Old 02-25-2010, 05:34 PM   #9001
ZEe_NYC's Avatar
Trader Rating: 27 (100%+)
SOLD all my spares. car is still available for all you dudes. $200 gets it, shipped, paypaled.
full titanium screw set, every hopup option. HB front and rear ends (complete with CVD's for easy replacement), front spool, rear diff (fresh rebuild/carbide balls), two bodies (one new DNA1 for carpet, on mazda 6), etc. lots of good parts on this build. solid car
PM me for more pics. if you go back one page (page 600), that's my car.
what's an analog?
ZEe_NYC is offline   Reply With Quote
Old 02-26-2010, 07:48 AM   #9002
Trader Rating: 26 (100%+)
Send a message via AIM to kriiiss
hey guys theres play in my center shaft area
the spur gear and two center pullleys will move either left or right.
i was wondering if u guys also had this problem and if there was a solution to it
any suggestions?
thanks
kriiiss is offline   Reply With Quote
Old 02-26-2010, 09:06 AM   #9003
Shopkeeper's Avatar
Trader Rating: 35 (100%+)
If I am reading it right, you need to add shims on the layshaft between the pulleys and bearings to take up the play side to side.
Shopkeeper is offline   Reply With Quote
Old 02-26-2010, 04:29 PM   #9004
yup
but idk what shims to get from yokomo theres a lot to choose from
Old 02-26-2010, 05:50 PM   #9005
ZEe_NYC's Avatar
you can get away with using the same shims that you would to space out hinge pins.
check ur parts box.
what's an analog?
Old 02-26-2010, 06:31 PM   #9006
check ur parts box.
the blue shims?
Old 02-26-2010, 06:49 PM   #9007
ZEe_NYC's Avatar
Originally Posted by kriiiss View Post
the blue shims?
no no, those will be too wide. something like .5mm or .25mm thick.
what's an analog?
Old 02-26-2010, 07:21 PM   #9008
ok thanks i guess ill just buy those
I have three choices:
http://www.driftspeed.com/index.php?...oducts_id=1444
http://www.driftspeed.com/index.php?...oducts_id=1443
http://www.driftspeed.com/index.php?...oducts_id=1445
Old 02-26-2010, 08:48 PM   #9009
Shopkeeper's Avatar
Kriiis,
None of those are the right size. The layshaft is 4mm. It uses 2 thick plastic washers and a aluminum collar. I don't have any yokomo part numbers for these.
Old 02-27-2010, 01:41 AM   #9010
Rozzer's Avatar
It doesn't have to be genuine yokomo spacers. Anything that will fit, will work
Rozzer is offline   Reply With Quote
Old 02-27-2010, 05:42 PM   #9011
Shopkeeper's Avatar
any suggestions?
thanks
This will get you the collar you need, 95% of your play will be gone, then a couple thin shims of any sort will finish it up.
http://www.mslusa.com/yok-bd-644.html
Old 02-28-2010, 11:45 PM   #9012
ok can i just use 2 of those collars ?
or will that be too much and take up too much space on the shaft
Old 03-01-2010, 09:03 AM   #9013
Shopkeeper's Avatar
No, one collar is all that will fit, it will take thinner shims to finish it. Have you looked at the manual? It shows what you need and how it goes together.
Old 03-01-2010, 03:39 PM   #9014
no i dont have the manual
i got this as a second hand car
Old 03-01-2010, 05:37 PM   #9015
Shopkeeper's Avatar
http://www.yokomousa.com/manuals/mrtc-bd_exploded.pdf
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
