Old 09-23-2008, 01:56 PM   #8506
Francis M.'s Avatar
Originally Posted by B18C Turbo View Post
1 club race on these and there already showing heavy wear Are there any CVD plastic blades that will fit the pin end?
Did you use tamiya antiwear grease or something similar?
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 09-23-2008, 03:09 PM   #8507
SammyZ's Avatar
Trader Rating: 138 (100%+)
no, how would grease help?
SammyZ is offline   Reply With Quote
Old 09-23-2008, 03:10 PM   #8508
STLNLST's Avatar
Trader Rating: 21 (100%+)
You are gonna have to make something else work. The blades for the Cyclone are $11 a pair (OUCH) so I went with the blades for the TC5. The holes for the pins are larger on the Cyclone so I had to slightly ream the holes on the TC5 blades to fit the Cyclone. I'm sure some blades will help with the wear on the outdrives.
STLNLST is offline   Reply With Quote
Old 09-23-2008, 03:15 PM   #8509
SammyZ's Avatar
will the TC5 blades fit inside these outdrives?
Old 09-23-2008, 03:17 PM   #8510
Francis M.'s Avatar
It will reduce the wear significantly. Metal to metal with out lubrication is never good... I recomend Tamiya Antiwear grease since it is really thick and last a lot longer....
Old 09-23-2008, 03:21 PM   #8511
STLNLST's Avatar
That's going to be the million dollar question. Do you have any TC5 racer's at your local track that will let you see if it would slide into the outdrives?
Old 09-23-2008, 03:23 PM   #8512
SammyZ's Avatar
yes I do but I don't wanna run again until i have something to fit in there before the next race! Im gonna go out on a limb, priority mail some right now and wish for good luck.
Old 09-23-2008, 04:01 PM   #8513
Francis M.'s Avatar
I don't think blades will fit into the outdrive. The universal pin fits perfect into the outdrives.
If you want to put blades on the universal pin Corally should fit but you will need to machine the outdrives bigger. IMO you are better off just greasing the pins and outdrive, well not unless you can open up the slots on the outdrives perfectly centered.
Old 09-23-2008, 06:44 PM   #8514
SammyZ's Avatar
I'll getem to fit, i wont mod the outdrives but I can getem to fit. All i would need to do is sand or file the blades until they cleared.
Old 09-23-2008, 08:00 PM   #8515
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
there r cheap blade around..serpent s400 blade. sell in 8pcs...around usd4..but if u said u wan file/sand the blade to be fit into d outdrive, d lifespan of the blade will be very very short...mebi cant last for 5minute if use on mod motor...
just my 2cents
Give the best while u can !
kschu is offline   Reply With Quote
Old 09-23-2008, 09:06 PM   #8516
SammyZ's Avatar
i've never had a CVD blade on either my xray or HB car fail or even show any signs of wear with 10.5 racing.
Old 09-23-2008, 11:03 PM   #8517
Trader Rating: 35 (97%+)
Send a message via AIM to King of B Main
Tc5 blades should work
King of B Main is offline   Reply With Quote
Old 09-23-2008, 11:50 PM   #8518
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
Originally Posted by Ron C. View Post
Hey Martin... awesome driving! If you may, what tires and body did you have on the car?
Again..... awesome driving!
tires:
sorex 36 preglued wheel from gm-racing was the only tire allowed (2 sets for the whole meeting)
bodyshell:
I used a heavyweight speed 6 with the frontlip cut down till there are only 3mm left and the side ofcourse trimmed accordingly so i can put the bodyshell lower (in the front!) as it is usually ment to be run ... passes the 115mm rule and gives you a little bit of extra steering
wing cut to 38*17mm so it passes the "lower as the roof" rule and mounted with 9,8mm overhang of the rearmost edge of the bodyshell
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 09-24-2008, 07:16 AM   #8519
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
just use the plastic one......
cheaper and last forever in stock ant 19t
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 09-24-2008, 07:42 AM   #8520
Send a message via MSN to mark34 Send a message via Yahoo to mark34
Hi there just use the Tamiya blades direct fit for driveshaft, you will have to lightly file and polish the out drive takes about 5 mins to do and had no problems with this running mod and no premature failure of blade HTH
Mark
Yokomo BD
CEFX C12
Powered By Demon Batteries and GM Brushless and 2 thumbs
Mark Ashby
mark34 is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
