-   -   TC3 brushless diff help (https://www.rctech.net/forum/electric-road/643369-tc3-brushless-diff-help.html)
jesqui4 07-05-2012 10:17 AM
Help please, I've just revived my TC3 that I built back in 2000.
I installed a Velineon 3500kv motor and ESC from a Slash 4x4, everything else is Factory stock.
I've heard the diffs are going to melt soon, I need advice on replacement or diff options that will work. Just for parking lot driving for now.
SteveM 07-05-2012 10:26 AM
I used a solid spool up front and used the steel diff outdrives for the diff in the rear. The plastic type are too fragile.
jesqui4 07-05-2012 10:39 AM
Thanks SteveM, could you list any part numbers for what you've used?
SteveM 07-05-2012 11:26 AM
1) Associated TC3/TC4 Solid Front Axle ASC1703
2) Associated TC3 Steel Differential Assembly ASC3918
jesqui4 07-05-2012 11:38 AM
Thanks a million SteveM
bertrandsv87 07-05-2012 07:24 PM
You will get alot of chatter with the front spool and cvd drives though, but it is the fastest setup.......
jesqui4 07-06-2012 06:06 AM
I'm ok with chatter as long as it wont melt my diffs.
