbers and what not... but at the end....
The Track Is My Dyno!!!
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 05-16-2005, 07:24 PM   #42
Korey Harbke's Avatar
And you had the most motor out of everyone in 1/12 stock!!!!
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 05-16-2005, 08:43 PM   #43
-Korey
Yeah, thanks to TS Tuning!
Dom
Old 05-16-2005, 09:25 PM   #44
Alex C's Avatar
Trader Rating: 50 (100%+)
Default Much More Motor Master Version 3.0 question
Hello,
Looking to purchase a Much More Motor Master Version 3.0 in the near future. Wanted to know about thr pro's and con's compared to my Turbo 35 GFX.
Alex Cortez
Thank You to all My Sponsors
Ko Propo USA / RC America - Xray - Hudy / Max Power Engines / VP PowerMaster Fuel / Team Espo - "Lay it down Prop"!!!!
Alex C is offline   Reply With Quote
Old 05-16-2005, 10:04 PM   #45
Default Re: Much More Motor Master Version 3.0 question
Originally posted by Alex C
Hello,
I own both. There is no comparison. The GFX simply just break the motor in, tell you the amp draw, you set the voltage and time, that's it. The only other thing you can do is to run a lathe.
The MM just pretty much does every of the above plus add a lot more features to it.
One more thing is that you can't adjust voltage while the GFX is breaking a motor in, but you can do that with the MM. For $160, it's a little bit spendy, but I got a used one for a little over $100, and it works perfectly so it's worth it in my mind.
The MM is just trick.
Dom
FS/FT: TEAM MUCH MORE Motor Master & Cell Master litespeed-dom R/C Items: For Sale/Trade 15 06-15-2006 08:44 PM
Much More Racing Motor Master hierog Electric On-Road 4 04-15-2006 01:44 PM
Much More Racing Motor Master Surikarn V3.0C DougC R/C Items: For Sale/Trade 8 03-20-2006 10:38 AM
Team Much More Racing CTX Cell Master and CTX Motor Master letitroll R/C Items: For Sale/Trade 7 11-18-2005 11:25 AM
Much-More Racing Surikarn Motor Master motoazure R/C Items: For Sale/Trade 3 05-28-2005 09:55 AM
