Yokomo MR4TC-BD
Old 07-17-2008, 05:38 AM
  #8311
Martin Hofer's Avatar
the car used at the lrp tcm featured a new dirt sealed diff
Martin Hofer is offline
Old 07-17-2008, 02:33 PM
  #8312
Hi i was wondering if some one who uses brushless and nimh could tell me how they balanced their cars.
I just recently got some scales and some weights and I managed to balance it right to left but the corner weights are way out from each other so any help would be good.
articnova is offline
Old 07-17-2008, 02:37 PM
  #8313
SammyZ's Avatar
Trader Rating: 138 (100%+)
wow i didn't know people actualyl did that? where can you buy a corner balancing kit? is that like 4 scales and each tires goes on each one?
SammyZ is offline
Old 07-17-2008, 02:40 PM
  #8314
yea its 4 scales I did it cause since changing to bl the right side of the car has been really heavy compared to the left
Old 07-17-2008, 03:07 PM
  #8315
my car is well balanced .. no need to trim anything
standard sized servo (extremely fast Graupner servo), Ko rx, GM Genius 120 and gm pro brushless motor on left side
and basic 5cell nimh pack on the right side
Old 07-17-2008, 03:10 PM
  #8316
Hi martin im actually using 6 cells thats why i asked as im using a 10.5
Old 07-20-2008, 08:11 AM
  #8317
I know most setups dont have this but has anyone tried the car with no spacers under the front and rear hinge pin mounts.
Whats the car like?
Old 07-20-2008, 09:06 AM
  #8318
Francis M.'s Avatar
Whats the car like?
I've tried this and the car pushed more noticably on entry....
Francis M. is offline
Old 07-22-2008, 10:41 AM
  #8319
Francis M.'s Avatar
I just got done racing the 10.5 class in the Bending corners mayham race...
race format was 1qual and 1main x4 different layouts... 1 point goes to tq and 50 points for 1st, 49 for 2nd and so on for each layout....
I got out to a slow start in the first layout qualifying 3rd and finished 5th...
I TQ'd and won the 2nd round, Qualified 2nd and finished 2nd in the 3rdrd, I had a chance to win it but bobbled, I qualified 2nd and finished 1st in the final layout to take the overall win....
The only change I did to the car all day is change my tires from some worn out rp30s to sorex 36 mounted on yokomo wheels and superthin firm inserts....
Old 07-23-2008, 07:50 AM
  #8320
Trader Rating: 36 (97%+)
Congrats on the Win Francis !!! Your car was dialed ....
King of B Main is offline
Old 07-23-2008, 08:54 AM
  #8321
francis
congrats
what setup did u use?
Old 07-23-2008, 06:04 PM
  #8322
Francis M.'s Avatar
Originally Posted by Martin Hofer View Post
francis
congrats
Front settings
front shocks 40wt w/ 3 hole rayspeed pistons and tamiya diaphram.
inside position on shock tower, middle position on the hard arms.
no swaybars... white progressive springs color code pink..
1mm spacer on suspension mounts.
3mm spacer for the inside of camber link
yokomo mr4tc 4deg c-hubs. with cgm mod
ackerman 2hole from the most forward position...
0 degree steering hubs
Droop 5mm on hudy blocks....
Rear settings
rear shock oil 35 w/ 3 hole rayspeed pistons and tamiya diaphram.
2nd to highest setting on shock tower (masami tower).. inside on arms
no swaybars...white progressive spring color code blue
no spacers on suspension block
camberlink no spacers on camberlink using the 4mm stud on outside hub.
2.5 degree camber block with .5 degree hubs
droop 4mm on hudy block
I was going to connect the swaybars for the front and rear but didn't have time to try it.. I have a feeling the car would have been better...
Front spool of course...
Old 07-23-2008, 06:20 PM
  #8323
Francis M.'s Avatar
Thanks Mike....
Old 08-01-2008, 08:21 AM
  #8324
Francis M.'s Avatar
Hey Martin, is that your car in Red R/C sporting a new chasis, upperdeck and steering bell crank?
Old 08-01-2008, 08:25 AM
  #8325
Hi Francis I dont think Martin can post since hes racing but if youre refering to this
http://events.redrc.net/wp-content/g...erYokomo-1.jpg
No its Chris Grainger's car but hes unwell and has withdrawn from the euros
