Old 04-08-2005, 12:37 PM   #871
LeoChan's Avatar
Send a message via ICQ to LeoChan
i was lockeded center oneway put out ball bearing
left side oneway + 4x8x3 copper bearing x2pcs
in copper bearing open a M3 screw 3x3 , can easy to fix center pully & same can use center oneway !
but this car only off power to turn ?
how to have more motor break ? to stop & turn
LeoChan is offline   Reply With Quote
Old 04-08-2005, 12:47 PM   #872
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally posted by pops
If you used a ball cup on the end of the shock shaft, in the outter hole, do you think it would rub?
like this you mean?
http://www.taobracing.net/review_bd02.shtml
check out the pictures... i used tamiya shock shaft ends..instead of the yokomo ones. makes it easier to switch out springs instead of screwing/unscrewing into the arm. im guessing eventually the hole in the arm will get worn out and you'll have to replace the arm.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 04-08-2005, 01:08 PM   #873
pheyhoe's Avatar
R/C Tech Charter Subscriber
Ok not being picky but i dont fully understand.
So you replace the bearings? do we use an M3 grub screw???
[SIZE=1][COLOR=navy]Paul Heyhoe[/COLOR][/SIZE]
pheyhoe is offline   Reply With Quote
Old 04-08-2005, 01:26 PM   #874
LeoChan's Avatar
Tomorrow take a photo !
Old 04-08-2005, 01:42 PM   #875
Mr. Shookie's Avatar
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Originally posted by Hebiki
like this you mean?
Hey Chris all I am going to say is MAN That photo makes it look SOOOOO PIMP.....
Stephen <><
Makes me want ot go look at mine agian...LOL
Tell you what though the Rayspeed Ti Rear CVDs are a great upgrade....
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 04-08-2005, 01:45 PM   #876
pheyhoe's Avatar
Do you get those wheelbase spacers as standard? now they are bling
The plastic ones had either loads of play or where dead tight!
Old 04-08-2005, 01:49 PM   #877
Square makes a sweet set of teflon shims perfectly designed for them. Call Steve and request them and tell him I want some too.. Last time I had to order from HK.
Hope this helps,
Stephen <><
Old 04-08-2005, 02:13 PM   #878
Hebiki's Avatar
spacers on the hinge pins..and the ones on the shock tops (cant see on the pic above) are tamiya blue ball stud is alum. ball stud from tamiya also, same with the shock end
Hebiki Design Works
Old 04-08-2005, 02:21 PM   #879
rc-zombies's Avatar
like this you mean?
I've done that too to other cars...but I found out that after popping out the shocks ends in and out to change springs...that the shock end will eventually deform resulting in slop and the shock popping out in the event of a crash.
Old 04-08-2005, 02:24 PM   #880
Hebiki's Avatar
yup thats happened to me. but replacing the shock shaft ends ($4.00) for two is cheaper than replacing an arm with a stripped hole.
Hebiki Design Works
Old 04-08-2005, 02:27 PM   #881
rc-zombies's Avatar
so true... wait til you see what I come up with...hopefully by this weekend I'll have mine all finished...
Old 04-08-2005, 02:29 PM   #882
pheyhoe's Avatar
I need to get some of those spacers
not too keen on the ball stud as they tend to open up the shock end until it falls of when you hit something, (like somebody already said)
When you change the wheel base with the hinge pin spacers, are you supposed to space the shock differently at the top??
Old 04-08-2005, 03:35 PM   #883
lazyboy's Avatar
Send a message via AIM to lazyboy
stupid question, but thought id ask it anyways... do you guys/gals think this car will be competitive on foam tires?
thanks
lazy
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 04-08-2005, 03:56 PM   #884
i believe what he he saying, is press out the one way bearing and press in a bushing the same size, in the bushing drilling and tap a hole for a 3x3 mm set screw, this will lock the pulley,
did this on a yr4 i had and it works. take your time and just think about it while looking at it, it will make sense
Turtlemaster is offline   Reply With Quote
Old 04-08-2005, 03:57 PM   #885
thanks
lazy
It kicks butt on foam, I ran it last night.
kmorast is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
