Yokomo MR4TC-BD
Old 04-05-2005, 03:50 PM
  #766
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally posted by Matt Howard
just trim the internal spacer leaving the triangle piece and your shocks will be plenty long.
what does that piece do exactly?
...cut it off completely? so its just a triangle?
Hebiki is offline
Old 04-05-2005, 03:53 PM
  #767
Matt Howard's Avatar
I believe it's so the shock shaft doesn't wiggle too much on the O rings. I cut it so the triangle piece is the only thing left.
Matt Howard is offline
Old 04-05-2005, 04:11 PM
  #768
rocketron's Avatar
Trader Rating: 16 (100%+)
Originally posted by KilRuf
Yes it does. The front pulley is pinned to the center shaft. And the spur mount/rear pulley is a oneway unit. However, the center shaft has 2 pin holes. Only one is used for the front pulley. That tells me they are designing a locked/pinned rear pulley/spur mount.
rocketron is offline
Old 04-05-2005, 04:20 PM
  #769
Hebiki's Avatar
sweeet. time to do some cutting tonight.
(btw.. are you making the trip for the reedy race?)
Hebiki is offline
Old 04-05-2005, 04:22 PM
  #770
I sure hope Yokomo gets the diff pulleys in the states soon, I need a diff for carpet racing. I'm willing to try the center one way since I don't use brakes ever. It might actually work quite well.
kmorast is offline
Old 04-05-2005, 04:24 PM
  #771
pheyhoe's Avatar
Ok, its been a while since i drove belt.
This center pulley shizzle..... Does it make any difference if you installed a front diff with the standard kit center pulley???
A quick lesson in what it does would also be appreciated...
pheyhoe is offline
Old 04-05-2005, 04:26 PM
  #772
hey matt,
that is a lot of cutting.....
man, mine won't be here till tomorrow....
TOMORROW!!!!!!!!!
~ming
aoizip is offline
Old 04-05-2005, 04:32 PM
  #773
I haven't run a center one way since I ran rubber on carpet, the front one way makes a huge difference. The center one way is not as noticeable. However you will loose the ability to brake with the front tires. I think the car might actually go through the corners better running a center one and front diff then it would running a front diff and locked center drive. You may actually notice the car is faster in the straights also with a center one way. But remember the gains may not be as great as the loss of braking.
kmorast is offline
Old 04-05-2005, 04:36 PM
  #774
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
Originally posted by aoizip
hey matt,
TOMORROW!!!!!!!!!
~ming
it's not THAT much , plus it's worth it . - JB
JayBee is offline
Old 04-05-2005, 04:49 PM
  #775
pheyhoe's Avatar
So with a center one-way (kit one) even if you put a front differential in you have no brakes?
I know about the front and rear diffs/oneways/spools but the center one has me baffled, lol
pheyhoe is offline
Old 04-05-2005, 06:05 PM
  #776
Don't be baffled, the center one way allows the front belt to spin free of the rear belt when off power; it then locks when on power. You will not have front brakes when you have a center one way. This option is not for a new racer; but can work great for an experienced driver.
kmorast is offline
Old 04-05-2005, 08:20 PM
  #777
ROBORAT's Avatar
back in the old mr4tc days, i ran a center one way and front diff set-up for a time. it felt like using just the center one way was like a "middle off the road" set-up vs going with the one way in front or full diff config. it was a bit easier to drive through the corners - a bit more forgiving for the not so experienced driver who wanted the better cornering a front one way would give but had difficulty driving one. but if one can handle the dual one way config, the car will really fly through the corners (for asphalt racing at least). less scrub off power (more efficient) and it rips out of the corners. ... but yes, no brakes.
ROBORAT is offline
Old 04-05-2005, 08:31 PM
  #778
Mr. Shookie's Avatar
Got mine all freed up it rolls and rolls off power.....Like 30' roll....Gotta love the center/front Oneway setup.
Stephen <><
Mr. Shookie is offline
Old 04-05-2005, 08:42 PM
  #779
Ortiz's Avatar
Has anyone weighed their car with all the electronics, rubber tires, and body? If so how much? The box says 1500g, so i would guess thats an estimate with some sort of electronics, tires and body
Also, just tried to put on a foam tire( tried the most popular brands Ex. Jaco, TRC, Parma) to see if it clears the shock eyelet. Looks like it rubs if you are using the outside hole, guess you might have to use spacers or use the inside holes on the arm to run on carpet.
Jairo Ortiz
Ortiz is offline
Old 04-05-2005, 08:43 PM
  #780
not a one way question, but what is your guys favorite brand of tool for doing the 2mm screws. mine always seems to fit the screws loose after a few weeks of use.
Turtlemaster is offline
