Old 04-05-2005, 10:14 AM   #751
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Someone who has run the car, how long is your shock length?
Old 04-05-2005, 11:15 AM   #752
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Originally posted by Randy Caster
I am going to go to SoCal today and tomorrow for Off-Road practice, but I'm going to take the BD and should be able to get it all finished while I'm up there, not much left to do.
Ceramics are nice because they last a really long time, if I end up liking this car, I'll put a set in.
I'm running a 104 tooth PRS gear, I dont see any need to go bigger personally.
I am planning on racing the whole JBRL series, should be a lot of fun. Do you know if you just sign up at the track, or if you have to sign up prior?
Here is where I disagree with Jimmy. You have to sign up at the tracks but the worse part is the sign ups begin @ 6AM....Man I have to drive more than hour for almost all of the races...That is one lonnnnnnnnnnnnnnnnng Day.
I haven't measured mine I just built them by the book. I did notice that I had to use the longer shock mounts on the front otherwise I could no higher than 4mm ride height. Once i went with the longer ones for the front everything was copasetic.
I think I will just stick with the 105 it covers all right ratios for stock and 19T (5.25-8.40) So to go larger would be a waste since it just adds weight to rotating mass.
One casualty from this last weekend.....Broke a rear diff...well really I just overtightened it and stripped the nut mount....Oh Well I had some Acer ceramic diff and thrust balls just sitting around, rebuilt the diff with the spare SD diff halfs I already have....(thanks again yokomo)....And viola....Super smooth rear diff now.....Just a hint....Break in your diff before you run it.....I believe Randy posted about how he breaks in his belts.....(Great to knwo since I never owned a belty 10th scale...Anyhow it really helps the diff to also get some workout too....I picked up the diff break-in tool from niftech which attaches to your dremel makes a world of (diff)erence.....LOL ultra pun intended.
Stephen <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 04-05-2005, 12:07 PM   #753
Hebiki's Avatar
Trader Rating: 26 (100%+)
Randy.. thats kinda personal dont you think?
i set my shock length at kit length. i think btween 59mm and 61mm.. i dont remember. ill look it up tonight. i set equal all around. but looks like ill need to make the front a tad longer since i have a lot of preload. again.. gotta check tonight
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 04-05-2005, 12:08 PM   #754
pheyhoe's Avatar
do you think its worth glueing the nut into the mount???
is the main diff bolt the same size as an SD?
i was doing up an associated TC4 one the other night and it just snapped like plastic, when i looked at it it was tiny! very thin indeed.
[SIZE=1][COLOR=navy]Paul Heyhoe[/COLOR][/SIZE]
pheyhoe is offline   Reply With Quote
Old 04-05-2005, 12:08 PM   #755
rc-zombies's Avatar
Hey Ramon, it's been a while since I ran the SD, but these look like they are interchangeable, just beefed up a lot from the SD. The Rayspeed springs do work on the car, I bought full sets of all the different spring rates just to be sure I'm ready for everything
thanks Randy
just curious..does the car come with the front one-way or front diff?... I'm assuming the one-way.
Good thing I didn't get rid of my RS springs...
Old 04-05-2005, 12:09 PM   #756
pheyhoe's Avatar
It comes with a one way,
Also if anybody has any diffs available, sell me one! i neeed one
Old 04-05-2005, 04:09 PM   #757
rcfiend's Avatar
Trader Rating: 30 (100%+)
Ok let me make sure that I have this right. The springs that come with the kit are rayspeed springs?? Or are they yoke springs?
Mr. Shookie - can you provide me the link to the niftech diff break-in tool.
Last question, does yokomo selll a diff set that will fit the BD or do you have to piece everything together??
Thx
rcfiend is offline   Reply With Quote
Old 04-05-2005, 04:20 PM   #758
JimmyMac's Avatar
The BD comes with RaySpeed springs.
And you have to build our own diff from all the SD parts minus SD diff gear (duh) hehe..... But still waiting on the BD spare parts so that I can get a diff pulley. Also note though... you'll need to wait for a locked/fixed center pulley/spur mount. Or you could just drill a hole through it and pin it to the center shaft.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 04-05-2005, 04:31 PM   #759
Hebiki's Avatar
Default Gear Chart Ratio
for BD owners:
www.yokomousa.com/manuals/mrtc-bd_gear_chart.pdf
Hebiki Design Works
Old 04-05-2005, 04:34 PM   #760
rcfiend's Avatar
Thanks kilruf, guess I better get a list of parts together.
Old 04-05-2005, 04:36 PM   #761
rc-zombies's Avatar
why is that?...does have a center one-way..?
Old 04-05-2005, 04:38 PM   #762
JimmyMac's Avatar
Yes it does. The front pulley is pinned to the center shaft. And the spur mount/rear pulley is a oneway unit. However, the center shaft has 2 pin holes. Only one is used for the front pulley. That tells me they are designing a locked/pinned rear pulley/spur mount.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 04-05-2005, 04:42 PM   #763
Hebiki's Avatar
Default Diff Parts
SD-501R : Outdrive ring
ZS-508 : Nut
SD-501 : Diff Outdrive
ZS-506 : Diff rings
BB-850 : 5x8 bearings
ZD-505 : Diff balls
ZS-507 : Thrust bearing
ZS-508 : Diff spring/screw
ZC-S100S : Shims
BB-1510 : 10x15 bearing
BD-BAC : Bearing holder
BD-503 : Pulley
Hebiki Design Works
Old 04-05-2005, 04:47 PM   #764
When building the shocks you want them to be about 64mm on front and 62mm on back. You get this length by unscrewing the shock end or modifying the shock internals (ask Matt Howard how). You will need this length in order to get the droop correct when running small foam tires. It's not really anything you need to be worried about; just remember long enough to get the correct droop. Droop screws will ultimately adjust how far the shocks extend.
kmorast is offline   Reply With Quote
Old 04-05-2005, 04:49 PM   #765
Matt Howard's Avatar
just trim the internal spacer leaving the triangle piece and your shocks will be plenty long.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
