Old 04-08-2005, 02:54 AM   #856
highwayman's Avatar
What's the largest 64 pitch spur gear that can be used on the BD?
highwayman is offline   Reply With Quote
Old 04-08-2005, 03:28 AM   #857
highwayman's Avatar
i saw in speedtech's web site, rayspeed makes three different shock bladders for the yoke shocks... does anyone know what's the progression from hardest to the softest among the three?
What's the closest among the three to the Stock ones?
thanks - jason
Old 04-08-2005, 03:35 AM   #858
Matt Howard's Avatar
thanks - jason
Blue is the hardest, white in the middle and the yellow is the softest. The white to me feels about the same as the stock bladders.
http://www.yokomousa.com/newproducts...yspeed001.html
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 04-08-2005, 04:53 AM   #859
Originally posted by pops
Did you have to cut the foams any to fit?
I'm using Parma foam tires, they fit without any trimming. When I ran Jaco's on the CGM I would have to narrow the foam tire to 26mm.
kmorast is offline   Reply With Quote
Old 04-08-2005, 05:25 AM   #860
Ortiz's Avatar
Do they not rub the shock eyelet at all?
Ortiz is offline   Reply With Quote
Old 04-08-2005, 05:29 AM   #861
I'm running my rear shock in the inside hole on the arm. When I ran the shock in the outside hole they rubbed. On front they do not rub.
Old 04-08-2005, 06:18 AM   #862
fpart's Avatar
Trader Rating: 40 (100%+)
Send a message via Skype™ to fpart
Cool
Does anyone know if any hobby shops have parts for the BD yet. I need to get a front diff and center one way lock for mine!
fpart is offline   Reply With Quote
Old 04-08-2005, 06:26 AM   #863
fpart's Avatar
Nevermind I just scrolled up and saw that Steve got some parts in.
Old 04-08-2005, 08:24 AM   #864
rocketron's Avatar
Trader Rating: 16 (100%+)
Originally posted by Randy Caster
Finished my car and mounted my body tonight, just gotta mount the electronics tomorrow and it's racing on Sat.
Hopefully we get enough for a mod turnout at SoCal, but if not, 19 turn should be fun
hey randy,
took my BD out for a few packs last nite and am very happy with the car. started with box stock setup which was actually fairly good.... after a couple runs the car began to 'settle in' i call it. so i'm looking forward to saturday too.
stop by and we can compare setups
rocketron is offline   Reply With Quote
Old 04-08-2005, 08:44 AM   #865
It will be a few weeks before Yokomo has a locked center pulley.
pops is offline   Reply With Quote
Old 04-08-2005, 09:24 AM   #866
rc-zombies's Avatar
I got a 108t in with no problems yet...
the gear ratio chart says 112...
Old 04-08-2005, 09:32 AM   #867
rocketron's Avatar
i've been using a 112t 64p spur without any issue
Old 04-08-2005, 10:29 AM   #868
If you used a ball cup on the end of the shock shaft, in the outter hole, do you think it would rub?
Old 04-08-2005, 11:42 AM   #869
pheyhoe's Avatar
R/C Tech Charter Subscriber
Will the locked center pulley be the same as the one way one just with a grove in it for a pin to sit in???
if it is then im getting it down the machine shop to get it milled out!
[SIZE=1][COLOR=navy]Paul Heyhoe[/COLOR][/SIZE]
pheyhoe is offline   Reply With Quote
Old 04-08-2005, 11:49 AM   #870
rc-zombies's Avatar
most likely...since there is 2 holes on the layshaft for the pins.
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
