Old 10-04-2008, 09:14 PM   #8536
jebs's Avatar
Send a message via Yahoo to jebs
good day!
i need a little help
i bought a used BDM and lately rebuilt it. accidentally i mixed up the springs. i dont know whats for the front or rear since all the springs are white. the only thing different were the dots. how should i differentiate those? im still new to rc racing so i cannot feel the difference in spring stiffness..
jebs is offline   Reply With Quote
Old 10-04-2008, 09:44 PM   #8537
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
Originally Posted by jebs View Post
good day!
normaly stiffer in the Front softer in the rear (white springs with color code dot)
YS-1460L Black 14.50
YS-14575L Blue 14.80
YS-1455L Yellow 15.70
YS-1565L Pink 16.26
YS-15625L Green 17.00
YS-1560 Orange 18.50
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 10-05-2008, 04:50 AM   #8538
jebs's Avatar
YS-1565L Pink 16.26
does a larger number mean stiffer? thanks a lot
Old 10-05-2008, 10:40 AM   #8539
the lower the number the softer the spring is and higher the number
is stiffer....
mwoods is offline   Reply With Quote
Old 10-05-2008, 02:19 PM   #8540
SammyZ's Avatar
Trader Rating: 138 (100%+)
YS-1565L Pink 16.26
Should note these are for Yokomo springs, not the Rayspeed springs which come on the BDM. Unfortunately I do not know the difference between the BDM white springs from the color dots. They feel the same though, this was poorly designed.
SammyZ is offline   Reply With Quote
Old 10-05-2008, 02:50 PM   #8541
Losiho's Avatar
Edited (question answered)
Losiho is offline   Reply With Quote
Old 10-05-2008, 02:50 PM   #8542
JasonC's Avatar
here are ratings for the rayspeed springs
Rayspeed
Spring Rating [lb/in]
Gray 19.90
Red 18.26
White 17.17
Yellow 14.87
Blue 14.29
Green 13.20
Old 10-05-2008, 04:06 PM   #8543
SammyZ's Avatar
which BDM spring is stiffer, there both white but color coded one is pink and the other orange.
The pink spring has more tightly wound coils than the orange coded spring.
Old 10-05-2008, 04:49 PM   #8544
caltek1's Avatar
Trader Rating: 36 (100%+)
Default Yokomo Progressive Springs
B18C Turbo,
For Yokomo Progressive springs(white springs with color code dot)
YS-1460L Black 14.50 Softest
YS-1565L Pink 16.26
YS-1560 Orange 18.50 Hardest
If you are running a spool then the springs are normally softer on the front than what is run on the rear. This is to give more steering, run harder springs up front and you will push through the corner.
On my BD fitted with a TIR spool I am using white spring pink dot front and white spring blue dot rear.
Later
Calvin.
Hope this helps.
caltek1 is offline   Reply With Quote
Old 10-05-2008, 07:36 PM   #8545
SammyZ's Avatar
Originally Posted by caltek1 View Post
B18C Turbo,
YS-1565L Pink 16.26
If you are running a spool then the springs are normally softer on the front than what is run on the rear. This is give steering, run harder springs up front and you will push through the corner.
Later
Calvin.
Hope this helps.
thats the most helpful probably the best post i've ever seen on rctech. Where did you find that!?
Old 10-05-2008, 09:46 PM   #8546
caltek1's Avatar
B18C Turbo ,which BDM spring is stiffer, there both white but color coded one is pink and the other orange.
Well you did ask which was stiffer in this post, just put in hardest and softest for you.
Also the previous post was saying to run harder spring up front, not done with spool.
Calvin.
Old 10-05-2008, 10:21 PM   #8547
SammyZ's Avatar
Calvin.
yes yes! thank you Calvin! I wrote down this information and pasted it to my spring box. Thanks again!
Old 10-05-2008, 10:53 PM   #8548
caltek1's Avatar
martin,
Thanks for access to your blog. Have got some good setup tips from there. Is there any forth coming info regarding the new BD, now that Masami has proven it in Japan?
Francis M,
Have you tried the graphite rear diffs,as made by TOP. I purchased a set with the thrust bearing and smaller screw. I will be trying this diff on the weekend.
Has anyone tried drilling more holes into the pulley so that you use more diff balls, same as they are running in the 416? I was going to give it a go.
I was running the front Yokomo aluminium spool, but it chewed out very quickly. I have fitted the TIR spool, which I have found to be lighter and give heaps of steering. Advantage is you can also replace the outdrives.
It is absolutely necessary to get the high volume shock bodies. I currently have the standard bodies, cutting down the triangular piece and fitting upside down. What is the major benefit for the newer bodies. Slower action??
B18C Turbo,
Apologies, took your post wrong way. Glad to see you fixed your CVD problems.
Later
Calvin.
Old 10-05-2008, 11:07 PM   #8549
Francis M.'s Avatar
martin,
Francis M,
B18C Turbo,
Later
Calvin.
Calvin the high volume shocks pretty much elimenates the need for the triangle peices in the shock body... the original bodies is actually a little larger on the botom of the body so the triangle peices can fit. Cutting it down will give you more shock travel but the piston fit will be loose towards the bottom and will be inconsistent....
I have not tried the top version diffs. I have found the stock yok diff to be really consistent and never had a problem with it....
As for spools I use either the aluminum or the plastic spool with aluminum sleeve. As for wear I recommend using Tamiya anti wear grease...
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 10-05-2008, 11:21 PM   #8550
caltek1's Avatar
Thanks Francis M,
I will order some of the larger shock bodies and give them a go.
I had glued the aluminium sleeve form my original plastic spool onto the Yokomo aluminium spool, however still had wear. I will stick with the TIR for now and purchase a couple of spare Yokomo ones for the spares box.
For the triangular piece I only cut the length down, not the width. I cut off approx 2mm. It still touches the shock inner body through the range of movement.
I am still not sure of how to make the shocks with zero rebound though.
Regards,
Calvin.
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
