Old 03-22-2009, 11:10 AM   #8866
Shopkeeper's Avatar
Trader Rating: 35 (100%+)
Originally Posted by Francis M. View Post
Hey Orin, I heard you are still doing really well with the BD....
Have you figured out they fitment issues with the RaySpeed Unis?
I have been told that the corally bones on the rayspeed axles works, the measurements look good. I have not tried it so I can't confirm that it works for sure.
Shopkeeper is offline   Reply With Quote
Old 03-22-2009, 05:25 PM   #8867
JimmyMac's Avatar
I used to use Corally bones on my BD back in the day with RaySpeed axles. I mainly used them because I could switch to steel bones up front with a spool. Let me dig up some pics....
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 03-22-2009, 05:33 PM   #8868
JimmyMac's Avatar
Well, nevermind, don't quote me on it, I can't find the pics... haha. I'd have to ask the guy whom I sold my BD to.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 03-22-2009, 07:37 PM   #8869
SammyZ's Avatar
Trader Rating: 138 (100%+)
the rayspeed bones are 48.2mm and the corally are 50.2mm, i actually fitted them to the CVD coupling/pin on the rayspeed axle and its a PERFECT fit! So now you have an option to get a replacement bone if you bend one! unfortunately the Corally aluminum bones are $22/pair
SammyZ is offline   Reply With Quote
Old 03-23-2009, 09:10 AM   #8870
capellone24's Avatar
do you know if corally bones would fit on titanium racing axles also?
thanks
visit my yokomo blog:
http://yokomo-fan.blogspot.com/
capellone24 is offline   Reply With Quote
Old 03-23-2009, 09:18 AM   #8871
Francis M.'s Avatar
thanks
I know that the corally bones fits the HB axles also... You might be able to borrow an HB bone for referrence also...
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 03-23-2009, 09:21 AM   #8872
Francis M.'s Avatar
I've just been running the yokomo steele cvd
Front universal joints part# SD-010FC
I just used a drill blank to replace the universal pin and it has been super reliable even in mod....
Old 03-23-2009, 09:24 PM   #8873
JimmyMac's Avatar
I used to run HB/HPI axles and steel Corally bones on my 415 a few years back.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 03-25-2009, 07:15 PM   #8874
SammyZ's Avatar
how do i combat an off-power steering push?
Old 03-25-2009, 07:28 PM   #8875
JimmyMac's Avatar
Rear droop, let the rear arms hang down more. Try some Ackermann settings. Move the inner steering links back on the steering plate. You can play with pro-squat in the rear. Or shorten wheel base to try and get the car to rotate a little more.
Is this with spool? Is it midcorner? Or entry?
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 03-25-2009, 10:10 PM   #8876
Team STPN's Avatar
Does anyone know if any of the top guns from Yokomo running the new BD 5 for the Reedy race at Speedworld.....
Team STPN is offline   Reply With Quote
Old 03-25-2009, 10:10 PM   #8877
SammyZ's Avatar
thanks for the tips Jimmy, it is with a spool yes. The push is corner exit only!
I will try the pro-squat in the rear and adding more rear droop. I was suggested 1.5mm over ride height.
Old 03-25-2009, 10:15 PM   #8878
Shopkeeper's Avatar
HMMM........
Old 03-26-2009, 09:27 AM   #8879
JimmyMac's Avatar
Actually, they may not help if it's exit steering you are looking for. That would only help with steering going in. Maybe Ackermann might help, but that would effect steering all around. Instead, I would try less droop up front (arms hang down less). This lets less weight transfer to the rear when you are on power out of a turn. Maybe drop 1mm on the front inner camber link. Maybe a stiffer rear swaybar? Is your rear diff too loose?
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 03-27-2009, 08:48 AM   #8880
SammyZ's Avatar
the rear diff is fresh, i'll try 1.5mm rear droop and shimming my camber link ball studs. If it still pushes then pro-squat it is, and if its still pushing I dont know? stiffer rear spring?
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
