Old 04-28-2008, 08:12 AM   #8131
Francis M.'s Avatar
The worlds are a long way from now so we will have to wait till then.....
On another note my BD has been working pretty decent for the last couple of race meets and I just changed my paint scheme which always makes me feel like I have a new car....lol
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 04-28-2008, 08:56 AM   #8132
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
yup, its a long way from now but still cant help but wonder ... we'll just have to see. im sure they're playing their cards the way they want to. hopefully though its all falls into place.
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 04-28-2008, 10:04 AM   #8133
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
Originally Posted by MARKANO View Post
Dear Martin,
Was studying your setup, got a few question:
Toe out inboard: 0.5 wheels; 0.5 open. Do you mean your are using the 0.5 front suspension mount with a 0.5 toe-out?
I only have the CGM steering crank but not the MR4TC hub, is it still worth to try the steering modification without the 4TC hub?
Do you use any thin Yok Hex in the front to make more steering?
Thanks.
- i do not make the car any narrower as usually the only thing you achieve is,
that the wheels rub on the wishbone
- yes i use a 0,5 block and the wheels are 0,5 open
- you need mr4-tc hubs to make the modification work
as it was already said, the main goal of that modification is to gain more
lock -> necessary steering
the setup is a good basic startingpoint, but i still do further tests
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 04-28-2008, 10:59 AM   #8134
Francis M.'s Avatar
How are you doing Martin... I've been using a set up by Chris Grainger but it's pretty much really close to what you sent me a few months ago. I think thats a good thing because it just confirms that the set up is a perfect starting point for most places outside of Yatabe.....the main thing with this set up that i found was to mount the wing further back especiallly running the Speed Six Mazda...
Old 04-28-2008, 11:07 AM   #8135
speed 6 shell, 17mm height, 10mm overhang, stock wing
works good on alot of tracks
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 04-28-2008, 11:53 AM   #8136
Francis M.'s Avatar
Where do you measure the overhang from?
Old 04-28-2008, 12:39 PM   #8137
from the rearwardmost point of the bodyshell (usually the middle of the rear bumper) to the rearmost point of the spoiler
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 04-28-2008, 04:10 PM   #8138
Martin,
Do you use alloy diff halves? If so, what do you do to the driveshafts to prevent damage from the steel dogbone pin.
Also, do you use Worlds TIR driveshafts in the front when you use the standard wishbones which are 2mm wider?
TIA
Don
donwhit is offline   Reply With Quote
Old 04-28-2008, 10:45 PM   #8139
- yes I do, tam aw grease
- i always use the standard wishbones and yes i use TiR shafts
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 04-29-2008, 10:50 AM   #8140
Francis M.'s Avatar
I've been using the standard yok axles front and rear but used the aluminum yokomo bones and the pins seems to be holding up fine after one straight month of racing on weekends.... I usually race 10.5 brushless with a minimum of 3 practice rounds before we run another 3 rounds of qual and 1 main...
I like running the plastic spools for spec racing since it seems to have more steering.....
Old 04-29-2008, 06:28 PM   #8141
stikman's Avatar
does any one know the setup Masami use at the pre world?
Martin, does your setup work with 6 cell?
thanks,
stikman is offline   Reply With Quote
Old 04-30-2008, 12:02 AM   #8142
it should. you may have to change some minor things but it should be quite good
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 04-30-2008, 07:39 PM   #8143
stikman's Avatar
Ok, thanks,
I'll try out this setup in prep for reedy race in May.
Old 05-05-2008, 12:05 AM   #8144
Francis M.'s Avatar
I wanted to congratulate Mike Molina for taking 3rd in the 13.5 class at the Reedy Warm up race. I beleive this is his 3rd race with the car so that is pretty good.....
Old 05-05-2008, 12:31 AM   #8145
SammyZ's Avatar
Trader Rating: 138 (100%+)
have pictures from the race?
SammyZ is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
