Old 02-23-2005, 03:47 PM   #1
dado11g's Avatar
Send a message via ICQ to dado11g Send a message via AIM to dado11g Send a message via Yahoo to dado11g
Default ORION V2 motor questions
i have a standard blue endbell version 9x1 v2 motor. i use it in my xray and i was told that a hara edition would be faster for onroad. is that true? and why? also what brushes and springs do you guys use?
thanks
marshalv.
dado11g is offline   Reply With Quote
Old 02-23-2005, 04:18 PM   #2
The Hara edition (purple endbell) is wound on a 4mm armature blank......which lends itself a little more twords 6 cell touring car racing to a certain extent........your 9 turn "modified" version ,(blue endbell) is wound on a 5mm armature blank which is known more as a torque blank.....the recomendation from orion is that for anything "under" a 9 turn thats going in a touring car with 6 cells .....get the modified (blue version).........9 turns and above....get the touring version (black endbell) which is also wound on the 4mm blank.......just like the hara and (I Believe) the Juka edition......and Ive always had the best luck with the (peak or orion)hard springs and sprint brushes.........Joe
1/8 Scale: Tekno EB-48.2... Tekin RX-8 GEN-2 W/2050kv... Airtronix M11-X Radio... HiTec HS-7954SH Servo...
1/10 Scale: Associated B-5(rear motor)...Tekin RSX Gen-2 W/8.5t... Savox SC-1258-TG Servo
Joe B is offline   Reply With Quote
Old 02-23-2005, 05:19 PM   #3
Thraex's Avatar
- The Hara edition has A 3,5mm Core.
(with Power (sprint) brushes, max. RPM and great Punch, but
isn't that efficient)
- The Touring (black) edition has A 4mm Core,
(with Longlife brushes, lot of RPM and A good punch which is
needed for 4wd tourers)
- The Steenari edition has A 4,5mm Core,
(with Power (sprint) brushes, good Torque and RPM and very
efficient)
- The Modified (blue) edition has A 5mm Core.
(with Longlife brushes, max. Torque and A wide Powerband)
Thijs van M[HPI/HB]
Thraex is offline   Reply With Quote
Old 02-23-2005, 06:19 PM   #4
Thanks for the correction for the Hara and the Jukka versions blank sizes.......I always went by the orion website it says Blue 5mm...and....purple ......black.....and green.......as 4mm blanks........very missleading.........
Old 02-23-2005, 06:34 PM   #5
Yea I double checked the site........blue5mm........touring (black 4mm).....(hara purple4mm) and (green Jukka version 4mm)
Old 02-23-2005, 06:34 PM   #6
unless something changed since Rick Howart's response to the question....
orion wasp .28/dynamite 26 questions triggerman101 Nitro Off-Road 1 08-06-2008 09:11 AM
Team Orion Lipo Questions? 008-Racer Radio and Electronics 3 02-04-2008 01:48 PM
Team Orion Core Stock 27t Motor Questions pro4x Electric On-Road 7 09-10-2005 02:52 PM
team orion battery questions hurley081182 Electric On-Road 1 06-28-2005 04:14 PM
orion 3300 RDS questions mcc-bri Electric On-Road 21 12-03-2004 07:20 AM
