zapped???
hey guyz, what is zapped? the fukuyama power cubeon speedtech batts are zapped, what does that mean? which one is better?
Initial cell Zapping (usually done only once) is a process that can inhance the cells ability to have good power output......
Simplified version:
Initial zapping is the process of using a capacitor to push 100+ volts through the cell. This will increase the voltage output of the cell. Maintenance zapping uses a lower voltage, 0-90 volts. This will break up any crystals that have formed inside the cell, increasing voltage of the cell and lowering its internal resistance giving you more punch. |
alright thanks guys, so now im sure of buying taht power cube on speed tech when teh next shipment comes in. and as i can see, anything that is out of stock in any store must be good.
