Old 02-13-2008, 06:39 AM   #7996
Island Losi's Avatar
long time.
i can't seem to get the rear of my car stable. it seems as if i don't have much side grip. id be goin into a hairpin and the rear would start hopping and slide out. the other time it happens it when i go over a bump exiting corners under power. the car either swap ends or i have to save it.
i checked my rear shocks and it seems there is binding. somethings when they are fully extended they stick at that length. i then have to pull then puch them in again. it does not happen all the time but is figure when i go into the corner it extends and binds. only mod i did to the shocks was to trim the triangle piece that goes in the bottom of the shock body. i took off half the material on the top of the 'hat' so i could get more droop. they insert it up side down.
my question is What is causing the binding? and could the Yokomo Gurus (u know who u are lol) post a step-by-step build of the shocks?
Yokomo|SpeedPassion|McgooCreative|TeamOrion|FusionPower|Futaba|Spektrum|RP|Trinity|Protoform
Island Losi is offline   Reply With Quote
Old 02-13-2008, 08:10 AM   #7997
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
the shockbody does not have a single inner diameter .. the lower part is slightly bigger than the upper part .. and if u trim the triangle piece, the piston can get into the lower part and bind at the step where the shockbody gets smaller
what rear shocktower do u use?
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 02-13-2008, 08:19 AM   #7998
razzor's Avatar
Island download a manual for the shock build here
http://www.petitrc.com/view_news.php?id=4618
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 02-13-2008, 08:35 AM   #7999
Francis M.'s Avatar
Better yet order the new Yokomo shock body. It does not need any inserts or tricks to get maximum travel......
I'm not sure but I think this is the part #YS-4SSS-7
A quick way to identify it from the outside is the octagon shape on the top vs round on the original version of the SSS shock body.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 02-13-2008, 10:20 AM   #8000
Originally Posted by Martin Hofer View Post
t
the standard at the rear.
thanks, i was thinking about that.
i looked at the shock build in the manual over and over and over. i cant seem to get more than 5.5 on the droop gaug when using the triangle pieces. i really think im doing something wrong cause when i setup my ride height i always seem to have to tread pass half-way on the front shock bodies to get 5mm ride height. im using pink front/ blue rear new white springs.
Old 02-13-2008, 10:27 AM   #8001
RC MARKET's Avatar
Masami will next week join TITC ,
maybe can see new test car kit .
RC MARKET is offline   Reply With Quote
Old 02-13-2008, 10:32 AM   #8002
Francis M.'s Avatar
You might want to look to where you put your hinge pin in the C-hubs. you should be using the lower hole in the C-hub and shimed per instructions. It makes a difference....
Also with the new shock body I can get over 10 mm of ride height if I wanted to so getting maximum uptravel is no issue.....
Old 02-13-2008, 10:44 AM   #8003
with the triangle piece in i get shock travel problems with it out i had no issues. i just wanted to build the shock as per manuel. is the triangle piece still used in the new shock bodies?
Old 02-13-2008, 11:01 AM   #8004
with the triangle piece intsalled you should be able to make the shocks 62,5mm long and this is enough for almost every downstop you'd like to use
note: when using the provided yokomo droop guage 5 is actually 4 on hudy blocks and every other gauge
cannot explain why but it is that way
so to have real 5mm u have to set 6 on the yok gauge
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 02-13-2008, 01:15 PM   #8005
ok. thanks for all the help. ill rebuild them again lookin at were the piston is in the body through the suspension stroke and see where it binds.
other than that the car is fantastic to drive. using the HB castor blocks, yokomo steering knuckles, cut top deck by the steering post, no rear bulkhead brace, no rear top deck brace. 5 cell/mod
any tips on keeping in the bottom screw on the steering block? im losing screws and HB tophats like crazy! superglue?
Old 02-13-2008, 03:01 PM   #8006
Francis M.'s Avatar
There is no inserts or triangle peices needed with the new shock body...
Old 02-14-2008, 02:52 AM   #8007
replace the steering knuckles
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 02-14-2008, 08:41 PM   #8008
Francis M.'s Avatar
Any pics of the new car or prototype?
Old 02-14-2008, 10:47 PM   #8009
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default Part where?
quick question.
I saw this pic in another thread (thanks for posting Francis M.)
but where can I get that bulkheak heatsink that is pictured here (behind the spur gear) and what's the price.
OL
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 02-14-2008, 11:26 PM   #8010
unfortunately not (yet) released
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
