Old 03-27-2009, 01:00 PM   #8881
Francis M.'s Avatar
Originally Posted by B18C Turbo View Post
the rear diff is fresh, i'll try 1.5mm rear droop and shimming my camber link ball studs. If it still pushes then pro-squat it is, and if its still pushing I dont know? stiffer rear spring?
Are you running asphalt?
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 03-27-2009, 01:24 PM   #8882
JimmyMac's Avatar
On power exit, do not mess with rear droop! Only front! Don't play with pro-squat either.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 03-27-2009, 08:14 PM   #8883
asw7576's Avatar
JimmyMac's suggestion is looking good, don't play with anti squat or pro squat to setup your car at this stage.
Have you use fresh new tires ? More lay down king pin on the front C hub ?
I always use new tires while setting up my car.
Old 03-27-2009, 08:15 PM   #8884
SammyZ's Avatar
Trader Rating: 138 (100%+)
yes the tires are new, running both assphalt and carpet the car acts the same...off power push.
SammyZ is offline   Reply With Quote
Old 03-27-2009, 10:04 PM   #8885
asw7576's Avatar
Do you use standard 2.5mm chassis or thicker chassis meant for carpet racing ?
2ndly, I think you need to increase more shims on front bulkheads that connected to front upper link, try that with 3mm shims. I'm sure this work.
Old 03-27-2009, 10:13 PM   #8886
Francis M.'s Avatar
Can you post your current set up
Old 03-29-2009, 09:42 AM   #8887
SammyZ's Avatar
setup:
MuchMore 24R
Front Spool
FRONT
.75mm shim under front bulkhead camber link
Rayspeed white springs
2nd hole out on tower
Middle hole on arm
40wt shock oil
No swaybar
0mm trailing knuckle
Toe: 1 pos
Droop: 6mm
Camber: -1 neg
Caster: 4 pos
No shims under toe blocks
Ride height: 5mm
REAR
.75mm shim under rear bulkhead camber link
2nd hole in rear hub carrier
no shims under toe blocks
No swaybar
Rayspeed blue springs
3rd hole in on BDM tower
inner hole on arm
40wt shock oil
3 degree rear toe
Old 04-13-2009, 10:12 AM   #8888
Default BD 2.5 suspension mount
Does anyone have an extra BD 2.5 degree rear suspension mount they want to sell? Let me know
Thanks,
Oliver
DOTMAN is offline   Reply With Quote
Old 04-13-2009, 10:25 AM   #8889
Francis M.'s Avatar
Hi Oliver, I'll check if I have an extra 2.5 block
Old 04-13-2009, 10:30 AM   #8890
Francis M.'s Avatar
setup:
MuchMore 24R
Front Spool
FRONT
Middle hole on arm
40wt shock oil
No swaybar
Toe: 1 pos
Droop: 6mm
Camber: -1 neg
Caster: 4 pos
Ride height: 5mm
REAR
No swaybar
inner hole on arm
40wt shock oil
3 degree rear toe
Try putting a 1mm shim under the front suspension mounts....
I would also play with the Ackerman....
Old 04-13-2009, 11:12 AM   #8891
Awesome, thanks Francis. My car is good right now but needs a little more rotation. 2 degrees makes the car a little unstable. 2.5 should be just right
Old 04-13-2009, 03:42 PM   #8892
RC MARKET's Avatar
Thanks,
Oliver
# BD-301RR1 ?
RC MARKET is offline   Reply With Quote
Old 04-14-2009, 02:07 PM   #8893
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
SD-300R25
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 04-14-2009, 03:21 PM   #8894
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
You could alway try runing the 1 deg rear hubs reversted ( left on the right and the right on the left.)
if i remember correctly, this will give you 2.5 deg of rear toe with a 3 deg block
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 04-15-2009, 02:41 PM   #8895
SammyZ's Avatar
I have a spare BDM im selling that i have no use for now. PM me!
Hotbodies USA
SweepRacing USA
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
