Old 01-04-2009, 03:22 PM   #8761
In order to get a stiffer top deck, I simply superglued two top decks together.
Once I got a higher thickness I could machine (I used a Dremel, actually) the upper one in order to use tapered screws.
il-gufo is offline   Reply With Quote
Old 01-05-2009, 12:52 PM   #8762
SammyZ's Avatar
Trader Rating: 138 (100%+)
you mean yu used a countersink bit so you could use countersunk screws?
SammyZ is offline   Reply With Quote
Old 01-05-2009, 02:18 PM   #8763
Bill-CZ's Avatar
Send a message via ICQ to Bill-CZ
at yokomousa you can buy hard chassis item n. BD-002MG Graphite Main Chassis BDM... 95usd
it could be hard chassis...
Bill-CZ is offline   Reply With Quote
Old 01-05-2009, 04:04 PM   #8764
That's it!
Old 01-05-2009, 08:19 PM   #8765
SammyZ's Avatar
ya mate thats just the stock 2.6mm chassis
Old 01-05-2009, 09:38 PM   #8766
if you want a stff chassis and upper deck for a bd contact Jari at ffrcconcepts.com . his chassis are great , I use one or foam carpet.
TcORC president
Yokomo bd7 sedan, bd7 usgt
Roche rapide p12
magnum is offline   Reply With Quote
Old 01-05-2009, 11:40 PM   #8767
SammyZ's Avatar
do you have a setup sheet for foam tires on carpet?
Old 01-05-2009, 11:55 PM   #8768
|JayFlores|2's Avatar
Trader Rating: 16 (100%+)
bd-002hg or gh, not sure about the order of the letters but it is definitely stiffer than the stock chassis.
|JayFlores|2 is offline   Reply With Quote
Old 01-06-2009, 02:25 AM   #8769
capellone24's Avatar
yes same thickness but stiffer carbon fiber...
visit my yokomo blog:
http://yokomo-fan.blogspot.com/
capellone24 is offline   Reply With Quote
Old 01-06-2009, 09:50 PM   #8770
fastolfart's Avatar
capellone24, that is a very interesting top deck you have designed. I would like to join the others and be on the waiting list. With Caltek after one as well will be able to order them together, so that would make at least 4 to ship to Australia.
The actual question was for a stronger upper deck rather than stiffer. I would like one that can take a bit more of a beating, as when I crash, it is usually a high speed into something hard and I find I can delaminate the upper deck easy.
It is so hard to fix the driver, but so easy to blame the car.
fastolfart is offline   Reply With Quote
Old 01-08-2009, 01:47 PM   #8771
you are right....a bit stronger topdeck was my first idea.
i'll try to make all the possible to cut some topdecks by the end of the month...and try to make it at a reasonable price.
ciao
Old 01-08-2009, 03:52 PM   #8772
Bill-CZ's Avatar
what was your setup for foam... i drive BD with foam on our clubracing...
but what i know is....good foam is Jaco - double pink rear, pink/orange front
Old 01-09-2009, 07:31 PM   #8773
Bill-CZ check you pm
TcORC president
Roche rapide p12
Old 01-10-2009, 11:57 PM   #8774
SammyZ's Avatar
what front springs do you use for foam tires on carpet?
Old 01-11-2009, 05:10 AM   #8775
Bill-CZ's Avatar
I use HPI - gold
magnum have yokomo grey gt4 springs
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
