Old 09-20-2007, 10:24 AM   #7681
To mount the HB C hubs you need to use the HB top hats. There are 2 ways you can do it. The first way (the way Chris does it) is to cut the flange part off one of the top hats. You then put the steering arm in the castor block and put the bottom top hat (the one not trimmed) in from underneath the castor block and insert the screw. Then using the trimmed top hat insert it in the top and screw the balljoint in.
I do it slightly different in that i machine off the top of the steering hub so instead of the having the slight curve on the top its flat and insert a untrimmed top hat before i put the steering hub in.
KO GP setup was exactly the same as the Euros setup I posted, just with 1.4mm front and 1.2mm rear roll bars. Using the new versions.
Schumacher
Team Sorex
EA Motorsports
Speed Passion
East Coast Bodies
John Pape is offline   Reply With Quote
Old 09-20-2007, 10:54 AM   #7682
Thanks for the information John. I am sure that most folk appreciate the help that you give on here.
Thanks Again
Bryan D is offline   Reply With Quote
Old 09-20-2007, 04:32 PM   #7683
Island Losi's Avatar
Thanks Again
x2
Island Losi is offline   Reply With Quote
Old 09-20-2007, 04:58 PM   #7684
tim fry's Avatar
Hi all
When running the narrow worlds front arms and using a one way should I still use o rings in the drive cups as with them in it seems to bind a little and with them out the drive cup moves in and out?
tim fry is offline   Reply With Quote
Old 09-21-2007, 01:17 AM   #7685
Sleighty:
we have high tracktion on our inside track carpet and when we started training inside beginning of this month changing from those shorter front arm to standard was one of the first things to do. We have had to do other changes aswell to decrease steering.
jarkko is offline   Reply With Quote
Old 09-21-2007, 08:51 AM   #7686
JJC
@ John Pape.
Just wondering what driveshafts you and Chris are running in the front of your BD's?
Running a spool combined with the extra lock of the CGM steering mod I've been snapping the drive shaft joint pins under accleration exiting corners. I had heard these were a weak point so built mine up from new using pins cut from 1.5mm drill bit blanks (as suggested on this thread), but these still snapped. I guess the extra lock does put more strain on the pins.
Will try the standard pins now, but would like a more permanent fix.
JJC is offline   Reply With Quote
Old 09-21-2007, 08:52 AM   #7687
Sleighty's Avatar
Originally Posted by jarkko View Post
Sleighty:
thanks alot
Sleighty is offline   Reply With Quote
Old 09-21-2007, 02:42 PM   #7688
Originally Posted by JJC View Post
@ John Pape.
somewhere in earlier post they talked about reducing the lock to prevent this. if u go over a particular angle u'll run the chance of failure. i may be wrong thought so check it out......also many people run TiR driveshafts as well.
Yokomo|SpeedPassion|McgooCreative|TeamOrion|FusionPower|Futaba|Spektrum|RP|Trinity|Protoform
Old 09-21-2007, 04:14 PM   #7689
Currently running TiR in the front, but I have been playing with running Associated driveshafts and Rayspeed axles at the moment.
I know at the Japan nats they ran associated driveshafts due to the level of grip being high and the nature of the track the TiR ones kept breaking.
Standard front wishbones should be better in indoors by the way.
Schumacher
Team Sorex
EA Motorsports
Speed Passion
East Coast Bodies
Old 09-22-2007, 02:32 AM   #7690
JJC
Thanks for that
Old 09-23-2007, 02:18 PM   #7691
Sleighty's Avatar
Sleighty:
Hi do you have any other tips for me?
Tried the car again today with standard wishbones, with a one way setup similar to the Olly J setup on the CML website. Car still traction rolled and simply handled badly, i tried a friends car with the 3mm chassis and his car felt much better. Car just feels very vague almost like you dont know what its going to do in the middle of a corner, whether it will grip, slide or traction roll.
Im sure if i put a stock motor in the car it would most likely handle great, but with modified it just doesnt like it.
any tips or a set up to try would be great, im running 5 cell 3.5 brushless with LRP Vtec27R tyres. What i cant understand is back when i ran foams, the car was brilliant and i never had a problem. I wouldnt have thought rubbers would give the car such a problem
Old 09-23-2007, 08:46 PM   #7692
Jochim_18's Avatar
Use a harder compound tires. Try 30's all the way around.
Old 09-24-2007, 06:11 AM   #7693
Sleighty's Avatar
Wish i could, its control rubber so thats kinda out of the question
Old 09-24-2007, 11:00 AM   #7694
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
Have you tried using a spool?
This should make things much easier for you. Especially with a 3,5T indoors.
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 09-24-2007, 11:08 AM   #7695
Sleighty's Avatar
I havent yet, i was trying to avoid doing that firstly because i wanted to protect the driveshafts secondly because i heard that the car was good with a one way with rubbers. Spose i might have to try it.
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
