Old 02-24-2005, 01:52 AM   #1
OleC's Avatar
Default Hypothetical tire question.
Hi,
Lets say I have a very soft tire (e.g. Sorex 20) that I want to use on a relatively high grip carpet track. What kind of insert should I use to prevent overheating as much as possible but at the same time make it driveable?
I.e. what should I look for: Foam insert, moulded insert, much airgap, little airgap, hard insert, soft insert etc.?
Also, would anti roll bars (or a high roll centre) help prevent overheating with less amount of weight being transferred causing less friction?
Regards
OleC is offline   Reply With Quote
Old 02-24-2005, 02:44 AM   #2
Cole Trickle's Avatar
Wink Hypothetic answer
About anti roll bars; I tend to agree that it will help, since the bar will force the inner wheel down during body roll, thus distribute the tire pressure a little more even. But it also a matter of handling. Personally, I like anti roll bars on smooth carpet tracks, because the car / traction feels more consistent.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 02-24-2005, 08:26 AM   #3
OleC's Avatar
Default Re: Hypothetic answer
My thoughts exactly!
I was planning on testing a couple of ideas over the weekend but I want to make sure that Iíve ruled out any (relatively) obvious things I havenít thought about.
Any thoughtís on the inserts anybody?
Old 02-24-2005, 09:10 AM   #4
TRF415boy's Avatar
Little air gap, hard insert. The problem won't be overheating, but mainly grip roll. In that case, don't use additive on the front and put glue onto the sidewalls of the front tires (outside sidewall, up to and including the corner of the tire).
TRF415boy is offline   Reply With Quote
Tire Question. OG RC 10T Electric Off-Road 6 01-02-2008 11:11 AM
Tire question. rc_freak Nitro On-Road 4 11-28-2007 03:26 PM
4 WD tire question Michal101 Electric Off-Road 23 04-29-2007 06:01 AM
Tire Question RedBullRacin Rookie Zone 2 01-31-2004 01:54 AM
tire question zachzachz Rookie Zone 12 08-20-2003 02:21 PM
