Old 10-19-2008, 10:12 PM   #8596
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
Originally Posted by Bill-CZ View Post
Hi i want ask you which shock end you use?because when i use short(16,4mm)... car heigt in front is 3,5-4mm
when i put there long susp.end(21mm) is ok but suspension work very small...
now i have front/short - rear/long
i can cut long shock end... but i want only ask you what you use you...
i have Masami special
now i make setup for carpet race with foam tyres
f you use the high volume shock bodies,( which i think most of us are using) you can use short shock ends, also make sure your shock lengths are at least 63mm, you can optian the 63mm with the stock shocks and short shock ends by unthreading the sock end.( but you will only have a few threads of the shaft in the shock end ... very risky......
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 10-20-2008, 04:20 PM   #8597
Francis M.'s Avatar
I have been experimenting with soft spring setups and found a good combination with the yellow progressive springs in the front and green rayspeed in the rear...
My usual spring setu up is Pink progressive front with Blue progressive rear..
All setups are using masami rear shock tower.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 10-21-2008, 04:22 PM   #8598
Bill-CZ's Avatar
Send a message via ICQ to Bill-CZ
i will use HPI gold - front and HPI silver rear
Bill-CZ is offline   Reply With Quote
Old 10-26-2008, 09:57 AM   #8599
SammyZ's Avatar
Trader Rating: 138 (100%+)
my BDM
SammyZ is offline   Reply With Quote
Old 10-26-2008, 02:34 PM   #8600
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Wow...you finally got one!! Congrats and enjoy.
How's it handling?
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 10-26-2008, 03:44 PM   #8601
SammyZ's Avatar
ya man! i like it a lot better than my old cyclones! handles better IMO.
i got these suzuki knuckles/hubs for sale, $45 shipped
Old 10-26-2008, 05:26 PM   #8602
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
Which steering knuckles and rearhubs you got?
It is very important to have non-trailing 0mm knuckles and 0degree rear hubs
We usw plastic steering knuckles anyway as alloy is very heavy and is as huge increase in umsprung mass not very healthy for the handling
+ plastic is ok or broken. Alloy bends
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 10-26-2008, 05:47 PM   #8603
SammyZ's Avatar
.5mm trailing knuckles and 0 degree rear hubs, alloy>plastic
Old 10-27-2008, 01:29 AM   #8604
0deg rear hubs are ok but please notice that these hubs are 0,5mm lower (2mm under ballstud with plastic = 2,5 with alloy)
If u use sd-010rw shafts, glue the inner bearing into the Hub to reduce angle-slop
And use sd-415s steering knuckles
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 10-31-2008, 05:16 AM   #8605
Kajman's Avatar
Hello!
I'm thinking of buying Yokomo MR4TC BD Masami Edition, is this car still worth it's price? How does it compare to TC5 or t2 007/008? Do parts break often? Weak points?
XXX-S G+, XXX-S, TRF 415MS, SCTE 2.0, SCTE TLD, Kyosho DRX VE
Kajman is offline   Reply With Quote
Old 10-31-2008, 09:41 AM   #8606
SammyZ's Avatar
Originally Posted by Kajman View Post
Hello!
the car is really durable, so far all i have broken/bent were C-hubs and CVD's. I have a full rayspeed spring set for you if you get one. Where do you plan on getting one?
Old 10-31-2008, 11:59 AM   #8607
Kajman's Avatar
on ebay they show from time to time NIB.
Old 10-31-2008, 12:26 PM   #8608
JasonC's Avatar
Weakist part of the BDM is the Alum Universials, the front ones bend or wear out really quick, ( highly recomend replacing Them with the TIR CVD's or the Steel Universals Yokomo Sells
Old 10-31-2008, 05:52 PM   #8609
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Default Yokomo at the worlds
Hey guys does anyone know who is going to be representing Yokomo at the worlds? I know masami will be there, but who will accompany him? Also does anyone know anything on the new car?
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 10-31-2008, 07:38 PM   #8610
SammyZ's Avatar
ya for $529+ shipping
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
