tires with glue? Should I dump it?
Hi. I accidentally put some CA glue on a tire. I put some debonder but it already had stuck nicely to the tire. Should I trash the tire? The glued tire surface is very glazy and slippery. Another thought is if I keep using the tire, would it eventually wear off? I appreciate experienced comments.
If you are going to race it, its trash.
It the spot is small it will do for some funride/practice.
It will be there until the rest of the tire is worn out probably.
You could cover it entirely with CA glue and when you have four tires you could use it for drifting.
short version: trash
Tarmac or carpet might play a difference.
You can easily sand it off by hand, or just wear it off.
tire truer is the best way. Just take a thin slice, it will come off and leave a nice truer tire.
