Old 04-21-2005, 09:53 AM   #1351
pheyhoe's Avatar
R/C Tech Charter Subscriber
I made a slipup when buiding my BD, i finished the car and it seemed really high. i had to lay all of the shocks down as far as possible and move the hub pivot positions to thier lowes to get 5mm ride height. I was confused.. I then realised i had compressed the shocks before putting the spring and retainer on and the small black O-ring was below the spring retainer not on top :P
I didnt think the RAYSPEED retainers fitted very well
Oh yeah.. Has anybody used the small plastic spring retainer at the top of the shock? my springs seem to move around a fair bit at the top....
[SIZE=1][COLOR=navy]Paul Heyhoe[/COLOR][/SIZE]
pheyhoe is offline   Reply With Quote
Old 04-21-2005, 09:53 AM   #1352
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Default Re: Finished my BD yesterday...
Originally posted by Geppetto
The only part of the instructions that wasn't clear, was determining which direction the Spur Gear assembly is supposed to fit into the mount???
Thanks Yokomo!
The spur gear and mounting hub will fit on the right side of the car. You basically want the front belt to freewheel forward.
Old 04-21-2005, 09:57 AM   #1353
Originally posted by Mr. Shookie
Hey Randy,
Maybe you should take it easy on those delrin diffs.... Sheesh.
I have gotten about twenty through it so far and no such wear.
Well maybe because I only ran stock so far, and we're you using the larger bones? I am using the Rayspeed rear bones and there is no real issue with slop. Things seem to work just right.
I am going to focus on the next JBRL race and the KO Gran Prix for now. I think I have a real good base for 4Fun but I have never ran @ Tamyia so if you get a good 19T base setup for there please share.
Thanks in advance,
Stephen <><
I am switching to the lightweight rear bones first, but if I still get wear I'll just take the plunge and get the Rayspeed CVD's. Once I get a setup at SoCal it seems that I can be fast with it on all the asphault tracks, sometimes just dial out a little steering, or throw in a spool. I wont have any 19 turn setups though, but usually my mod setups work awesome with a 19 turn, more steering than they already have.
Old 04-21-2005, 09:59 AM   #1354
I dont think the plastic retainer will help any, it's the Rayspeed springs that are a little oversized. The Yokomo springs will fit on this car with no problem and should be a tighter fit if thats what you want.
Old 04-21-2005, 10:50 AM   #1355
Pulled all the rear suspension to bits and i still cannot find any reason for the 1mm more pre load on one side to the other. I will run it how it is and then go from there. Thanks
Rick Draper is offline   Reply With Quote
Old 04-21-2005, 11:01 AM   #1356
rc-zombies's Avatar
maybe to compensate for the weight of the batteries? the batteries are heavier than the motor and electronics weight put together...
also check the upperdeck...
remove the front/rear bumper
and loosen the upperdeck... hold down flat on setting board and tighten in a criss-cross pattern...
Old 04-21-2005, 08:39 PM   #1357
ghoppa's Avatar
Trader Rating: 54 (98%+)
RocketRon,
you got "PM'ed"
R1 Wurks - ActivRC - ApexRC - P1 Brands
ghoppa is offline   Reply With Quote
Old 04-21-2005, 08:42 PM   #1358
just want to check some info, on the hpi delrin diff halves, use the delrin, hpi diff rings, and assoc bolt and nut, which thrust bearing. and i understand that the hpi slots are slightly bigger the the yok slots in the outdrives, so then maybe the assoc bones will fit these slots. i know there really close to the yok ones
Turtlemaster is offline   Reply With Quote
Old 04-21-2005, 09:31 PM   #1359
rc-zombies's Avatar
I use the yok thrust bearings...
I just tried the TC4 bones in the rear w/ the RS Sd axles... they will not fit... the AE bones are 2mm too long. 50mm long... you'll need to find some 48mm mip bones to work or the original RS mips conversion set.
Old 04-21-2005, 10:43 PM   #1360
I'll let you guys know how the new outdrives work, hopefully I just got a fluke part and the stock stuff will work fine without blowing all this cash on aftermarket junk.
Old 04-22-2005, 09:14 AM   #1361
rc-zombies's Avatar
it's no fun without some aftermarket bling bling...
Old 04-22-2005, 09:49 AM   #1362
Because this car doesnt have enough bling on it stock, right Ramon?
Old 04-22-2005, 10:06 AM   #1363
Mr. Shookie's Avatar
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
YEA We all know the BD is Blingless RIGHT...LOL
Yea Guys Boca now has the ceramics in kit form here is the part number #85-095C-YZ
So glad I sent back those ACER's now.
That part number is for the metal sheilded not the rubber of metal with rubber. I spoke to a rep who asked all the right questions and that part number is for the most free spinning bearings for the BD. You get 22 bearings.
Glad to be a service.
Stephen <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 04-22-2005, 10:09 AM   #1364
Rob Phillips's Avatar
How much are they Shookie?
Team Durango | TrakPower | DE Racing | Futaba | Restricted Paint Worx
Velocity R/C Magazine - vrcmag.com
Rob Phillips is offline   Reply With Quote
Old 04-22-2005, 10:11 AM   #1365
edit.
They are just hard to find on their website.
Here is the link.
http://www.bocabearings.com/main1.as...&n=*85-095C-YZ
If you want rubber seals
http://www.bocabearings.com/main1.as...14&n=*85-095GS
Glad to be a serivce.
Stephen <><
Cost is in the link.
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
