Old 08-12-2008, 05:38 PM   #8341
ckoetsch's Avatar
Trader Rating: 18 (100%+)
how does the yokomo compare to the t2 008?
Sick Graphics - KYOSHO RB6.6 - "If you ain't first you're last" R. Bobby
NW Hobbies of Albany and Dave's RC Tracks of Hubbard.
ckoetsch is offline   Reply With Quote
Old 08-12-2008, 06:33 PM   #8342
yokemad's Avatar
New Yokomo will be available soon
for your information
yokemad is offline   Reply With Quote
Old 08-12-2008, 08:38 PM   #8343
HOW SOON IS SOON???
Y
MARKANO is offline   Reply With Quote
Old 08-12-2008, 10:59 PM   #8344
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
The BD is still capable of winning as it shows here in Germany all the time.
There are more and more yokomo drivers. One switched from Team Xray to Yokomo and he was a lot faster. He's very happy with the car and has good chances to win the stock category at the upcoming german nats.
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 08-13-2008, 01:03 PM   #8345
There are features on this car I really like. I race on a med bite carpet track and wonder how this car would do/hold up. I currently have a T2 but want to get a new car. This car seems like a great value, looks like high quality and havent really heard of many quality issues.
What would be the top 3 pros and cons to this car ?
wcalaker is offline   Reply With Quote
Old 08-13-2008, 01:17 PM   #8346
pro:
always! easy to drive and consistant even if the track conditions change
The alloy is quite high quality -> not many bent parts
It is BLUE :-)
con:
the diff needs maintance -> if not working properly the car ain't handling good
the same is true for the car itself ... check for tweak regularly and make sure everything is set correctly ... actually you should do that with every car ...
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 08-13-2008, 01:28 PM   #8347
How are the shocks? They easy to build and maintain? Adjust rebound etc....
How is it out of the box? I want a car I dont have to make many hop ups to and if they are hop ups I want it to be factory. In other words i dont want a car that has to have another brand of c-hub and dremel work to make it work right.
Old 08-13-2008, 01:37 PM   #8348
Then you might want to wait or the release of the new car
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 08-13-2008, 06:24 PM   #8349
m3ndo5a's Avatar
Have both cars it is easy to relay the tally. Both car are good kits, and in the hand of any great driver the performance areas would seem confusing to the spectator which car look the easiest to drive.
Performance wise the Xray carries more corner speed with a spool, with a one way and center 1way the yokomo performs alot better. Dual diff they are both sloppy.
The Xray is forgiving to set up error without losing much performance were as the BDM will reflect its performance due to set up or maintenance. The only other kit that I can think of that is so forgiving would be the HB Cyclone.
My yokomo seems to perform well with any tires without set up changes, were as the xray008 adjustment tends to be made depending on the shoes it wear.
Steering the Xray008/ has the BDM hands down
Acceleration....they very similar
Braking the Xray is very determined
The BDM is Smooth in its transition not as rough as the Xray008
Set up wise the Xray controls more adjustments and quicker.
Maintenance they both are easy to work on.
Quailty wise the are both equally the same.
Cost wise the Xray 008 is crazy priced @ $529USD and so is th BDM $469USD if you can find one state side, else where its a $500 kit to ship.
I did change my steering rack, to change the ackeman setting and steering throw.....the steering radius is tighter and quicker. The car has pick up corner speed and faster transition throw the apex.
m3ndo5a is offline   Reply With Quote
Old 08-13-2008, 06:33 PM   #8350
Hebiki's Avatar
Trader Rating: 26 (100%+)
Mendosa.. that looks like the 415 MRE steering arms/rack?
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 08-13-2008, 10:19 PM   #8351
This isn't necessarily a BD question, but I race a B4 and like to use the Yokomo caps with the bleeder screw. I just bought some and the header cards said "new" and they didn't thread onto my shocks right. I didn't force them as I didn't want to start cross threading them. So my aquestion is, did Yokomo change the threading on the caps or do I just need to monkey with them a little more?
Chris Brown is offline   Reply With Quote
Old 08-13-2008, 11:09 PM   #8352
CSF0623's Avatar
I have had the same issue trying to use them on my T4. They didn't thread in right. I know of some others using the same caps on the associatied shocks with no problems. So you are not alone. I ended up not using them.
Carl F.
ACTIVRC.COM P1BRAND
CSF0623 is offline   Reply With Quote
Old 08-14-2008, 05:31 AM   #8353
m3ndo5a's Avatar
Yes, good eye
Xray 4*Castor and Steering Blocks (not a must, it cleans up the car up front, also adds the ackerman adjustment)
35mm lunsfords ti turnbuckles
Tamiya MRE Steering Rack
Old 08-14-2008, 11:48 AM   #8354
Hebiki's Avatar
Yes, good eye
im really good at spotting a GOOD RACK from far away.
Hebiki Design Works
Old 08-15-2008, 01:29 PM   #8355
mr4tcsdrifter's Avatar
Trader Rating: 45 (100%+)
Send a message via MSN to mr4tcsdrifter Send a message via Yahoo to mr4tcsdrifter
Thanks to "King of B Main", i will now be part of the BDM family. I can't wait to get this car and take it to the track. this means i can retire my mr4tcs special now. Any word of advice for this car? I'm going to be running the 19t/10.5 class. My setup will be a GTB/10.5 and 4500 trinity lipo. how balanced should the car be with this setup? Thanks for your input
Bryan
mr4tcsdrifter is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
