Old 03-01-2008, 07:45 AM   #8026
i hav send the setup to u guys who never receive pls pm me and i wil mail u again sory for late reply cos internet problem
ongsan is offline   Reply With Quote
Old 03-02-2008, 06:53 AM   #8027
Island Losi's Avatar
Originally Posted by ongsan View Post
Can u pls pm me ur mail so i can mail it to u ,i only available to giv 90percent setup cos some of it i don hv the part
Best Regards
Ongsan
ygpm
Yokomo|SpeedPassion|McgooCreative|TeamOrion|FusionPower|Futaba|Spektrum|RP|Trinity|Protoform
Island Losi is offline   Reply With Quote
Old 03-02-2008, 07:32 AM   #8028
Setup from Ongsan on link given post 8015
Arn0 is offline   Reply With Quote
Old 03-02-2008, 11:11 AM   #8029
Hi i was wondering if i could get some setup tips from you guys. I know that some of my questions can be directed to drivers of other touring cars but id prefer it if they came from bd drivers as each car is slightly different.
Ive only just started racing so i dont really know what im doing so any help would be appreciated.
My problem is that the car doesnt feel planted and it understeers badly mid corner.
My current setup is
Front:
50wt oil
Rayspeed White spings
4.5mm ride height
2nd from inner shock hole at the tower and middle hole at the wishbone
normal wishbones
4mm spacer at from of wishbone none at back
2mm droop
Rear:
50wt oil
Yokomo black springs (all white springs with dot of colour)
5mm ride height
2nd from outer shock hole at tower and outside hole at wishbone
normal wishbones
2mm spacer either side of the wishbone
3 deg toe in
1mm droop
I run muchmore absolute 24 preglued rubber tires with additive and this is on a small twisty carpet track in the Uk. The track itself has only one straight with the rest of it being chicanes (sp?) and hairpins. I dont run more droop as i tried an old ollie jefferies setup with 5mm droop but the car struggled and it looked like it was gonna grip roll. I havent tried roll bars as i cant find any in the uk without ordering. I have the car gear with a quite high FDR as i have only just started racing i would prefer to get used to the track rather than just crashing all the time. I have a front one way and a direct drive in the middle. I currently run 27t motors.
How do i get more grip mid corner? I tried putting the shocks at the back more vertical by putting the shocks on the 2nd from outer hole at the tower but it just made the back end slide with no grip.
I think ive listed as much as i can remember so any help would be appreciated if you need to know more let me know and ill try to tell you the info.
Mike
articnova is offline   Reply With Quote
Old 03-02-2008, 03:44 PM   #8030
Default BD setups
Articnova - have you tried the CML website? www.cmldistribution.co.uk
Click on DOWNLOADS then SETUP SHEETS. Click on the car then GO.
regards
Don
donwhit is offline   Reply With Quote
Old 03-02-2008, 05:52 PM   #8031
Petit Rc Link for Chris G. doesnt work.. No update on CML site too...
MARKANO is offline   Reply With Quote
Old 03-02-2008, 07:14 PM   #8032
Fixed!
Old 03-02-2008, 07:21 PM   #8033
Francis M.'s Avatar
It looks like Chris Grainger specified using SD .4 degree hubs. I always thought that the SD hubs were identical to the BD?
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 03-03-2008, 02:39 AM   #8034
sportssedanman's Avatar
Send a message via Skype™ to sportssedanman
I am after some help locating drive shafts. I have SD-010FC for the front, and I am after some Low Friction Universal Driveshafts. I think they they are SD-010RC or SD-010RS.
Can anyone tell me where I can get them? I have tried RC Champ and RCMart.
sportssedanman is offline   Reply With Quote
Old 03-03-2008, 04:00 AM   #8035
Trader Rating: 8 (83%+)
well ill be selling my bd soon
just gotta finish the rebuild
depressing :-(
i730 is offline   Reply With Quote
Old 03-03-2008, 08:27 AM   #8036
Racingbod85's Avatar
They are. a lot of the team drivers tend to use the old MR4-TC hub carriers (think it's a ZS part no) or HB bits so he's just specifying which one.
RC12L4
Novak 4.5R / 10.5R
Sanwa/Futaba/Much More
Carpetwars/Sidcup RCC/Maritime Racing/7oaksmcc
Racingbod85 is offline   Reply With Quote
Old 03-05-2008, 08:18 AM   #8037
MrUnlimited's Avatar
depressing :-(
You aren't leaving the scene don't you? I have heard the Betty Ford Clinic has a new block for people who try to leave the hobby
U5 Formulaboat 1/8 hydroplane - MHZ138 AQUAMANIA - Axial Exo Terra - Tamiya Avante - LC Racing EMB1 - Atomic AMZ 4WD Touring car
MrUnlimited is offline   Reply With Quote
Old 03-05-2008, 10:28 AM   #8038
yea im leaving
dont have time anymore :-(
sign me up for the clinic lol
Old 03-07-2008, 01:19 AM   #8039
Slideaway's Avatar
Hi there !
I was wondering if someone had the chance to get the TITC 08 Set-up sheet from Masami Hirosaka or Chris Grainger.
Any info or link are welcome !
Thank you.
Slideaway
Ludo
Thai Ride Tech Support.
Slideaway is offline   Reply With Quote
Old 03-07-2008, 08:37 AM   #8040
Chris's setup
No probs on advice, setup is as follows:
Front
Drive train spool and fixed centre
Roll-bar - 1.3mm
Caster block HB
Camber - -2
Toe angle - 0
Kick up 0
Susp spacer 1mm under all
Steering arm - -0 inline
Bladder Yokomo black, no O ring no rebound
Shock - new body, 1.5mm inside, 11.6mm travel
Spring Yokomo pro dot Pink
Oil 600
Piston 3 hole
Droop - 5.5 to wishbone
Top link inner 1mm under ball
Shock upper 2nd from inside
Shock lower middle
Susp arm - graphite standard length
W/B - 5- -1
Ride height - 5mm
Ackermann 2nd hole from back and CGM steering used
Rear
Roll-bar - 1.1mm
Camber - -2
Toe angle 3.0 all inboard
Susp spacer 0mm
Bladder Yokomo black no O ring no rebound
Spring Yokomo pro dot blue
Oil - 550
Piston 3
Droop 5 measured to wishbone
Top link inner - 0mm
Top link outer - 2mm with short silver ball
Shock upper 2nd in
Shock lower - outer
Susp arm - graphite
W/B 2-2
Ride height 5
Standard chassis, standard uncut top deck, bomber belts and no rear brace. Cut motor mount and no rear post. UJ rear driveshafts, TIR fronts with Yokomo alloy spool. Alloy rear diff halves
Mazdaspeed shell
Masami's setup was a little different, not entirely sure on all of it.
Schumacher
Team Sorex
EA Motorsports
Speed Passion
East Coast Bodies
John Pape is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
