Old 04-13-2005, 02:55 PM   #1096
Trader Rating: 36 (100%+)
"I will have mine today but I am returning them as I found out that the rubber seals have drag and we all know that is no good for bearings in our hobby. "
I have had several sets of Acer Ceramic bearings and they don't have rubber seals. They call it HSR, whatever that is. I pop them off quite frequently to clean mine and they are some sort of a plastic. When they are installed the outside part locks in the bearing and the inner part doesn't touch anything. They have always been great bearings for me.
EVILGRAFX is offline   Reply With Quote
Old 04-13-2005, 03:47 PM   #1097
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
Sometimes they DO touch the bearings, why, because you can bend the shields. It seems like they have a thin metal ring inside them or something. At any rate when you mass produce something and don't have the time to check every single one, there's bound to be hiccups in the product. Let's face facts... -JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 04-13-2005, 04:59 PM   #1098
Sleighty's Avatar
OH MY GOSH, the car is killer. I'm SOOO jealous; I'd do anything for a BD...anything
Rayspeed Blue. you get them with the kit, the rears are Rayspeed yellow
The Rayspeed springs are to be used with Rayspeed spring retainers.
Yokomo springs work with Rayspeed retainers.
I will post the spring rates later, it only gives you <Soft - Hard> no actual rates.
(posted by pheyhoe) at sleightys house.. lol
A1-RC.com
Team Scream
Xray
Sleighty is offline   Reply With Quote
Old 04-13-2005, 06:58 PM   #1099
berger's Avatar
R/C Tech Charter Subscriber
I have the rayspeed spring figures here from my barracuda, these are correct i think. Ooops, quick edit, those figures are in lb's
Rayspeed Green 13.20
Rayspeed Blue 14.29
Rayspeed Yellow 14.87
Rayspeed White 17.17
Rayspeed Red 18.26
Rayspeed Grey 19.90
berger is offline   Reply With Quote
Old 04-13-2005, 07:15 PM   #1100
Randy Caster's Avatar
Trader Rating: 46 (100%+)
The older shields were made out of that material, the new ones are rubber seals.
Old 04-13-2005, 07:32 PM   #1101
Send a message via AIM to aoizip
wooo hooo... I Got my Manual now....
Thanks steve W
time for me to build them....
quick question...
do you guys still sand and seal the battery slot?
or... just drop the plastic battery tray and call it a day?
~MING
aoizip is offline   Reply With Quote
Old 04-13-2005, 08:06 PM   #1102
You cant even run it without the plastic cell trays I dont think.
Old 04-13-2005, 08:08 PM   #1103
Matt Howard's Avatar
There's no need to sand and seal them since the car uses the battery trays
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 04-13-2005, 08:30 PM   #1104
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
How did you guys attach the cell holders to the chassis? Mine fall out evertime I move the car without a pack in it. Thought about a drop of CA but didnt want to ruin them. I guess that is the ONLY complaint I have about the hole car....and its not a ver big problem!! LOL
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 04-13-2005, 08:37 PM   #1105
I put a small drop of shoe-goo on each corner so they don't fall out. With shoe-goo it will come off easy if I want it to.
RCTech #361
Old 04-13-2005, 08:53 PM   #1106
I just CA glued em in, perminate
Old 04-13-2005, 09:20 PM   #1107
rocketron's Avatar
Trader Rating: 16 (100%+)
i agree with the shoe-goo - easily taken off i just put a small drop inbetween the cell cradle of the two pieces - four drops
rocketron is offline   Reply With Quote
Old 04-13-2005, 09:48 PM   #1108
Team EAM
DOHH...Neve thought of the Shoo goo!! LOL And Ive been doing this how long????
EA
Contact Us
Old 04-13-2005, 10:53 PM   #1109
JDM_DOHC_SiR's Avatar
EA
Come on Eric... just use JB Weld and be done with it
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 04-13-2005, 11:09 PM   #1110
LeoChan's Avatar
Send a message via ICQ to LeoChan
Me too !
before i was change Low rod center & C hub , Rear hub short camber link very like MR 4 TC W ,
now change high STD roll center C hub , Rear hub same is use short but move to out side , will same TCSP 2002 ..
after will madke full shock tower.with more camber hole .
Originally posted by Randy Caster
Since the BD was designed in Japan, and most of the tracks (at least that I have seen pictures of) are wide open and flowing, I realized that the car may actually be too stable for some of the tracks we have here (especially SoCal, with it's tight layouts and constant hairpins) so I made a mount for the rear inner camber links, to mount them outward taking a bit of stability out of the rear end, basically I have the car set up now to where it will rotate very well, but wont necissarely break loose.
I'll post a pic of the one I ran yesterday, but tonight I am going to cut off the stock aluminum ballstud mounts and make a carbon piece that I can make 3 mounting locations on, rather than 2.
I didnt stay to race, just worked on my car and tested all day.
LeoChan is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
