Old 04-13-2005, 05:53 AM   #1081
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Originally posted by chaini
Where did you get that from????
The Acerpage is cool tough
GO back to there site acually purchase a set, then it will ask you which set you want and in the drop down menu it will be there listed as Yokomo BD. I will have mine today but I am returning them as I found out that the rubber seals have drag and we all know that is no good for bearings in our hobby. I will take that $$$$ and either get the Yokomo ones Part # BD-BBC. Or I will get a set of Boca Bearings, I know Bocas cost more but everyone I have talked too including the guys who run 12th and off road all say they are the cats meow. I have a set of Acers in my SD and now I know why my drive train isn't as free as my bone stock BD....Guess you have learn the hard way. I think I will pull them and sell on ebay, then put back the percision ones I have.
One other reason why I think Acers won't work well is normaly you can remove one sheild as to free up the drive train but with the BD the drive train is wide open so you risk damage to the bearings by opening up the sheilds.
Hope I helped.
Randy any suggestions that you found were usefull last night and how did you place in the races?
On the steering rack and the turnbuckles switch to the bottom it looks as if the switch the spacer to the steering arm you would keep the angle so would that still change bump steer?
I was just wondering if it looks to be a good change or should I leave well enough alone.
Thanks for the help guys,
Stephen <><
Also here is the spring rate chart for every kind of spring....very usefull to have printed on the back of your gear ratio chart. Here is both links.
http://www.rcingreece.com/index.asp?...ing_comparison
http://www.gearchart.com/index.cfm?f...n=chart.create
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 04-13-2005, 07:00 AM   #1082
Does anyone have all the dimentions of the bearings used for the BD?
I can make a kit out of Boca bearings just need to know the complete dimentions including thickness. As that is also a needed measurment.
Thanks in advance.
Stephen <><
Old 04-13-2005, 09:15 AM   #1083
chaini's Avatar
Some Pics:
URL: RCWORLD.ch
chaini is offline   Reply With Quote
Old 04-13-2005, 09:17 AM   #1084
chaini's Avatar
Originally posted by Matt Howard
Hey guys, here's a setup from Chris Grainger, a Yokomo factory driver in England.
Front
Drive train - one-way [and center]
Roll-bar - gold
Caster block - 4 plastic high hole
Camber - -1.5
Toe angle - 0
Kick up - 0
Susp spacer - 2 blue washers under each
Steering arm - -1 trailing spacer under
Bladder - std with no foam, use 1 o ring
Body - sss
Shock end - short
Length - 61.5
Spring - white
Oil - 400
Piston - #3 std
Droop - 5 to bottom of caster block
Top link inner - 1mm under ball
Top link outer - king pin
Shock upper - all-in
Shock lower - middle
Susp arm - plastic
W/B - 4-0
Ride height - 5mm
Ackermann - one more forward than std
Rear
Roll-bar - silver
Camber - -1.5
Toe angle inner - 2 new lower
Toe angle outer - 0.5 new alloy
Susp spacer - 0
Body - sss
Shock end - short
Length - 61.5
Spring - blue
Oil - 350
Piston - #3 std
Droop - 4
Top link inner - 0 washers
Top link outer - inside hole, long std ball
Shock upper - 3rd out
Shock lower - outer
Susp arm - plastic
W/B - 2-2
Ride height - 5.5
Body - Dodge 2.0
Additive - Tweak
Motor - check point 8x2
Ratio - 7.50 :1
Wheel - proline 26mm
Insert - Hara gray
Tyre - cs-22
Battery - novak 3300
For what kind of track is this setup?
Old 04-13-2005, 09:21 AM   #1085
Matt Howard's Avatar
an outdoor track, he didn't say which one specifically
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 04-13-2005, 09:22 AM   #1086
rc-zombies's Avatar
I notice one of the car's is using a servo saver....
Old 04-13-2005, 09:24 AM   #1087
I put a kimbrough medium one on mine. It's a bit shorter than the stock servo arm but my servo is too quick as it is.
RCTech #361
Old 04-13-2005, 09:45 AM   #1088
Trader Rating: 35 (100%+)
Default BD Shock Question
I don't know if you guys saw my question, but...
Will the BD shocks work with my full compliment of Yokomo springs, or will I need to purchase a Rayspeed set?
Which Rayspeed springs (colors) are included in the kit?
Are the BD shocks the same as the CGM/SD shocks that I already have?
tanks.
Geppetto is offline   Reply With Quote
Old 04-13-2005, 09:54 AM   #1089
rc-zombies's Avatar
Default Re: BD Shock Question
tanks.
RS Blue and White are included in the Kit. so far the box set-up works great.
BD shocks are the SSS type. I forget what was on the SD...I sold it a long while ago...
don't know about the compatibility with the other Yokomo springs...
Old 04-13-2005, 10:02 AM   #1090
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
The SD also has the SSS shock bodies (the short ones). The Yokomo springs do work without any hiccups, if I'm remembering correctly. If you have both kinds of springs, why not try them out? -JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 04-13-2005, 10:49 AM   #1091
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by Mr. Shookie
Randy any suggestions that you found were usefull last night and how did you place in the races?[/url]
Since the BD was designed in Japan, and most of the tracks (at least that I have seen pictures of) are wide open and flowing, I realized that the car may actually be too stable for some of the tracks we have here (especially SoCal, with it's tight layouts and constant hairpins) so I made a mount for the rear inner camber links, to mount them outward taking a bit of stability out of the rear end, basically I have the car set up now to where it will rotate very well, but wont necissarely break loose.
I'll post a pic of the one I ran yesterday, but tonight I am going to cut off the stock aluminum ballstud mounts and make a carbon piece that I can make 3 mounting locations on, rather than 2.
I didnt stay to race, just worked on my car and tested all day.
Old 04-13-2005, 10:54 AM   #1092
rc-zombies's Avatar
Very nice delrin diff...
I'll have to see if the Pro4 CF camber mount will fit.
Old 04-13-2005, 10:57 AM   #1093
On the delrin diff, I actually had to use Losi diff rings to get it to work, I had Associated D rings on there at first but they were too thin.
Old 04-13-2005, 11:03 AM   #1094
rc-zombies's Avatar
I just used the std. HPI diff rings... Is the Losi's any different than HPI's?
Old 04-13-2005, 12:28 PM   #1095
The HPI's that SoCal had in stock didnt have the D shape, just standard O so I didnt even try them out.
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
