Old 04-23-2005, 12:12 PM   #1396
SpeedTech's Avatar
Originally posted by Randy Caster
Rayspeed has CVD's, and Yokomo also has another kind of universal that comes assembled. I really dont think there is anything wrong with the stock CVA's as I've never had a problem with them.
the universal design like the hardened universals (ZS-010FH for example) also works better with running a spool. For the BD, we might have to experiment with ZS-010RH since the dogbone sits in the middle of the outdrive and not towards the edge like the MR-4TCSD, so the ZS-010FH will be too long (but ZS-010RH is shorter so it might work)
Also, Tamiya anti-wear grease helps tremendously with universals when running spool
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 04-23-2005, 12:50 PM   #1397
Matt Howard's Avatar
Steve, if you planning on trying rear universals up front it won't work, the bearing spacing is different front to rear in the hubs.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 04-23-2005, 05:15 PM   #1398
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by ghoppa
where did you get it????
or is it a "locked" diff (for right now....)
I just JB welded my 1 way for now... but look at my attachment
Old 04-23-2005, 05:18 PM   #1399
And the regular front universals are too long even if the end where it meets the 1 way is shaved down?
Old 04-23-2005, 05:44 PM   #1400
Rob Phillips's Avatar
It's offical. I am the proud new owner of a BD.
You guys just starting with the stock setup for carpet? I may put in a diff in the front instead of the one way.
Steve, any word on when yokomo will have the locked center shaft/gear/pulley?
Team Durango | TrakPower | DE Racing | Futaba | Restricted Paint Worx
Velocity R/C Magazine - vrcmag.com
Rob Phillips is offline   Reply With Quote
Old 04-23-2005, 05:45 PM   #1401
Are you running foams or rubber tires?
kmorast is offline   Reply With Quote
Old 04-23-2005, 06:05 PM   #1402
ghoppa's Avatar
Trader Rating: 54 (98%+)
dude,
"what's up wit dat????"
when will these bad boyz be available????
let me guess, your buddy who cut out you some of those carbon fiber caster mounts is behind these spools????!!!!!.....
pretty tight, what's the e.t.a. on them????:
R1 Wurks - ActivRC - ApexRC - P1 Brands
ghoppa is offline   Reply With Quote
Old 04-23-2005, 06:26 PM   #1403
dude,
It's actually a buddy in Germany that cut these for me. Problem is, I was origionally told that we could run a SD 1 way, so these are cut for the SD, but from looking at it, I dont know if we can or not. I'm going to test one of them out and see if it works, but if not, there will be some happy SD owners for sure
Old 04-23-2005, 07:11 PM   #1404
Kmorast,
I'm running foams, 19t and 27t for now. I run a DRCW, you run at Mimi's?
Old 04-23-2005, 07:16 PM   #1405
Kmorast,
No I don't run at Mimi's. Would you like a good (I think) starting setup for carpet?
Old 04-23-2005, 08:07 PM   #1406
yeah send it to my email [email protected]
Old 04-23-2005, 08:08 PM   #1407
Sorry I thought you were someone else. I thought I saw your name in the Maryland race thread.
Old 04-23-2005, 09:34 PM   #1408
Last week I ran the hardened front universals in my car and they worked fine. I did have to shave the end down slightly and take out the O ring from the oneway drive cup but I had no problems.
RCTech #361
Old 04-23-2005, 09:58 PM   #1409
SpeedTech's Avatar
*doh*
Thanks Matt!
Steve Wang
Old 04-23-2005, 10:06 PM   #1410
JimmyMac's Avatar
I just ran the car with foams on carpet today in stock class. Did pretty good I think. Very close to the box setup with a few changes...
Front
Diff, half turn out.
Shocks on arm, all the way in.
Shock on tower, second hole in.
AE 40wt
AE Yellow spring
RS#3 piston
60mm shock with no droop screws
0 toe
-1.5 camber
No Swaybar
Rear
AE 30wt
AE Purple spring
RS#3 piston
Center oneway (yes, still using it)
Arms all the way forward (0/4 shims)
2 degree rear toe block
-1.5 camber
No Swaybar
Other
Parma Alfa with stock wing
Epic Roar Stock
100/28
Parma foams (plaid front, purple rear 57mm)
Ride Height 4mmF/4.5mmR
Everything else is kit setting. Car ran great first time out. Very easy to drive. Our layout is fast and flowing. Much like the Snowbirds. Not highly technical like Cleveland. I'm sure I could tweak it even more. But carpet season is now over. Time for some Asphalt BABY!!!
I might run up at Debbies next weekend. A couple of us NC boys are suppose to show up (Brandon M/Steve B/Anthony S). I'm not sure if I will since I'd rather race asphalt. But we'll see. I just don't wanna pay for Roar Membership just for one race. Then again, I plan on racing the Nationals this year in Florida. So maybe I'll see ya Debbies. If not next weekend, maybe sometime later. Say hi to Keith for me...
~Jimmy Mac
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is online now   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
