Old 05-05-2008, 02:55 AM   #8146
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
jup, pics would be greatly appreciated
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 05-05-2008, 08:09 AM   #8147
Francis M.'s Avatar
Sorry I don't have pics since I didn't attend the race. I'm sure someone will post pics in the reedy thread.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 05-05-2008, 09:23 AM   #8148
snoopyrc's Avatar
Originally Posted by Francis M. View Post
I just changed my paint scheme which always makes me feel like I have a new car....lol
Those are beautiful! Did you do them yourself? If not who is the painter?
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 05-05-2008, 09:43 AM   #8149
Francis M.'s Avatar
I don't have the skill or the patience to paint anything with more than one color. The painter is Jeremy Go AKA J-go paints.
I beleive you can buy some of his prepainted bodies at speedworld.com
Old 05-11-2008, 05:04 PM   #8150
Francis M.'s Avatar
Just got back from racing yesterday and the BD was working really good....
On another note Masami is atttending the Reedy Race of Champions and it will be interesting to see what car he will be runnning......
I know the BD works well at SpeedWorld since Billy Easton won the 19turn ROAR nationals there and almost won the Modified Class also....
Old 05-11-2008, 05:32 PM   #8151
STLNLST's Avatar
Trader Rating: 21 (100%+)
I'd run one if Yokomo comes back to the states. The BD does look good and the one local guy out here that has run his forever seems dialed.
STLNLST is offline   Reply With Quote
Old 05-11-2008, 05:50 PM   #8152
Trader Rating: 35 (97%+)
Send a message via AIM to King of B Main
Default setup
I wanted to congratulate Mike Molina for taking 3rd in the 13.5 class at the Reedy Warm up race. I beleive this is his 3rd race with the car so that is pretty good.....
Thanks, Francis....
Hey do you know where I can find Billy's setup from the nationals.. I would like to see his setup?
King of B Main is offline   Reply With Quote
Old 05-11-2008, 06:16 PM   #8153
Francis M.'s Avatar
Yokomo hasn't left, they don't have a factory driver in the U.S.A. currently but Yokomo U.S.A still supports all the LHS. They just need to call and order what ever is needed... There are a couple of locals here at Socal bringing out thier old Kit which is a big improvement considering I saw that it was only me and Jason C running the car for a while. So there is a resurrecting interest in the car... It just works and is pretty maintenance free......
King of Bmain, Sorry but I don't have Billy's set up.... Your car is almost there when I was watching your heat it did look good, You just seem to need a tiny more steering....
Oliver Clipper one of the locals brought out his BD for the Weekend and almost got TQ in the second round for the 10.5 class and he told me he is bringing out his other BD also. One for 13.5 and 10.5, his car was really dialed... I ended winning the 10.5 class from 2nd in the Grid and Ron C. also driving a BD got 2nd, Oliver forgot to charge the Lipo on his BD and ran the Main with another car and didn't fair so well but all our cars are consistently good and easy on tires.... All three of us are running pretty close in set up.....
Old 05-11-2008, 07:02 PM   #8154
stikman's Avatar
would you mind sharring your setup?
stikman is offline   Reply With Quote
Old 05-11-2008, 07:23 PM   #8155
Francis M.'s Avatar
I used Chris Graingers Baseline set up and this is what I ended up with...
Front....
Toe- 1out or .5out
Camber- Negative 1.5
Camber link position 2MM shim inside
Suspension blocks- 1mm shim
Ride Height 4.5
Droop-6 on Yokomo Droop guage
Srings- White springs with pink color code
Sway Bar-none
Shock oil - 35 with 2 hole rayspeed piston
Shock position - inside hole in tower and middle hole on Hard arms....
Ackerman-CGM mod using 3 hole back on the plate... MR4tc hubs...
Aluminum Spool with Standard steele axles and Yokomo aluminum bones...
Rear......
Toe-2 block with .5 hubs
Camber 1.5
Camber link position- No shims using the stock 4mm ball stud on rear hubs.
Suspension Block - No shims
Ride Height- 5mm
Droop 4 or 5 MM on yokomo Droop guage
Springs - Blue rayspeed
Sway Bar none...
Shock oil 35wt with 2 hole rayspeed
Shock position - 3rd hole in from the outside (masami tower) and inside hole in the arm....
Tires-Sorex 32 with Yokomo precision wheels and Superthin medium insert.
Body- PF mazda Speed 6 mounted lined up using the front cut line. Wing mounted 10-11 MM overhang....
Shock oil is 35 Associated oil....
Old 05-11-2008, 10:36 PM   #8156
stikman's Avatar
Front....
Toe- 1out or .5out
Ride Height 4.5
Sway Bar-none
Rear......
Camber 1.5
Ride Height- 5mm
Sway Bar none...
Body- PF mazda 6 mounted lined up using the front cut line. Wing mounted 10-11 MM overhang....
Thanks,
I'll test out that setup.
Old 05-11-2008, 11:51 PM   #8157
Francis M.'s Avatar
Stik Man, I was using the Mazda Speed 6. Sorry for the typo and hopefully the set up will be a good starting point for you...
Oh one last thing, remove the Graphite stiffener on top of the rear bulkhead along with the stiffener post near the rear of the battery and remove the bottom screw on the left rear bulkhead the one all the way in the front.....
Old 05-12-2008, 07:11 AM   #8158
STLNLST's Avatar
Yokomo USA needs to put the word out that they are still open because I don't think anyone around here knows that. I might tinker with one after the Reedy. I'm really loving the Cyclone though. The BD will have some big shoes to fill
Old 05-12-2008, 07:38 AM   #8159
Francis M.'s Avatar
The Cyclone definitely is a good car. Oh and good luck at the reedy race...
Old 05-12-2008, 12:25 PM   #8160
lem2's Avatar
Front....
Toe- 1out or .5out
Ride Height 4.5
Sway Bar-none
Rear......
Camber 1.5
Ride Height- 5mm
Sway Bar none...
Francis,
Are you using the long shock ends? Fixed or center one way?
will try your set up---Salamat!
and speed 6 is different from a mazda 6 body? sorry been out a long time.
Lem
Where can I get hero sieko wheels, locally?
lem2 is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
