HPI E10 clicking sound... >
Old 07-04-2012, 11:12 PM
<<<MAD>>>'s Avatar
Default HPI E10 clicking sound...
Hey guys,
I have a HPI E10 Drift and i changed it to a touring by putting the transmission back and installing a new set of wheels, and since then a clicking sound is coming from the back, i con't find where it is coming from.The sound is coming only when the car is on the ground,when there is no weight(when it is lifted) its not coming. So i am seeking for some help from you guys, couz i am getting ready for my first rc event... so help me find the problem.. and here is a video of it..
Help me
<<<MAD>>> is offline
Old 07-04-2012, 11:15 PM
<<<MAD>>>'s Avatar
here is the video..
youtu.be/F9eFPtZGL_U
Old 07-05-2012, 03:36 PM
your video link is not working
momogt is offline
Old 07-05-2012, 03:43 PM
Marv's Avatar
He can't post URLs yet - try this
Marv is offline
Old 07-05-2012, 06:22 PM
narcotiks's Avatar
Could be one of the drive shafts, or the rear of the chassis hitting the ground when under acceleration
Or just vibration and loose fitting stuff cause it's not a high end chassis
narcotiks is offline
Old 07-05-2012, 11:30 PM
Dinukap4's Avatar
Bump to you mate!
Dinukap4 is offline
Old 07-06-2012, 07:43 AM
<<<MAD>>>'s Avatar
its not the drive shafts or the rear hitting the ground, nt sure if its couz of the vibration...
try copy pasting the link
Old 07-06-2012, 07:44 AM
<<<MAD>>>'s Avatar
when i install drift tires, the sound isn't coming.. only on touring wheels.. :/
Old 07-06-2012, 07:37 PM
The e10 has a plastic pinion gear that runs on the metal ring gear of the diff I have found this gear with strip just enough to cause that problem.
bgrick is offline
Old 07-09-2012, 10:02 AM
<<<MAD>>>'s Avatar
its the diff that has been making the sound, but i can't find what is making the sound inside the diff.. :/ the gears look fine as well.
Old 07-09-2012, 10:24 AM
SteveM's Avatar
Trader Rating: 148 (100%+)
If the clicking stops with different rims, then it's likely that the sedan rims have some ribbing inside that is touching a camber link or some other part of the suspension causing the sound. Drift rimes often have a +2 or more offset that moves the rim further from the chassis to widen the stance and eliminates the rubbing.
SteveM is offline
Old 07-09-2012, 07:20 PM
<<<MAD>>>'s Avatar
its not the rims for sure.. i tired almost all the touring wheels i can get.. but still the sound is coming.. and i even checked if anything is rubbing as well..
Old 07-12-2012, 11:06 AM
<<<MAD>>>'s Avatar
Unhappy
The problem is the part number hpi 88000. The plastic gear has stripped :/ and i can't find a upgrade for that :/ some help
Old 07-12-2012, 11:21 AM
SteveM's Avatar
Lots of these parts on eBay.
SteveM is offline
