Old 04-19-2005, 05:46 PM   #1306
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by pheyhoe
But at the same time it looks weaker....
i had one on my special that was like that and it broke pretty easily
I'm not really looking at it for strength purpouses, I just like the way the thing looks.
Old 04-19-2005, 05:48 PM   #1307
Glen G -
I took your electronics mount idea and made it out of .020 lexan, seems pretty sturdy, you might want to give it a shot, rather than mounting them right onto CF which could cause glitching problems.
Old 04-19-2005, 06:52 PM   #1308
rc_bam226's Avatar
Hummm, I'll try that also. Randy, nice motor
rc_bam226 is offline   Reply With Quote
Old 04-19-2005, 07:41 PM   #1309
LeoChan's Avatar
Send a message via ICQ to LeoChan
where have this motor to buy ?
LeoChan is offline   Reply With Quote
Old 04-19-2005, 08:25 PM   #1310
JimmyMac's Avatar
EA, how about building the spool to fit Corrally blades?! Less wear and maybe less chatter.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 04-19-2005, 08:27 PM   #1311
The motors should be shipping to the distributor really soon, you guys should see em in a couple weeks or so
Old 04-19-2005, 08:29 PM   #1312
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Spool will be available soon. Will the Corally blades fit the stock CVD pins on the yokomo? If so that wont be a problem at all!!!
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 04-19-2005, 08:56 PM   #1313
rc-zombies's Avatar
The IRS pin cushions will fit the MIP's cvd bones...that will also help reduce wear on the sppols....
Old 04-19-2005, 09:29 PM   #1314
JimmyMac's Avatar
Yeah, the Corrally blades fit the stock Yokomo pins and Tamiya pins as well. But you need to enlarge the diff cup slots to make them fit.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 04-19-2005, 09:41 PM   #1315
Team EAM
Hey Jimmy....Thanks for the info...I'll be sure to get that put it...The caps do tear up but they are a LOT Cheaper than a spool!! That will be in there for sure.
And for that awsome idea I'll send you a free sample when they come in!!
EA
Contact Us
Old 04-19-2005, 11:13 PM   #1316
What material are you going to use for the spool?
Old 04-19-2005, 11:15 PM   #1317
highwayman's Avatar
Ran the BD last sunday... i can definitely say that this car handles like a dream, on a low to medium bite track, my set-up was not that far off... too bad a broken spur forced the car into retirement in the last final heat.
things that i changed in the car from the box set-up ... i ran a short wheel base and softer (blue) springs in front... and lowered the rear roll center by removing the blue spacers .
highwayman is offline   Reply With Quote
Old 04-19-2005, 11:23 PM   #1318
highwayman's Avatar
Originally posted by johnbull
I always leave the little foam out too.
It gives the shocks a more linear feel.
in removing the foam, does the bladder require more maintenance? does it it wear more easily?
... or does the shocks require more rebuilding?
thanks - jason
Old 04-20-2005, 12:12 AM   #1319
JimmyMac's Avatar
Why Thank You EA! hehe.. Let us know as soon as the carpet chassis's are out. Gonna need one for next years Snowbirds..
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 04-20-2005, 01:04 AM   #1320
johnbull's Avatar
thanks - jason
I can't say I've noticed the shocks need any more maintenance.
I normally rebuild my shocks before the start of a season, and don't touch them if they don't leak.
Re Corally blades - Kilruf has it spot on.
johnbull is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
