Old 10-23-2007, 11:12 AM   #7786
Francis M.'s Avatar
Just got the updated shock bodies that does not require the guides. I was wondering what the difference is inside because I couldn't find it.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 10-23-2007, 11:24 AM   #7787
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
old shockbody inner diameter was slightly larger in the lower part (only visible when the triangle thingy is removed.
new bodies : same diameter throughout the whole shockbody
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 10-23-2007, 11:53 AM   #7788
fpart's Avatar
Trader Rating: 40 (100%+)
Send a message via Skype™ to fpart
whats the part number for new shock bodies and do you know who carries them(other than Yokomousa?
teamTrinity.com Sweepracingusa.com
スクービーは私のヒーローです!
Why is Scooby so slow, you might ask?
fpart is offline   Reply With Quote
Old 10-23-2007, 12:34 PM   #7789
Francis M.'s Avatar
You can have your local hobby shop order it for you, I'll get the part # as soon as I get home. Another upgrade i'm thinking of buying are the new Sway bars.
Old 10-23-2007, 12:38 PM   #7790
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
YS-4SSS-7 and yokomo usa is out of stock
JasonC is offline   Reply With Quote
Old 10-23-2007, 01:09 PM   #7791
fpart's Avatar
Jason,
Thanks!
スクービーは私のヒーローです!
Old 10-26-2007, 12:37 PM   #7792
|JayFlores|2's Avatar
Trader Rating: 16 (100%+)
Francis M. -- new sway bars? care to post the part #? thanks
....any updates for the BD?
|JayFlores|2 is offline   Reply With Quote
Old 10-26-2007, 01:40 PM   #7793
JasonC's Avatar
SD-412RS Rear Anti-Roll Bar Set for CM/BD/SD
SD-412FS Front Anti-Roll Bar Set for CM/BD/SD
Old 10-26-2007, 02:00 PM   #7794
Francis M.'s Avatar
Hi Jason, Thanks for the previous help. I was wondering what hinge pin location you are using in the front HUB? I tried to use the Higher one in the front but could not get full droop extention out of it and when using the lower hole the car the car seemed to have lost some initial steering.
Old 10-26-2007, 04:24 PM   #7795
JasonC's Avatar
are you going to BCR tomorrow
Old 10-26-2007, 06:35 PM   #7796
Francis M.'s Avatar
I'll probably pass by to watch.
Old 10-26-2007, 08:23 PM   #7797
Thanks JasonC,
@FrancisM, i prefer the lower hole and set the car up for more steering. i can steer it hard but the car is much more stable and predictable.. and with regards to your droop when the c-hub is at the upperhole, maybe its because of your shock length. make it a little longer.
Old 10-29-2007, 08:25 AM   #7798
tantalus007's Avatar
Trader Rating: 17 (100%+)
Originally Posted by jebs View Post
would you recommend me getting a motor heat sink if i use that tall drive ratio? by the way i use sub-c's so my car would be heavy.. i use johnson and i dont think the magnets are strong enough to produce that torque.. i havent tried though i might be wrong...
try a gear ratio of 5.00ish first at our tracks... if you still want some speed on the straits... gear taller but you'll lose some punch on the technical part of the tracks...
yes... motor heatsink wid fan would help especially if you change the standard fan to a much stronger fan like that of what much more offers...
tantalus007 is offline   Reply With Quote
Old 10-29-2007, 08:43 AM   #7799
tantalus007: no motor fans and burn it... black as possible anyway, hows the BD going? november 3 looks good for some serious testing..
Old 10-29-2007, 03:19 PM   #7800
fpart's Avatar
Default bd one degree rear arm mount aluminum
Does anyone know where I can find a one degree aluminum rear arm mount for a bd. I want to run some foam carpet this year and don't want to. Have to use the plastic one. Please help !
スクービーは私のヒーローです!
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
