Old 05-20-2010, 11:00 PM   #9046
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Originally Posted by shio View Post
Anyone know what is the brand of this servo horn and parts number??
Looks like a KO one. There is a sanwa one that also fits KO/JR/Sanwa servo's.
Heres the link to both:
http://www.rc-mushroom.com/product_i...ducts_id=11991
http://www.rc-mushroom.com/product_i...oducts_id=9962
You simply cut one side off
Hope that helps,
Antoni
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 05-21-2010, 12:24 AM   #9047
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
sanwa servo horn
Give the best while u can !
kschu is offline   Reply With Quote
Old 05-27-2010, 11:54 PM   #9048
Trader Rating: 26 (100%+)
Send a message via AIM to kriiiss
anyone know the dimensions of the BDM bottom deck?
kriiiss is offline   Reply With Quote
Old 06-21-2010, 07:41 PM   #9049
cocka99's Avatar
Hi actualy i have a problem whit a 40T Diff Pulley from My BDM. Mi Problem reside in i canīt found more BD Pulley but y found BD5 Diff Pulley.
This Bd5 Diff Pulley Itīs Valid from The BDM Diff?? They Are the Same??
Shio i mount the same configuration but i decide to use The TAMIYA High torque servo kit, and aluminum Horn i like very much because i have servo-saver. In the Grainger Photo they have not saver itīs direct and very very dangerous for your Servo. Thiis is a simple opinion
Thank You A gretting From Spain
Yokomo BD Masami Edition + Xerun 120A + Orion 5.5T
Tamiya M03L + Ezrun 60A + Ezrun 13T
F104 Pro + Hobbywing Justock + Sp 13.5R
Yokomo LCG, Yokomo YR-F2 & Kyosho Gallop Mk2
Airtronics Mx3-Fhss 2.4Ghz + Turnigy 5A - 40C Tune Up 4.2A - 35C + Icharger 208B
cocka99 is offline   Reply With Quote
Old 06-21-2010, 08:12 PM   #9050
Shopkeeper's Avatar
Trader Rating: 35 (100%+)
The pulleys are not the same, but, the complete diff assembly will interchange.
Shopkeeper is offline   Reply With Quote
Old 06-22-2010, 08:26 AM   #9051
cocka99's Avatar
Thanks Shopkeepe, damm i hace a problem so.... I use the Titanium racing Diffs.
I need tu found the Bd pulleys i search in japan also.
Thanks another time a recive a gretting from the north of Spain.
Old 10-09-2010, 09:25 PM   #9052
cocka99's Avatar
Hi anibody conserve a setup for BD for low grip surfacce setup i found in onthe page but al the setups are K.O.
Please help me..
Thank you
Old 10-10-2010, 09:18 AM   #9053
outtafocus's Avatar
I found this low grip setup.
It might work for you.
http://www.rcracechat.com/vb/showthr...yokomo-bd-mods
Now if I could only find a good carpet/rubber tire setup for a 17.5 motor.
Any one out there still run this car? Please help.
www.rcdepot.ca-Hobbywing-Tekno-TLR-Brass Knuckle Brush Worx
outtafocus is offline   Reply With Quote
Old 10-11-2010, 09:11 PM   #9054
outtafocus's Avatar
Bump for a good starting setup for Carpet, rubber tire with a 17.5?
If any one out there is still hanging on to this car, let me know what you have for setups.
Old 10-12-2010, 12:35 AM   #9055
Ever Try here?
http://www.petitrc.com/reglages/yoko...omoMR4TCBD.htm
Antoni Caretti
Old 10-18-2010, 07:57 PM   #9056
cocka99's Avatar
Thanks but yokomo_ant3 mi friend all the setups from this pages are k.o
THANk friends i try the setups and post
Old 10-19-2010, 05:03 AM   #9057
housey's Avatar
Alright dude I still battle on with the old BD, although mine does now have a LIPO chassis and top deck I had made so that car has less flex than standard. I ran at a big winter series meeting on sunday and came 5th in 13.5 out of 66 so hopefully this setup will be ok for you.
Front:
Shocks:
Rayspeed blue spring
40wt oil
1.3mm roll bar
2nd hole from the inside on the tower
middle hole on the wishbone
Suspension:
1mm under both suspension mounts
F-0.5 FR mount
2mm under inner camber link
0mm under outer camber link (king pin)
steering block in upper position
lower hole in c-hub
6mm droop
0 degrees toe
1.5 degrees camber
shortest wheelbase
Rear:
Shocks:
40wt oil
1.2mm roll bar
outer hole on the wishbone
Suspension:
0mm under both suspension mounts
0mm under inner camber link
0mm under outer camber link (2nd hole from inside, long ballstuds)
Lower hole hole in hub
5mm droop
3 degrees toe block
1.5 degrees camber
middle wheelbase
Hope this helps and let me know if I've missed anything off.
housey is offline   Reply With Quote
Old 10-24-2010, 08:40 AM   #9058
outtafocus's Avatar
Thanks for the setup posts.
I actually ran the BD on friday night at our clubs first club race of the season.
Considering I havent driven a touring car in like five years, I was very pleased with my driving and the cars handling.
Ended up finishing 4th in the B main due to a final corner bobble.
Old 01-17-2011, 09:42 PM   #9059
RAL
RAL's Avatar
Trader Rating: 60 (100%+)
Default BD5 Steering conversion
I thought I would post pics of my BD to BD5 steering conversion for those that may be curious to see what it looks like. BD5 standard rack, c-hubs(BD5 c-hub is thinner so you will need a 1mm shim, or two .5 shims to space it on the BD arm), BD5 knuckles and kingpins. 45.5 front universals are used. Roche spool used but BD5 spool will fit. Also using the "thin type" wheel hexes(4.1mm width) available at the link below with no wheel hex spacers for 188mm front end width using TOP Solaris tires. I also used 39mm tie-rods for the steering assembly. I DID NOT have to drill out the arms for the outer pins going through the c-hub.
http://www.driftspeed.com/index.php?...oducts_id=2264
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 01-17-2011, 11:24 PM   #9060
Greg M's Avatar
Thanks, could you post the part numbers to make sure I have them all.
I assume this is definitely a work while mod?
Greg M is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
