Old 08-29-2007, 10:55 PM   #7606
E-clip's Avatar
Trader Rating: 39 (100%+)
I will have to check that as well.
so no thinks it could be the shock mounting holes ???
E-clip is offline   Reply With Quote
Old 08-29-2007, 11:20 PM   #7607
Island Losi's Avatar
may be the shock mount screw is screwed in at an angle into the arm. thus changing the length between shock and tower
Island Losi is offline   Reply With Quote
Old 08-29-2007, 11:41 PM   #7608
djlove85's Avatar
Default Picture?
i would like to see some picture of chris graiger BDif you know were? thank,s
djlove85 is offline   Reply With Quote
Old 08-30-2007, 04:36 AM   #7609
Heres a post from John Pape of Chris Graingers car from a few months back.
http://www.rctech.net/forum/showpost...postcount=6990
adyb is offline   Reply With Quote
Old 08-30-2007, 05:08 AM   #7610
Sleighty's Avatar
Originally Posted by John Pape View Post
Ah yes, dreaded carpet racing. We havent run the car yet with 5 cells on carpet yet, first meeting is in October. The car we are running is quite a bit different from last year so I would expect the carpet setup may differ from last years.
We were running the cgm steering conversion last year, well I was anyway, can't remember if chris was or not.
Ok thanks John, I ran the car last night with a similar setup to Chris's most recent tarmac setup that i got from him after West London - purely to give me some kind of base. Car was awful which i kinda expected. Lots of turn in oversteer so any suggestions of a base to work from would be great.
thanks
Sleighty is offline   Reply With Quote
Old 08-30-2007, 06:40 AM   #7611
kermit's Avatar
Originally Posted by E-clip View Post
droop screws are out
I've had a similar problem with my car but on the rear end. At first I thought it was droop. In the end it turned out to be the rear shocks. A long overdue rebuild of the shocks fixed the inbalance in their natural travel.
kermit is offline   Reply With Quote
Old 08-30-2007, 06:48 AM   #7612
ark
Hey am i seeing things or does that pulley on Chris's car look like a prototype part?
ark is offline   Reply With Quote
Old 08-30-2007, 06:43 PM   #7613
E-clip's Avatar
Thumbs up
Originally Posted by jarkko View Post
E-clip, have you checked that the shock tower is not tilting towards one side.
The winner is JARKKO Thanks for everyones Advise
Old 08-31-2007, 12:33 AM   #7614
The screw holes in the shock tower are big enough to allow some movement of the tower. Some people have made countersunk holes for the two upper screws and I will also do that to our BDM's.
Another tip (if screws are not not countersunk) - before retightening the shock tower screws hold it from the middle and lift up and then tighten the screws. This way the tower will not tilt as easily when the car hits a track marker etc.
jarkko is offline   Reply With Quote
Old 08-31-2007, 12:16 PM   #7615
fpart's Avatar
Trader Rating: 40 (100%+)
Send a message via Skype™ to fpart
Anyone know where I can get an SD-202G other than Yokomousa? Also, is the D-004 the same only aluminum? The drift cars really just a CGM anyway right?
teamTrinity.com Sweepracingusa.com
スクービーは私のヒーローです!
Why is Scooby so slow, you might ask?
fpart is offline   Reply With Quote
Old 08-31-2007, 07:44 PM   #7616
Trader Rating: 17 (100%+)
Send a message via Yahoo to Chico
Hey guys, I have a post in the wanted section for a yokomo BD. So if anybody here has one for sale, please email me what you got at [email protected]
Thanks Chico.
Chico is offline   Reply With Quote
Old 09-01-2007, 10:28 AM   #7617
hey ARK
i noticed that pulley mod aswell also if you look closely on the back pulley you can c that every second tooth is missing.
does any body know why his done this and the advantages or was it just for the euros and that particular track and set-up.
cheers
blazer2 is offline   Reply With Quote
Old 09-02-2007, 10:07 AM   #7618
highwayman's Avatar
Originally Posted by blazer2 View Post
hey ARK
cheers
one "trick" to free-up the drive train before on the XXX-S and XXX-4 was to cut out every other tooth of the BELT, and this really did reduce the friction, thereby freeing-up the drive train... im guessing this is just a variation of that, to make the BD's drive train even more lighter for spec racing.
highwayman is offline   Reply With Quote
Old 09-03-2007, 08:30 AM   #7619
cheers highwayman, if i was to do this mod on my car would the overall internal gaer ratio change. cheers
Old 09-03-2007, 09:32 AM   #7620
jebs's Avatar
Send a message via Yahoo to jebs
i dont think that the drive ratio would change since you are not changing the drive pulleys. but would that modification increase the wear of the belt since less teeth would support the force on the belt? wouldnt want to try that on my first belt driven car... hehe
jebs is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
